PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
Staggered wheels on xdrive?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
08-19-2021, 12:57 PM | #1 |
Rep 13
Would it be ok too run a staggered setup up on an awd car? I have a 2011 328i xdrive, and I'm looking at the e9x m3 wheels. I don't know the exact size but I know they're staggered.
08-25-2021, 08:10 PM | #3 |
Rep 49
I own your same car but with the M-sport package which came with the staggered set up. So yes, you can run staggered and it would be great. But what you SHOULD run is a 17" square set up. That's right 17". I could afford to replace all my wheels and tires with whatever is out there and I went with 17" square, Apex wheels and Michelin Pilot Sport AS 4 tires. I HATE run flats. Despise run flats. If you get a flat, carry a spare, or carry a can of fix a flat, or drive on the damn rim for 500 miles, or set the whip on fire and jet pack away like a boss!
245/40ZR-17 tires - all the way around Apex 17x8.5" ET40 Hyper Black APEX ARC-8 BMW - all the way around and when your dumb sheet "friends" ask, "Why did you get 17s? You could of put 19s on that bitcch." You reply "Because I got 99 problems and a bittch aint one." |
Mac Ram1.00 alpinec1984132.50 |
08-26-2021, 01:27 AM | #4 | |
Rep 13
08-26-2021, 09:10 AM | #5 |
Rep 49
Define "stock rims" - do you mean the stock rims currently on your car? 245/40 fit nicely on any 17" 8.5" wide ET40 wheel made for BMW.
10-19-2021, 09:23 PM | #8 |
Rep 50
The reason you were asked to define "stock rim" is because there are literally hundreds of wheels offered by BMW that can come standard on the 3 series depending on various packages/options.
You *appear* to be running style 284 wheels, which are 17x8 et34 square. 245 would not be the recommended tire size for an 8-inch wheel, though it could be used. If you want to run 245/40, like previous post mentioned, pick up a set of Apex wheels, they have been trusted wheel manufacturers for BMW enthusiasts for quite a while. Or search the classified forum for gently used Genuine BMW wheels in 17x8.5 or 18x8.5 Running staggered is not going to spoil the driving behavior of the car but it will complicate maintenance (rear tires will be slightly more expensive and your setup will be non-rotatable, not to mention you will need to dial in your alignment) Be sure to search around before changing tire sizes or wheel diameters… there is a thread on here that details the rotating diameter tolerance.
@N52_e92 on Instagram
LCI 328i xDrive | 3-stage IM | AA catless headers | Turner Motorsport tune | 330i muffler retrofit | APEX EC-7 18x8.5 et35 square | Michelin PS A/S4 235/40-18 |
Mac Ram1.00 |
10-21-2021, 10:35 PM | #10 | |
Rep 50
Certainly it's within range of what can safely be mounted on an 8" Regarding OP, I believe you would encounter issues running 245/40 on 17s due to the change in rotational diameter, let me go dig that up [ EDIT : the issue is not with the new rotational diameter, rather the difference between front and rear axle ]
Mac Ram1.00 |
10-21-2021, 10:47 PM | #11 |
Rep 50
https://www.bimmerpost.com/forums/sh....php?p=3646192
Long story short: Staggered can be done on xDrive but your rotational diameter difference between front axle and rear axle must be kept to a minimum (1% or less is the commonly-referenced threshold). Anything beyond that and you risk damage to your transfer case (multi-thousand dollar replacement cost). The benefit gained from staggered setup is probably not worth it unless you have a specific application for its use.
Mac Ram1.00 |
10-22-2021, 07:12 AM | #13 | |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
10-28-2021, 11:37 AM | #14 |
Rep 96
10-28-2021, 12:15 PM | #15 | |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Square 17, 18, 19 all work perfectly fine. Same with staggered 17in.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
10-29-2021, 10:46 AM | #16 |
Rep 4,330
I ran 245/40r18s on 18*8 wheels for a long time without issue.
my winter tires are still 245/40/18 on 18*8 wheels. 32 offset IIRC. they work fine at stock xdrive height. they will rub the front bumper a touch on big dips if you lower the car. I also run staggered summer wheels, 225/40 255/35 so yes, all things are possible. |
11-01-2021, 08:37 AM | #17 |
Rep 96
Yes, things are possible but not recommended. And here in Europe they are not even legal as we cannot use tires other from the recommended sizes.
Anyways, your car, your country, your choice. |
