European Auto Source
      11-24-2017, 01:37 PM   #1
zack3110
Drives: BMW 325ci 2006
Buying a 2006 E46 325ci
Hi All, This is my first post in this forum so please bear with me. I am purchasing a BMW 325ci (2006 model) from a family relative and has 99k miles on it. So I wanted to know what all should I look out for (maintenance wise) at this point.
They've done a PPI, replaced the tie rod end in front engine gasket, drive belt, front brake pads, one tire, and oil seal. Filled up all fluids (oil, brake, transmission and power steering) and did the wheel alignment.
This would be my first car, so any help would be appreciated. Thanks in advance
      11-24-2017, 03:14 PM   #2
Chihuahua
Chihuahua's Avatar
638
Drives: BMW
Check the rear floor where the subframe bolts to it for tearing. Other than that it's typical E46 stuff. They're very solid cars, good luck with it.
      11-24-2017, 03:23 PM   #3
zack3110
Thanks for you reply.
Newbie question, How frequent should I change the fluids to maintain a car of this age?
      11-25-2017, 11:43 AM   #4
zack3110
I found this maintenance schedule from this link https://www.cargurus.com/Cars/Discus...37551_ds515157. What do you guys think about this?
Change oil every 6K miles
Change Differential Fluid every 30K miles
Replace the following every 30K miles: Water Pump, Thermostat, Thermostat Housing, AC Belt, Alternator Belt, and Idler Pulley
Change Radiator coolant every 50K miles
Replace Radiator and Expansion Tank at 90K
Replace Timing Chain Tensioner at 100K miles
Change Brake Fluid every two years
      11-25-2017, 11:57 AM   #5
last1left
last1left's Avatar
72
Drives: e92 M3
That's about right I have a ZHP and the weaknesses of these cars are the cooling system. Nice solid cars the e46's are
      11-28-2017, 12:33 PM   #6
CTinline-six
Winning
CTinline-six's Avatar
Drives: 2000 Jeep XJ, 2006 BMW 325xi
Originally Posted by MaximusJ View Post
Just sold my 325; so I think I can help. I’d make sure the link kits are in shape; not very expensive, but one seems to pop every 20k or so miles. Coil packs are also something to look into. You need to make sure none misfires. Then I would check for water pump and thermostat. If they were not changed, they will need to be done very shortly and this can reach 4 figures. And if they were not, thats something I’d seriously consider while dealing the price.
I believe you are talking about the E90 2006 325i in your signature, not the E46 325CI which the OP is looking at.
Regardless, the cooling system is important. Luckily they are a bit cheaper to replace on an E46 than on an E90.
Josh
      11-28-2017, 12:52 PM   #7
lennyf
lennyf's Avatar
56
Drives: 2017 BMW M240i
My son has an 06 325Ci.
Got it with 60k miles last year.
Replaced radiator, expansion tank,serpentine belt, new tension pulleys, ignition chamber.
Car runs great !!!
PS i have a 2017 M240i and I love driving the E46.
Hydraulic steering rocks !!
      11-28-2017, 02:29 PM   #8
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Car runs great !!!
I DD an M235 convertible and Dad still has his 2006 330 - with 35k miles on it. Definite +/- to each but actually a very nice pairing.
2016 M235 xDrive Convertible • BSM / CR • BBS SR • Dinan Stage 2 with CAI • Active Autowerke IC• MPE • Bavsound Stage 2
2016 328 xDrive Sport Wagon • BSM / SB • Dinan Stage 1 • AFE Scoop • Bavsound Stage 2
2014 328i xDrive • Bavsound Stage 1
2006 330ci • Bone Stock
      11-29-2017, 04:07 PM   #9
Chihuahua
Chihuahua's Avatar
638
Drives: BMW
Agree with all of this except for the water pump and belt intervals, 30K miles is a bit premature IMO. If it's never had a water pump before and/or you can't confirm it, I'd replace it, thermostat, and drive belts and invest in an aluminum water pump pulley when you do (~$30).
good luck with the car, the E46 platform is one of the best BMW ever produced.
      12-06-2017, 11:13 PM   #10
marshak
Drives: 2013 528xi
^ Agreed. I had my 2000 323i for almost 200k mi. The water pumps with the metal impeller are the only way to go. I would also see if the CVV and hoses have been replaced. They get brittle over time and can cause all sorts of odd error codes. Most things on an E46 are an easy DIY job. Make sure to get a Bentley manual as well
      12-06-2017, 11:24 PM   #11
dauble2k5
dauble2k5's Avatar
22
Drives: 2011 VR E92 335i, 6MT
2011 BMW 335i  [0.00]
I came from an '04 325Ci. The only big ticket items I ever had problems with was the cooling system. I replaced the radiator, WP and t-stat around 80k and sold it with 144k and never had any other issues. It was a relatively low-maintenance car. Man, I miss it.
Might not hurt for a suspension refresh, either. New shocks and bushings will make it feel brand new.
Tags
2006, 325ci, used bmw
Search this Thread:
Advanced Search
