08-02-2019, 02:18 PM | #1 |
Rep 504
Is 0-60mph time a good indicator of which car will be faster?
I don't speed but those times where car has to merge from street light , it is kind of fun and exciting per say. I drive a regular x3 that has like 248 hp and goes around 6 seconds 0-60 which is pretty slow but for me it's fast lol During these situtions, I'll glance if it something i can beat when merging and other times I realize I don't budge if its like some tesla etc (which they don't drive fast anyways). Anyways my question is the 0-60 seconds usually determine which is faster (seems automatic cars not much input is needed for shifting gears etc as in manual).
Other question is , I was about to get the acura mdx and that has 295 hp but 0-60 in 6.3 . I'm sure it weight little more then the x3 but not sure why it's so called tad bit slower? is this where german engineering takes over? |
08-02-2019, 02:28 PM | #2 | |
Rep 4,210
I am usually first away from a light and never have to depress my accelerator very far. I personally think 0-60 is a bad car measure. Anyone can pour a lot of HP into a car and claim a fast 0-60 rating. But it is more important how it handles, etc. |
nakamuru136.50 |
08-02-2019, 02:31 PM | #3 | ||
Rep 254
Torque, gearing, shift times, drivetrain, tires, etc. all play a part |
08-02-2019, 02:33 PM | #4 |
Rep 124
a lot of factors will go into the 0-60 and depends on what you mean by faster. I think 0-60 is a decent indicator but more knowledgeable members will chime in. The metrics I hear a lot of are 0-60 and 60-130 for mph and then for distance 1/4 mile and 60' times.
They are all correlated to an extent. I think 60 ft times might be a better indicator for you since you are wondering from a stoplight who might win on a merge...haha. This depends on your launching, traction and power. if you are talking on the highway and coming up on a merge then 60-130mph might be more important. |
08-02-2019, 02:41 PM | #5 | |
Rep 504
But yes I wouldn't do any pedal to metal doing turns on this car and just merging or maybe needed lane change. Other then that my driving record is clean so I must keep it that way lol |
08-02-2019, 02:44 PM | #6 | |||
Rep 504
My home is rear this merge traffic light and usually have lot of times to have some fun lol (no intersections after traffic light either |
08-02-2019, 02:45 PM | #7 | ||
Rep 504
08-02-2019, 02:47 PM | #8 | |
Rep 124
I like taking off hard from a stoplight and then merging on highways. I really don't drive fast any more (especially as I've gotten older) but do still enjoy the thrill of accelerating hard on occasion. Guess this is why I rolled the dice and got a 550 instead of the more reliable and fuel efficient 535 (and got the BMS stage 1).
08-02-2019, 02:51 PM | #9 |
Rep 124
Not sure why they do it, but it is pretty well known. Even the 550 I have is supposed to have 480 ft/lb torque at the crank but several folks have seen 450ish at the wheels. Then I think the new Z4 dynoed higher than what was advertised by BMW.
eluded3041.50 |
08-02-2019, 03:24 PM | #10 | |
Rep 4,210
https://carbuzz.com/news/the-toyota-...habit-from-bmw https://www.***********.com/content....M5-and-E70-X5M Etc. Etc. |
08-02-2019, 03:29 PM | #11 |
Rep 1,480
Drives: 2022 M440xi GC
I do know that nobody programs transmissions like BMW (in the "normal" car world). Be it ZF or Aisin, the job they do is incredible. A RAV4 has an Aisin 8 speed and 200hp and it can't get out of its own way and Toyota programmed it like a diesel to keep mpg up so it is a struggle to rev out past 2k unless you floor it but my X2 can drop the hammer pretty hard.
That plays a big part. I do think on the street that rolling acceleration is more important than 0-60 and again, the transmission programming plays heavily there. |
clee1982797.50 |
08-02-2019, 03:31 PM | #12 | ||
Rep 504
08-02-2019, 04:04 PM | #13 | |
Rep 966
clee1982797.50 |
08-02-2019, 04:14 PM | #14 | |
#buildnotbought
10855
Rep 4,893
Usually the used dyno in those tests make bigger differences, just for laughs and giggles google results on same cars in same conditions between for instance dynojet (the tuners dyno, gives extremely high HP's) compared to say a mustang dyno. That difference alone is easily 10-20%
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
08-02-2019, 07:23 PM | #15 |
Rep 1,850
If you want fast for cheap get a motorcycle. Even my slow electric bike absolutely smokes my tuned 135i from 0-60. And you never have to wait behind traffic.
08-02-2019, 07:46 PM | #16 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
A lot of lower HP cars can be set up to get a quick 0-60 and then fall on their faces after that and end up having very little top end. It works for the red light rally I guess but would be annoying anywhere else.
08-02-2019, 08:33 PM | #17 | |
Rep 3,470
But, many modern turbo cars do have a rich flat torque curve down around 1500-1700rpm to max rpm, which is fairly unprecedented before the 2000s. Area below the (torque) curve is what makes a car accelerate fast. BMW doesn't "sandbag" hp/tq really, they simply tell you what the hp/tq is at the wheels and don't make a big deal about informing you that it's "at the wheels". It's brilliant from one aspect, because in comparisons they get put up against cars that have the "same" horsepower and always come on top for acceleration.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
08-02-2019, 08:50 PM | #18 | |
Rep 10,120
08-02-2019, 08:54 PM | #19 |
i'm just saying
5739
Rep 2,634
wheel drive, transmission, power to weight determines the 0-100kmh times.. to understand the overall picture better, 0-200kmh is the one i look especially..
all the power figures from factory shows the power on crank.. according to wheel drive and transmission this number is lower on the wheels.. unless its written like whp.. only sandbagging that BMW made in recent years was new M5 comp.. the rest just -/+ numbers on crank.. generally VW sandbags the power figures..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
Delta03117477.50 |
08-02-2019, 08:55 PM | #20 | |
Rep 10,120
08-05-2019, 01:45 PM | #22 |
Rep 124
Found this entertaining and relevant to this thread given how surprised the C&D folks were at the dyno results of the M5:
https://www.msn.com/en-us/autos/rese...ted/ar-AAFk9A9 |
