06-03-2011, 12:23 PM | #1 |
Rep 12
My new Yokohama AD08 feels soft!
Hi!
Just shifted my old PS2:s to Yokohama AD08. I'm rolling on OEM 19" weels and kept the stock dimensions on the new tires. I was expecting a sharper feeling, but got the opposite. The new tires feel softer than my old PS2:s. The grip is ok (compared to the very much worn out PS2:s), but I was expecting a much crisper feeling. Current pressure: 38 front and 40 back. Any ideas? Is a weel aligment typically necessary when going to more performance oriented tire? Thanks, J |
06-03-2011, 12:36 PM | #4 |
Rep 1,512
^^ Yup. It's just the squishy "full tread" effect that you'll get with new tires. Older tires typically have a significantly less amount of tread, thus there is less flex in the actual tread and a more crisp response and turn in. The tires will get better with wear.
Tire Rack has some good info here: http://www.tirerack.com/tires/tirete...e.jsp?techid=5 |
06-03-2011, 01:08 PM | #5 |
Rep 7,653
I am not too sure what size you got but sometimes playing with tire pressure helps too. the rear pressure seems quite high. too high of a pressure decreases effective contact patch sometimes. the pressure also gets affected with driving, so maybe take that down a notch and see how that feels. my 2 cents
06-03-2011, 01:24 PM | #6 |
Crazy Russian Bastard
30
Rep 819
Tire is still new so give it time to break in.
When the car has sat in the garage for few hours and cooled off. Check the tire pressure, it should be 34 PSI all around. Thats a good starting point.
B
M W |
06-03-2011, 01:30 PM | #7 |
Rep 12
Signes, Julius: I went for the stock dimensions, i.e 245/35/19 and 265/35/19.
Julius: Ok, my initial thought was to actually increase the pressure to tighten things up... Maybe you guys are right about the full thread. My PS2:s were completely worn out. However, I expected the AD08 being so much stiffer "by design" as the difference would be smaller! I wouldn't have whine if I'd put on new PS2:s. |
06-04-2011, 10:52 PM | #10 |
octane chick
81
Rep 1,187
Drives: ex-M
I love my Yokohamas! I got 255/35R19 and 275/35R19. Very sticky on the track. (Definitely want to break them in first.)
06-18-2011, 03:48 AM | #11 |
Rep 11
So over all Yokohamas and P2s which would be the better choice.....I heard the P2s have a lot of popularity ive been hearing about just them for jeez! I dont even know how long. But can I get some opinions.
06-18-2011, 06:03 AM | #12 | |
Rep 751
Your question, I think, is which tire is recommended between the PS2 and AD08. I think the PS2 is the better street tire, with more compliant ride and better wet traction, and quieter. The AD08 is stiffer, with better turn in and better dry traction. This has been my experience with these tires. I just installed a set of the new PSS, and it seems to be a very good tire also. |
06-18-2011, 12:48 PM | #13 |
Rep 340
If you're mainly going to be street driving and you want comfort, performance, and longevity I'd look into the new Michelin PSS.
However, if you're going to be tracking your car semi-often and want a tire that you can drive on the streets as well I'd get the AD08s. I don't think you can go wrong with either. If you're not going to be hitting up the track I'd get the PSS. |
06-18-2011, 10:20 PM | #14 |
Track Duty
270
Rep 2,467
Ad08 is a wonderful tire. You need to drive on them a bit to get ride of the outer layer. Once you get to the real rubber and heat up the tires they are amazing. I don't think street driving will really bring out the true potential of the tire however at the track, they will shine.
06-18-2011, 10:23 PM | #15 | |
Rep 3,246
mods: track ready stuff
