      10-08-2016, 08:05 PM   #1
crunchy_frog
crunchy_frog's Avatar
Drives: 2008 E92 M3
DCT maintenance questions
I'm thinking of getting an oil and filter change for my dct. i have a few questions
i'm looking at the parts from here
http://www.realoem.com/bmw/enUS/show...diagId=28_0005
1-is the oil pan reused or new one is used? isn't there usually a gasket for the oil pan?
2-there is a part called the sucking jet pump (#4), is that reused or a new one is needed
3-what about the 2 oil drain plugs (#2 and #9) are they reused?
thx
      10-09-2016, 11:59 AM   #2
dparm
dparm's Avatar
Drives: Corvette Grand Sport
Why are you changing the oil pan? Unless it's damaged, you don't need to remove or replace it. Same goes for the pump.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
      10-09-2016, 12:06 PM   #3
crunchy_frog
Drives: 2008 E92 M3
to change the filter, the oil pan needs to be removed.
      10-09-2016, 12:17 PM   #4
Amirsm3
Amirsm3's Avatar
491
Drives: 2011 Space Grey e90 M3
From what I've seen with the metal filters from Gintani (I think....could have been a different vendor), you don't have to drop the pan to replace the filter.
I'd replace the drain bolts and washers, why not? It's like a couple dollars a piece. I don't think I'd replace the pump.
BMWCCA:518970
      10-09-2016, 02:27 PM   #5
dparm
dparm's Avatar
The shop that changed my filter at 50k did not drop the pan.
      10-09-2016, 03:07 PM   #6
Rat3d ///M
997.1TT
Rat3d ///M's Avatar
Drives: 2007 Porsche 911 Turbo
That's not possible. They likely changed the side cartridge style filter but not the pan filter. There are two.
      10-09-2016, 03:29 PM   #7
dparm
dparm's Avatar
Ah yes, thank you for clarifying -- they changed the cylindrical one on the side.
      10-09-2016, 04:18 PM   #8
Umi|all|day
Umi|all|day's Avatar
67
Drives: 2010 SS M3 E92
DCT oil is lifetime, isn't it?
      10-09-2016, 06:29 PM   #9
WingZeroX5
WingZeroX5's Avatar
Drives: 09 E90 M3
http://www.m3post.com/forums/showthread.php?t=1280752
      10-11-2016, 11:26 AM   #10
dparm
dparm's Avatar
According to BMW, yes. Most people change it at 50k but almost every analysis I've seen shows the fluid is good past 50k. Blackstone said mine probably could've done 75k.
      10-14-2016, 01:54 PM   #11
drwankel
Drives: 2012 M3 Coupe DCT
Its also important to note that the pan gasket is not available separately. Its only available with a new pan.
If you change the cartridge filter you then have to replace the pan. It doesn't make any sense to me why these DCT service kits don't include the pan.
Search this Thread:
Advanced Search
