      01-21-2014, 04:26 PM   #1
Mike Townsend
Drives: e90 M3 2010
Inspection of DCT
Hello,
I have a 2010 e90 DCT that is coming to the end of the factory warranty period.
I wanted to to see if there was a well known inspection that can be made of the DCT to check on the health of the DCT. For example, is there an easy visual from underneath the car?
I don't have any symptoms now but I'd like to know if I have a growing problem while the car is still under warranty.
I checked the threads and found a few discussions about leaks detected after shields were removed.
Thanks for any assistance.
      01-21-2014, 05:06 PM   #2
blankstar43
Drives: 2012 e92 M3
I don't kno for sure, but I doubt there's much you can see from simply looking under the car at the transmission besides a fluid leak or broken bolts? I'd imagine you will be able to feel it in the shifts b4 there is any visible sign without cracking open the transmission
2012 JZB/Fox Red M3 DCT -JZB reflectors, CF gills, gloss black grills
      01-21-2014, 06:43 PM   #3
MTM
Drives: 2009 M3
I am pretty sure Blackstone can do a fluid analysis on the DCT, which is probably the best way to get some insight into the health of your transmission.
      01-22-2014, 12:09 AM   #4
grantmax
Drives: 2011 M3 ZCP
Originally Posted by MTM View Post
I am pretty sure Treadstone can do a fluid analysis on the DCT, which is probably the best way to get some insight into the health of your transmission.
Fixed.
This is the only "real" way to figure out what's going on in there. Short of cracking it open (not recommended).
      01-24-2014, 12:12 PM   #5
Mike Townsend
Drives: e90 M3 2010
Thanks!
Tags
dct, inspection
