11-06-2019, 12:01 PM | #1 |
Rep 194
Test pipe w/ Megan exhaust ?
Hello everyone
As much as I know this topic has been beaten over the head millions of times, I’d like to reopen the conversation. Current setup: car is 100% stock except Megan supreme ultimo muffler. It does sound slightly louder over stock but still not filling that void for me. I’ve considered MS X pipe but just don’t want to spend 2K on the setup. I began to look into test pipes instead. I’ve watched a ton of videos with this Megan exhaust/ test pipe setup. It’s tough to tell what your getting by watching YouTube videos. I was utterly disappointed by the exhaust alone as it was almost close to being stock. Here’s a few questions about this: 1) dB of Megan exhaust vs Megan exhaust with test pipes?( not sure if anyone did a sound test or comparison video back to back) 2) how much of a difference is adding the test pipes to the existing Megan muffler?( noticeable power? Noticeable sound?) 3) what test pipe do you recommend and why? 4) did you need a dyno tune after test pipe install or does the simple plug and play software all you need to experience performance gains and removal of SES light. 5) is there noticeable backfiring? Burble? Or is that related to X pipe Thank you in advance for any input |
11-06-2019, 12:06 PM | #2 |
Rep 265
1) Not sure as to how loud it would be either way since I don't own the exhaust, but I have a CNT with test pipes which is similar and boy is it LOUD.
2) You'll notice a sizable difference. Test pipes will always allow for better flow thus giving you more noise 3) Turner. Because I have them. There honestly isn't much of a difference in test pipes. 4) Go to Mike at BPM for a tune. You'll get hooked up and you wont need to worry about your light. Plus you'll have a noticeable performance increase. 5) I can't speak for the Megan on backfire, but again - mine is similar and has SOME backfire/burble, but not a lot.
11-06-2019, 12:39 PM | #3 |
B.E.
444
Rep 761
Here's a video of my Megan + test pipes from back in the day. Keeping the secondary cats on definitely helps keep the smell down if that bothers you.
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
11-06-2019, 11:32 PM | #4 |
Rep 194
Thank you for some input. That video essentially sounds the same as all the other videos online posted.
Yes the test pipes all seem to be the same considering there’s not much going on. I believe my issue is that I have no idea what my car sounds like from behind since I do not let anyone drive it but I may need to. The v8 is completely overpowering inside the cabin. Also, to go see Mike at BPM, they are in LA. So I’d be doing the plug and play tune they offer I guess for $899. Not sure if that’s after being hooked up or is that retail. Based on their website, they have a claim of 430rwhp after removing primary cats, is that a true number since these cars come with Only about 350rwhp? |
11-07-2019, 12:46 AM | #5 |
Rep 458
https://www.m3post.com/forums/showthread.php?t=1635216
Self-plug but you could consider a cutout setup if noise is a concern. I get straight pipe when I want it and quiet when I don't. Perfect for driving the gf around, or if I have guests. Test pipes are good for 20whp, tune is good for 10-12 at the wheels, intake is good for another 10, and pulleys are good for 8. That's full bolt on. It'll bring most M3s to about 390 as there are diminishing returns to stacking everything. Full carbon plenum, long tube headers, and cams will bring you to 410. Those are all about $2000 each. Rogue TPs and Alex@Alpine for a tune Stock dynos at about 350 if the compression is healthy and on the newest software. |
11-07-2019, 02:38 AM | #6 | |
B.E.
444
Rep 761
11-07-2019, 07:26 AM | #7 | |
Rep 194
I’m also seeing many members either went with BPM or Evolve. |
11-07-2019, 09:14 AM | #8 | |
Rep 3,976
Dave Last edited by Dave07997S; 11-07-2019 at 09:24 AM.. |
11-07-2019, 11:15 AM | #9 | |
Rep 194
Before you added test pipes with exhaust only, were you disappointed ? Because I was very disappointed. All I’ve noticed is when the cars RPMs are dropping to the lower range that I can feel a slight drone which is the only thing that lets me remember I have an aftermarket exhaust. After test pipe, did you get a noticeable difference? |
11-07-2019, 12:25 PM | #10 |
B.E.
444
Rep 761
For the record, I never had Megan by itself. It went on at the same time as test pipes, and is still probably one of my favorite setups for this car. Quiet when you need to be, loud when you get on it, and great all around sound
11-07-2019, 04:38 PM | #11 |
Rep 194
Understood. I guess now it’s down to choosing either Evolve or BPM tune. There’s a $150 delta in between. Not sure why considering both give same results
11-07-2019, 07:58 PM | #12 |
Rep 201
11-07-2019, 08:37 PM | #13 |
Rep 194
Good point. I don’t remember seeing this tune help anyone unless your stock. I don’t see anything for cars that are missed
I do see they are at a more reasonable price point vs Evolve and BPM Last edited by E46tknv; 11-07-2019 at 08:43 PM.. |
11-13-2019, 09:36 AM | #14 |
Rep 290
ive had three different setups using the megan exhaust on 2 different E92's:
Megan mufflers only Megan mufflers with MS test pipes Current: Megan mufflers with Bimmerworld resonated x-pipe my favorite of them all was definitely the muffler with test pipes. I didnt hear any rasps and as others have said, for the price and the compliments I used to get, you cant beat it. Currently the bimmerworld X-pipe has a little too much rasp for my liking at the lower RPMs. But its currently on the car, and I wanted a little more power so it'll probably stay on until I get really really tired of it. to answer your questions 1) dB of Megan exhaust vs Megan exhaust with test pipes?( not sure if anyone did a sound test or comparison video back to back) Naturally youll hear an increase in sound, it is noticeable but nothing too loud im my opinion 2) how much of a difference is adding the test pipes to the existing Megan muffler?( noticeable power? Noticeable sound?) both noticeable power and sound, but again not much. 3) what test pipe do you recommend and why? MS because ive had them before. Most if not all branded test pipes are the same if im not mistaken 4) did you need a dyno tune after test pipe install or does the simple plug and play software all you need to experience performance gains and removal of SES light. didnt do a dyno or a tune but yes the a tune will take care of the gains and light. Ill probably be getting a BPM tune down the road. 5) is there noticeable backfiring? Burble? Or is that related to X pipe i didnt notice any, even with the X pipe i have now, i think thats more tune related. I would look for a used MS x pipe. they usually pop up around here for about 700-800 bucks. thatll be my next x-pipe to try out eventually |
11-13-2019, 11:04 AM | #15 |
Rep 194
MS x pipe is what I plan for down the road but looking for alternative options that can give me that sound increase. I didn’t want to go forward spending $1000 on the X pipe and tune. I’ll try the test pipes with tune first, and then report back. If I feel it’s not enough, I’ll move forward with MS X pipe.
