09-07-2015, 07:26 PM | #1 |
Rep 112
2nd to 3rd gear grind under high rpm???
Interesting thing started happening today....When running hard and shifting from 2nd to 3rd under WOT and high RPM it will almost seem like I miss 2nd to 3rd shift. It happen maybe 1 out of 2h0 times.
Car has 120k miles. I put in a Stage 1 Spec clutch 3000 miles ago. I'm running redline D4 ATF. Any of you guys hear of this before? Thanks
09-08-2015, 09:13 AM | #2 |
Rep 478
Not sure if this applies to bimmers but on my old 5spd Eagle Talon TSI AWD it would grind 1-2, 3-4 under WOT @ high RPM because the the clutch fork wasnt pushing the pressure plate enough so its as if the clutch was never disengaging between shifts.
If i was you I would check your clutch fluid first, bleed the whole system and see if the problem still persists. |
09-08-2015, 10:35 AM | #3 |
Rep 112
Yeah....I was thinking about that as well....I did bleed the clutch pretty well a few weeks ago but I'm wondering if maybe after driving hard that all the mechanics just don't work as well (Master Cylinder, Slave Cylinder, High RPM, Added force with the after market pressure plate, fluid temp, etc) and occasionally this happens. Like I said it only happen every once in a while. Otherwise it is smooth as butter.
Thanks for your response.
09-08-2015, 11:22 AM | #4 |
Rep 368
I never had the grinding between gears issue but I couldn't change gears when driven very hard on the track, even double clutching didn't work. The only variable that track day was the same redline ATF.
Spoke to a few hardcore Porsche track guys and they had issues with the Redline stuff as well. I went back to OEM stuff and pulled off the small metal deflector on the tranny cooler. worked for me.. What fluid did you use before the clutch was replaced? |
09-08-2015, 11:32 AM | #5 | |
Rep 112
I'm probably going to try some OEM fluid and see what happens. That stuff is just so expensive. BUT... if it works it works. Thanks guys.
09-10-2015, 11:19 AM | #6 |
Rep 383
I use the synchromax from Royal Purple or the syncromesh from Penzoil in manual transmissions.
I've had good luck with that fluid. I will say that I've driven manuals for years and this car requires a much slower engagement from one gear to the next to avoid grinding. Last edited by douglee25; 09-10-2015 at 12:30 PM.. |
07-08-2016, 10:43 AM | #7 |
Rep 112
Just wanted to post an update...
Replaced both master and slave cylinders and feel was greatly improved. Mileage on clutch and fluid has also greatly improved performance. I heard/read once that a little mileage on your tranny fluid actually is important which I'm starting to believe. Additionally....I've read many comments and done many searched on grinding gears in our cars and this is actually more common than I thought. When our cars are in high rpm range the chances of grinding does increase apparently. In my case my frequency was too common and was greatly reduced by replacing my master and slave cylinder to almost a none issue. If it does happen it seems to be a driver error now.
07-08-2016, 11:58 AM | #8 | |
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
07-08-2016, 01:52 PM | #9 | |
Rep 81
Drives: 2013 E92 M3 MT
It may just be me but the 3rd gears synchromesh seems to be the most vulnerable. Its more likely to happen at high RPM because of differential in the shaft speeds. See if it goes away with double clutching. If it does its likely the mesh.
