05-29-2016, 08:55 PM | #1 |
Rep 125
2011 E92 M3 Whining Noise
Hey Everyone,
Please take a look at this video and tell me your thoughts. It sounds like some type of whining noise, watched some Youtube Videos and closest thing i could find was a vacuum line leak noise. Other day, I found my power steering fluids low due to a loud humming noise around 1.5 - 2k RPM, filled it and it doesn't have that sound anymore. However, I have been very paranoid since then and think the sound in this video clip also isn't normal. Any suggestions as to what this may be would be great, thank you!! |
05-29-2016, 11:25 PM | #3 |
Rep 15
I have this EXACT problem with my car. I posted about it here: http://www.m3post.com/forums/showthread.php?t=1197185
Everyone told me it's normal, but it's definitely new and wasn't there before. |
05-30-2016, 12:43 AM | #4 | |
Rep 125
05-30-2016, 08:44 AM | #5 |
Rep 162
Mine seems to be making the same noise, and it always has. In hindsight, I had a bad AC compressor bearing, which was causing noise of sort of the same pitch, but much more pronounced. It was getting stronger with RPM, and was disappearing after the engine is warmed up. Turning the AC on/off didn't make a difference. The dealer charged me around $2.2k for the repair. Good thing, I had a warranty.
05-30-2016, 04:14 PM | #6 |
Rep 1,919
Drives: 2013 E92 M3
Sounds like the timing chains...normal!
05-30-2016, 04:30 PM | #7 |
Rep 4
Drives: 2011 E93 M3
I had the same issue a month ago and had to replace the power steering pump :/ best way to check is to have the car running and open the reservoir to see if the fluid is circulating. If it isn't, then most likely could be the pump. Either or, good luck with it and hopefully is nothing major! ?
05-30-2016, 06:47 PM | #8 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
450
Rep 1,989
Drives: 2011 E92 M3 DCT/ESS 625 kit
Seems normal to me as well. My car sounds the same.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
05-31-2016, 11:45 AM | #9 | |
Rep 125
06-01-2016, 02:24 PM | #10 |
Rep 125
06-01-2016, 02:42 PM | #11 |
Rep 1,919
Drives: 2013 E92 M3
06-01-2016, 03:22 PM | #16 |
Rep 125
