BPM
      10-24-2016, 01:03 PM   #1
///M Kidding
///M Kidding's Avatar
Drives: E92 M3 DCT
High flow cats recommendations?
Hi guys,
I currently have the challenge street xpipe, and I want to switch the OEM primary cats to high flow cats if possible. Any one has any experience with these stuff? Any recommendations? Also, are there any downside switching the OEM cats to HF cats?
Thanks in advance.
11 E92 M3 DCT | Evlove Stage 2 Tune | Evolve Test Pipe | Akrapovic slip-on | MS Stage 2 Intake | Ohlins R/T | Vorsteiner VFF-101 | OSSdeisgns | Exotics Tuning
      10-24-2016, 01:20 PM   #2
dparm
Stop the hate, get a V8
dparm's Avatar
Downside is the car will get a bit louder, depending on which specific cat you go for. A "larger" cat (e.g. more volume) will tend to be quieter since it has more mass and material to absorb the sound. It will also change the tone of the exhaust, and possibly not for the better -- they tend to get tinny and raspy.
You should also check into your local state laws about this. If there's a visual check as part of emissions inspection, you will fail. It's illegal in all 50 states to modify or remove a functioning emissions device, as I understand it.
Past: 2011.5 M3 sedan ZCP
      10-24-2016, 01:45 PM   #3
///M Kidding
Drives: E92 M3 DCT
Thanks for the input, the main thing I'm after is the power gain. As for the sound, I don't think it's going to be too bad right? Because a good amount of people run HFC here on the forum.
As for the state law, I think I will be fine
      10-24-2016, 02:30 PM   #4
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11500
I run the ESS HFC Xpipe. Very nice, light and it sounds wonderful. Having an xpipe actually reduced the drone at 3200rpm!
      10-24-2016, 02:31 PM   #5
dparm
dparm's Avatar
I see that you have a Challenge X-pipe and Akrapovic exhaust. I would talk to both of those companies and see if they offer matching high-flow cats and explicitly ask them about the sound (e.g. "is your cat converter designed to complement the exhaust, rather than being a generic off the shelf one").
This is the problem when you piece together an exhaust: you never know what it might sound like.
      10-24-2016, 02:37 PM   #6
///M Kidding
Drives: E92 M3 DCT
Good to know, what did you pair with?
      10-24-2016, 02:39 PM   #7
///M Kidding
Drives: E92 M3 DCT
I will try to contact them but I think they will just tell me to buy the xpipe from them since they both have their own HFC xpipe mass produced lol
      10-24-2016, 03:15 PM   #8
dparm
dparm's Avatar
Ask them point-blank why you should buy theirs versus someone else's.
      10-24-2016, 03:34 PM   #9
///M Kidding
Drives: E92 M3 DCT
Lol not sure it's the best thing to ask, I just did some research and found out adding HFC in the stock primary cats' position does not add a lot power... :
      10-24-2016, 04:57 PM   #10
KRZ3
Drives: E90 M3
Tried the Akra Evo full line. Too much drone and lots of torque lost in the low rpms. Now on ESS HFC and mufflers. No drone, torque is back and the M sounds like an Aston Martin, very sophisticated. I just love it.
'09 E90 M3 DCT EDC, ESS VT2 625, ESS HFC, GTS DCT, D2R BBK, B16D, VORSHLAG CP, DELRIN SUB, TE37SL
'00 996.1 GT3 CS
      10-24-2016, 05:01 PM   #11
///M Kidding
Drives: E92 M3 DCT
Yeah I've heard the akra evo drones a bit, glad you like your new setup
KRZ323.00
      10-25-2016, 01:10 PM   #12
SYT_Shadow
SYT_Shadow's Avatar
11500
Evolve valvetronic catback
      10-25-2016, 01:31 PM   #13
///M Kidding
Drives: E92 M3 DCT
Why didn't you choose evolve's HFC xpipe? I heard their xpipe is pretty good.
      10-25-2016, 02:47 PM   #14
SYT_Shadow
SYT_Shadow's Avatar
11500
ESS is the only one that maintains the HFCs in their original position, and I've worked with ESS in the past and have a lot of trust in them.
If they built a valvetronic rear section I would have gone with them. Mind you, the Evolve has worked out well
      10-25-2016, 02:52 PM   #15
///M Kidding
Drives: E92 M3 DCT
Doesn't it kill power if the cats are located at where the stock cats were? At least that's what I've learned from previous research.
      10-25-2016, 03:55 PM   #16
loveskiing
Drives: 2011 M3 E90
Another vote for ESS X-pipe with HFC, but it's wedded to the Corsa axle back. Zero drone and IMHO, the best sound of all that I've heard.
      10-25-2016, 04:04 PM   #17
SYT_Shadow
SYT_Shadow's Avatar
11500
Their xpipe shows nice gains. OEM cats are restrictive and around 4x the volume of the hfcs ESS uses
      10-25-2016, 04:11 PM   #18
///M Kidding
Drives: E92 M3 DCT
Have you run a dyno comparison? Got any numbers? Or, it's the feeling that there's obvious power gain after installing the xpipe?
      10-25-2016, 06:13 PM   #19
SYT_Shadow
SYT_Shadow's Avatar
11500
There was clear and unmistakable power gain from this. I'm sure someone did the dynos. Many supercharged cars are running this setup
      10-25-2016, 07:12 PM   #20
///M Kidding
Drives: E92 M3 DCT
Cool, good to know
      10-26-2016, 05:41 PM   #21
SYT_Shadow
SYT_Shadow's Avatar
11500
Cool, good to know
Here you go, they claim 20hp. Given their ample experience with BMWs, I have no reason to doubt them
http://esstuning.com/ess-e9x-m3-exhuast-full-system/
Best part of their hfc is you maintain emissions readiness
