09-27-2010, 01:17 PM | #1 |
Rep 5,695
▀▄ eas | Macht Schnell - Competition Wheel Spacer kits for BMW
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance. Here is a recent article in European car: -An additional online article in European car's Tech section: http://www.europeancarweb.com/tech/e...gineering.html -Macht Schnell spacer reference thread with photos and spec details: http://www.m3post.com/forums/showthr...schnell+spacer -Macht Schnell DIY on how to properly install spacers: http://www.m3post.com/forums/showthread.php?t=272915 A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders. Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts in black OEM finish. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US. Competition Wheel Spacer kit Features: - Machined from 6061-T6 aerospace aluminum - Chamfered edges allows installation & removal quick and easy - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included black extended-length corrosion-resistant wheel fasteners Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm http://www.europeanautosource.com/pr...oducts_id=2197 Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm http://www.europeanautosource.com/pr...oducts_id=2198 Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm http://www.europeanautosource.com/pr...oducts_id=2199 Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm http://www.europeanautosource.com/pr...oducts_id=2200 Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm http://www.europeanautosource.com/pr...oducts_id=2201 Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm http://www.europeanautosource.com/pr...oducts_id=2202 Models Supported: 2008+ 1-series 1992+ 3-series, including M3 (e36, e46, e90, e92) 2004+ 5-series, including M5 (e60) 2005+ 6-series, including M6 (e63, e64) 2004+ X3 (e83) 2000+ X5 (e53, e70) 2003+ Z4, including M-Roadster/Coupe (e85) 2001-2003 Z8 1996-2002 Z3, including M-Roadster/Coupe All sizes are currently in stock and available for immediate shipment. |
09-27-2010, 10:24 PM | #2 |
Rep 270
Please PM recommended setup for stock 19s with stock suspension shipped to 20814. Thanks.
18 Alpine White F85 X5M // 03 Titanium Silver E39 M5 // 13 White Porsche 991 911 Carrera
(Gone but not forgotten) 15 Mineral White Metallic F15 X5 XDrive50i M Sport // 09 Melbourne Red E92 M3 // 08 Space Gray E70 X5 4.8i // 07 Black Sapphire Metallic E86 Z4 M Coupe |
09-28-2010, 11:06 AM | #3 |
Rep 4,048
10-12-2010, 05:19 PM | #5 |
Rep 835
Also pm me your choice for 2011 m3 coupe with oem 19's and stock height. Also pm me about installing to prevent vibrations. And is alignment is needed after?
many thanks |
10-12-2010, 06:13 PM | #6 |
Rep 5,695
11-15-2010, 03:01 PM | #14 |
Rep 5,695
11-17-2010, 01:31 AM | #15 |
Rep 207
Would love to get some info on what the recommended setup is for a stock 2011 M3 Coupe w/competition package is? I may also buy some wheels from you but would stick with the OEM size so the spacers should work before and after.
Thanks for any info! -Shane |
11-17-2010, 11:31 AM | #16 |
Rep 5,695
Hi Shane, I'll send you over a PM on the recommended setup for the ZCP
12-01-2010, 06:43 PM | #20 |
Rep 5,695
12-04-2010, 02:51 PM | #21 |
In Reno we don't dial 911 :)
Rep 25
Hi David,
This is my very first post. What spacers would you recommend for a OEM 19 wheels and OEM PS2 tires and Dinan Stage 3 suspension for a 2008 E90. This is a daily driver and intend to do track and auto x next season. Also for those seeking the safest setup for track use exceeding 125 mph are spacers really advised? And if so, what are the options for lock bolts instead of extended lugs? Much thanks! |
12-06-2010, 11:47 AM | #22 | |
Rep 5,695
There is an option to purchase RAD lock bolts, which comes in a set of four, when you place the order for Macht Schnell spacers. |
