      05-27-2011, 06:38 AM   #1
anduaox
Drives: E90 330xd
supersprint race exhaust
i just mounted the supersprint race exhaust on my m3 e92 and i dont know how to put mount the 4 sensors on the exhaust. 2 are in the same place before the cat but the other 2 are to far behind and they dont have enought wire. can anyone help me ?
      05-27-2011, 06:49 AM   #2
z00m
z00m's Avatar
37
Drives: E92 m3
Thinking about the same set up. Also interested
Are you going to use it without ECU tune? if so would be nice to hear about the CEL, if there where any problems after some time
As I understand we are talking about this catless part
      05-27-2011, 08:22 AM   #3
anduaox
Drives: E90 330xd
i have rear holes for the sensors after the xpipe. so i have to move the sensors
      05-27-2011, 02:05 PM   #4
M-Maika
M-Maika's Avatar
Portugal
11
Drives: M3 E92 AW
2008 BMW M3 E92  [10.00]
You have to do a wire extension.
Be sure not to cross any wire and use a wire with same thickness. A bit of tin solder and some heat shrink tube should do the trick.
At least is what i did and is working like a charm.
Beware to pass the extension far away from the exhaust tube, i did pass the wire extension under the aluminum heat protection to avoid damage because of heat generated.
Hope this helps.
Best Regards,
Maika
M3 E92 M-DKG and all the options available.
Forum BMW Portugal: http://www.forumbmwportugal.com
