BPM
      11-05-2013, 08:52 PM   #1
ccondo
ccondo's Avatar
161
Drives: 2017 BMW M4 - Ferrari Red
Question piston spreader tool
I purchased a set of stop tech BBKs and I need to switch the track pads off the brakes to the street pads. I have the car lifted up and the top off the BBK but now I need a way to compress the pistons so I can get the pads out.
I would like something that will not mess up the finish of the BBK etc.
I have seen some people say C clamps but they look like they are going to scratch things up. I also found this:
http://www.zeckhausen.com/Tools/cali...n_spreader.htm
But that is a bit expensive and very large. I was hoping for something smaller that I could easily get in my car so I could switch pads at the track etc.
Any ideas?
      11-05-2013, 09:41 PM   #2
ydoc
Drives: 2017 F87 M2
This one available on Amazon works fine and is a lot better deal at $46.
http://www.amazon.com/Lisle-29100-Qu...sim_sbs_auto_2
      11-05-2013, 10:14 PM   #3
okusa
okusa's Avatar
Drives: 2011.75 E90 M3 - SSII
I've used that big expensive one a few times with my AP BBK and I would not recommend spending the money. It is definitely helpful but I still end up having to use my fingers for the final push on each piston. The one on Amazon looks promising though.
      11-05-2013, 10:44 PM   #4
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
+1
I use it with the pads attached on the brembo six piston front. Otherwise it is not wide enough.
      11-06-2013, 12:11 AM   #5
White 13
Drives: A 2013 Alpine White E92
I recently got an add from ECS tuning for a compression tool. Might check them to see if theirs would work. Not too expensive.
Sorry, link got too difficult to add here.
      11-06-2013, 12:13 AM   #6
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
i use lisle pad spreader. think model is 29100 but not sure. works great.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      11-06-2013, 06:43 AM   #7
MCPilot
MCPilot's Avatar
Drives: 2013 E92 M3
the Girodisc tool works great, but you need to grind the edges to get it to fit easily into ST60 Caliper.
      11-06-2013, 07:37 AM   #8
mid-corner fun
Drives: F80 M3, '22 X3MC
+1 works really well with the ST40 BBK. There was an earlier post about how to push all 6 pistons on the ST60 with this tool, if you do a search it'll come up.
      11-06-2013, 09:37 PM   #9
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Excellent tool! We use it daily at the shop.
      11-06-2013, 10:18 PM   #10
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
thing is awesome. works perfect. pad changes are so damn easy with that stoptech bridge also.
      11-07-2013, 11:26 AM   #11
BimmerRob08
BimmerRob08's Avatar
Drives: 2008 M3, Space Gray
OP, you don't have to waste time ordering a part. What I used is this;
Cut a 1" square of card board or large enough for the surface of the C-clamp. That cardboard goes between the finish of the caliper (outside) and the clamp head goes on the brake pad. Turn slowley and make sure you don't slip off. I apply the pressure at two points of my AP pads so in order to compress all three pistons equaly. I open the brake reservor just incase to release the pressure. Never scuffs up the paint of the calipers. Easy.
But if your going to be doing this alot, then that tool is perfect. I'm thinkng of getting it now.
      12-02-2013, 11:02 PM   #12
ccondo
ccondo's Avatar
161
The tool from amazon worked great. One piece of advice to others - when spreading the pistons, do it with the pads still on.
      12-02-2013, 11:45 PM   #13
dagolfpro
dagolfpro's Avatar
Taiwan
248
Drives: 2011 E90 M3
Totally agree. I changed mine with the tool that I borrowed from a friend. If I changed my pads as much as he does, I would get one for myself. Yes, spread with pads still on.
2011.75 E90 AW | DCT | ZCP | ZCV | ZCW | ZP2 | Prem Sound | Moonroof | BMW Apps |
Mods List: Evolve Exhaust | M Perf Steering Wheel | Tint | Lux | Hardwired V1 | KW V3 | Volshlag CP | Brembo BBK | BBS FI | Yokohama AD08 R| Schroth 4 Point Harness | Challenge GT Diffuser | OEM GTS Wing| GTS Lip| I lied earlier, I wasn't done with mod, but I swear, I'm done now, no more mods...
      12-03-2013, 12:05 AM   #14
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
I use my hands haha.
      12-03-2013, 08:03 PM   #15
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
that's designed to spread with the pads on. it's a great tool and I'll take full credit for creating its official name..."the whore spreader".
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      12-12-2013, 12:13 AM   #16
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
hmmm and i get in trouble!
