07-13-2016, 09:35 PM | #1 |
Rep 1,239
What voltage is your battery reading on a normal day?
I'm only at 12.4V. I have no problems but it seems low.
A job is nothing but work.
07-14-2016, 04:11 AM | #4 |
Rep 7,120
Been checking the voltage as well Monterey and believe 12.4v is ok (Measured on battery). Although it should be more like 12.7v when full and no load I'm assuming soon as you unlock to open the bonnet some current will start to be drained. Have been like this pretty much since I bought the car 2.5y ago so have to assume its ok.
Cheers Ps. This is obviously with no engine. |
07-14-2016, 08:44 AM | #5 |
Save the Manuals
1714
Rep 2,937
Depends on if wet cell or AGM.
12.4v is ~ 60-70% charge state IMO, That's a bit low for an AGM, however they recover typically from deep discharge so maybe it needs a good topping off. If after a good drive it is still 12.4 it may be on its way out-- I changed my Exide out when it read 12.4v after an hour drive, and it had been on a CTEK tender before the drive! My new AGM at rest (24 hours) reads 12.8v A load test will reveal if the battery can do its job- starting the engine
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
