11-10-2008, 09:32 PM | #1 |
Rep 247
6NF Smartphone Integration Pics
I picked up my '09 E90 M3 with 6NF Smartphone Integration tonight and wanted to post pics of the setup in the center console as I don't think I have seen any yet on the forums. My CA says the iPhone 3G cradle isn't available for order yet so unfortunately I can't report on the actual functionality differences 6NF gives you over the "standard" 6FL and bluetooth setup.
There is a dummy plate installed in the center console so I have taken pics both with and without it installed. Pics are at the following link/thread (sorry in advance for the crappy iPhone pics, it was all I had tonight): http://www.m3post.com/forums/showthread.php?t=185267
2009 E90 M3 - Silverstone/Fox Red - M-DCT, CW, PP, TP, 19", Moonroof, Sunshades, PDC, Enhanced Prem Sound, HD Radio, Sat, iPod, Smartphone Integration
11-11-2008, 08:39 AM | #3 |
Rep 247
I'm pretty sure it cannot be retrofitted based on what I have read here on the forums, but I don't have a definitive answer to that.
11-12-2008, 09:52 AM | #4 |
Moderator
7515
Rep 19,368
Thanks a bunch for posting this thread, rmmcdaniel. There have been plenty of others who say they have 6NF equipped '09s, but yours is the first I have seen that shows any evidence of it.
I wonder if this piece is the same physical piece that was previously sold as an phone cradle through BMW accessories? Or maybe it is a new piece. Obviously it is different in its electrical connection somehow since it supports Music playback. But I wonder if that is the only difference or if there are others. |
11-12-2008, 11:32 AM | #5 |
Rep 2,105
What you can see in your center console is called the "base plate". Did that come with your car, or did you purchase it separately?
Visually, it looks the same as the base plate used in the 08's, minus the words TCU, stamped on the plate .... |
11-12-2008, 11:40 AM | #6 |
Moderator
7515
Rep 19,368
apw2607, are you as confused as I am by all this?
I believe you've been following the new 6NF developments as closely as me if I recall, and am I crazy, or did we not see multiple people claim they have 6NF equipped in their cars, only to have absolutely no visual evidence? As far as I know, rmcd is the first one to actually show signs that 6NF gets you anything other than some potentially different wiring inside the center console that will allow you to get music playback through some mythically rumored new type of cradle adapter (or base plate adapter, whatever one wants to call it). |
11-12-2008, 11:45 AM | #7 |
Rep 2,105
yea. thats why i asked the question. What rmmcdaniel shows it sort of what i expected to see when folks first started to get their 6NF equipped cars.
That base plate is unique to the car type Once you have the base plate installed, you then buy a cradle for the phone, or smart phone you have Whats interesting is ... the base plate doesnt look any different from the 08 base plate on quick inspection. However, i'm sure the pinouts are very different and include the necessary connectivity to allow the iphone to be used as a 6FL device. |
11-12-2008, 12:01 PM | #8 | |
Moderator
7515
Rep 19,368
But what do you mean by the baseplate being unique to the car type? Do you mean E90 vs. E92 vs E93, etc? Or do you mean 2008 vs. 2009? As you assert, there must be some difference in the wiring harness that connects to the base plate (which I have been calling a cradle in most of these discussions, usually, I think). But what is that really, other than some wires? My big concern in all of this, being that I have an '08, was to figure some way to get an iPhone 3G cradle adapter (which I believe you may be calling the cradle itself, but its just a difference in our wording) into my car. There have been claims made that the 3G adapter will only work in 2009+ cars. But here we are seeing that as far as the physical shape of the base cradle piece is concerned, its really very similar if not identical to the currently available accessory. This gives me reason to believe that, when (and if) a 3G cradle appears, it should work both in newer cars with 6NF or older cars without it. |
11-12-2008, 02:57 PM | #9 |
Rep 247
I'm going to try to cover all the outstanding points at once...
"I wonder if this piece is the same physical piece that was previously sold as an phone cradle through BMW accessories? Or maybe it is a new piece. Obviously it is different in its electrical connection somehow since it supports Music playback. But I wonder if that is the only difference or if there are others." I agree it physically looks just like the base plate sold previously but I have never seen the previous one live so I'm just basing that on pictures I've seen on websites. Whether or not it is the same, I also agree that the big difference in 6NF is the internal wiring to allow music playback. "What you can see in your center console is called the "base plate"." Yes, I know it is called a base plate. When I used the term "dummy plate" I was trying to discern between two of the pictures I took, one of the "naked" base plate and another that had a second piece that was kind of a "base plate connection cover" (i.e. dummy plate) snapped into the baseplate. It's only purpose appears to be to protect the connector used between the base plate and phone cradle. "Did that come with your car, or did you purchase it separately?" It came with my car from the factory. The only thing the dealer did was install the alarm and floor mats. "Visually, it looks the same as the base plate used in the 08's, minus the words TCU, stamped on the plate ...." Agreed. "yea. thats why i asked the question. What rmmcdaniel shows it sort of what i expected to see when folks first started to get their 6NF equipped cars." I completely agree with both of you. I have been watching the threads/posts too and didn't want to call anyone out since I didn't have my car yet (thus no physical evidence to call them out on), but I have had serious doubts as to whether the others that claim to have 6NF really have it. As you know, when 6NF was announced it was stated that it was only available beginning with Oct production. At that time I already had a production number with a confirmed build week in Sep. I knew I wanted 6NF and immediately called my CA to add it to my order. That "action" resulted in a new production number being assigned to my order with an Oct build week. What I don't know is if the BMW order system issued the new production number based on adding 6NF to my order, or if my dealer "manually" switched my order to an October allocation because they knew 6NF was only available starting with Oct builds. The reason I bring this up is that many of the other posts from people who said they added 6NF to their order kept the same production numbers and Sep build weeks, and are the same people who have produced pics of their cars with no base plate installed. So I have doubts that they really have 6NF. One last note on this is that my order did end up moving up and production was completed the last full week of September. The worst part about all of this is that the iPhone 3G cradle hasn't been released yet so I'm in no better position than you guys using 6FL/Bluetooth with the stupid "this device is not compatible" message! That does bring up something I've been very curious about... Whether 6NF provides integrated phone functionality withOUT having to link the phone to the car via Bluetooth. I'm (obviously) hoping that is the case, but since nobody knows what this thing really does at this point it's pure speculation.
11-12-2008, 05:06 PM | #10 |
Rep 2,105
I looked at your photos again, and compared it to my 08 base plate. I think I've spotted the difference. You base plate has two additional coaxial connector shown here. On the 08, these are simply plastic stubs.
I think this means ... that you might be able to still use the old iphone cradle in a 09 base plate ... however it would only give you charging and external antenna functionality. Not music functionality. In answer to your other query, telephone connectivity with the iphone is done through bluetooth ... and thats it. |
11-13-2008, 08:02 AM | #11 | |||
Moderator
7515
Rep 19,368
Thanks a bunch for the replies, rm.
11-13-2008, 08:11 AM | #12 | |
Moderator
7515
Rep 19,368
As I've said a few times before, my big curiousity with this new option (and its hardware) is whether or not we pre-6NF (with 6FL) people can somehow use it in an unsupported fashion in order to get music playback in the cradle. Your post here makes me even more optimistic that this should be possible. I remain convinced that, with proper research, it should be possible to build a custom wiring harness with proper leads connected, such that the 6FL cable could be used to provide music playback from the phone while it is in the cradle. This won't be quite as cool as 6NF since we'll still need the 6FL cable, and won't have the USB port free for a second device. But this is a minor thing in my opinion. |
11-13-2008, 12:21 PM | #14 | |
Moderator
7515
Rep 19,368
If nothing else, I don't think it will be hard in a MY2009 since, in theory, they will have any new non-6NF specific hardware (audio/telcom/etc.), whatever that might be, that has changed from MY2008 that makes the addition of the 6NF hardware itself possible. For a MY2008, depending on any such differences, it might be either too difficult, too expensive, or both. For example, if you have to replace the whole radio in a MY2008, its probably not worth it. That's why I have been thinking about the possibility of a hack moreso than actually trying to retrofit it as a whole. But hopefully you are right, and we can just order the parts and hook it all up. Time will tell. |
02-24-2009, 05:35 PM | #15 | |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
If one has 6FL installed and that 6NF is only a $150 option it does sound like there is not to much in it. More likely a different base plate (as pictured above) and a change in the wiring just underneath the base plate where it couples with the 6FL in the centre console. I cannot see it being a major wiring harness all the way to the iDrive as the cost of $150 does not reflect this. Also to get 6NF you must have 6FL also which means this is the major component. Has any looked under this new base plate to see the difference between the two? and how it wirers in?
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
03-19-2010, 11:35 PM | #16 | |
Rep 23
2009 M3
03-21-2010, 08:47 AM | #17 |
Rep 1,597
I thought that you not only needed the new base plate which has the extra blue wire (usb), but also another cable that joins this blue connector to the USB (6FL) and also carries the audio connection as well.
This cable I thought simply splices in the existing usb & audio that is in the middle compartment, which is already connected to the system. If you install a USB stick into the 6FL it overrides the the usb connection of the base plate because it see's that connection first, the reason it that both are in parallel and will only accept one USB connection at a time. Apparantly it says that in the manual, which means its only a small adapter cable. Wonder if this cable can be seen on a wiring diagram at BMW spare parts?
03-21-2010, 04:24 PM | #18 | |
Rep 23
2009 M3
03-21-2010, 05:55 PM | #19 |
Rep 1,597
Agreed, I think the key is a small interconnect wiring cable from the new backing plate connecting parallel into the 6FL thats in the compartment box between the seats. For $150 the cost reflects it being something simply like new adaptor plate & a small cable?
03-21-2010, 06:29 PM | #20 | |
Rep 13,001
03-22-2010, 09:40 PM | #21 | |
Rep 23
2009 M3
03-23-2010, 07:18 AM | #22 | |
Rep 13,001
