2010 2011 BMW 5 Series Forum F10
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications ExhaustMeister installed on 550 with M5 Mufflers - very cool!
      03-04-2014, 12:41 AM   #1
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
Apologies in advance for not taking pictures/video of the install process, but it was so quick and easy that I didn't think it was warranted.
Summary: The ExhaustMeister is a control box that intercepts the connector/controller of the oem exhaust flaps. This works on the stock 550 exhaust, as well as those of us running M5 mufflers who retained the M5 oem vaccum valves. I think it works on other F10 models as well, but not 100% sure. It allows you to control the oem exhaust vaccum valves/flap at your command. It's AWESOME in my opinion.
How it works: The device is remote controller to keep the flaps functioning like OEM (off position) or at the push of a button, forces the flaps on both mufflers open, as if you were on throttle above 3000 RPM or as if you zip tied them open like many of us have (I did previously). At start up, the flaps are in the factory position and open at your command when you push the on button on the remote (there are 2 included for good measure) or on the garage door opener if you program it. This means every time you shut the car off it goes back to the stock position/control.
Convenience/Cool Factor: The device even programs to your garage door opener, if you have 2 open program buttons like I did.
This is the ultimate solution for those who want more sound and don't want the hassle of zip ties which are a pain to put on and sometimes break or slip off.
Price: For $129+shipping you can't go wrong.
Note: I am running M5 Mufflers and a custom x-pipe replacing the center muffler. The difference for my car for sound with the flaps open vs. closed is significant at idle and on throttle. For those of you with stock 550 mufflers, the sound gains from opening the flaps with this or zip ties is negligible in my opinion. For those of you with M5 mufflers but with the oem center muffler, I think this is still probably worth it for that extra sound when you want it.
Install Instructions: Follow the instructions on their site. Very straightforward, took less than 10 minutes. They even have pictures if you need them. Basically pull the trunk carpet back on the left side after removing the clips, disconnect the factory plug, connect the ExhaustMeister plug to the factory connector and the factory wire to the other cable on the ExhaustMeister. Then take the white ground wire and connect it to one of the bolts in the area. I used the one pictured. Leave the blue wire alone, its the antenna. Put the carpet back. That's it. http://www.exhaustmeister.com/instal...-2009-present/
Link to buy: http://www.exhaustmeister.com/
or
http://www.ebay.com/itm/231067201069...witem=&vxp=mtr
I will post better videos and sound clips when it's not 1AM or 12 degrees outside, but for now... ignore the remote in the plastic bag.
      03-04-2014, 12:54 AM   #2
badblack550xi
badblack550xi's Avatar
Drives: F10 550i 2011 F90 2020 COMP
Ordered mine! Install was 2 easy, now I can wake people up on demand.
      03-04-2014, 06:09 PM   #3
scott135i
scott135i's Avatar
Guess nobody cares? Too bad.
      03-04-2014, 08:36 PM   #4
badblack550xi
right!? not a single reply lol.. this is by far the best thing for $115 i bought.
2011 550i RWD 60-130 7.35
      03-04-2014, 08:42 PM   #5
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
I was waiting on your review before I pulled the trigger in this. Not enough 550's with aftermarket exhaust to get a lot of attention.
Having the valves open makes no difference on stock exhaust.
      03-04-2014, 09:11 PM   #6
badblack550xi
time to make it none stock
      03-04-2014, 09:12 PM   #7
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
I've got M5 mufflers on mine now. I have only seen this on the M5s until now. Wasn't sure if it would work on the 550. Looks like I'll be ordering one.
      03-04-2014, 09:34 PM   #8
badblack550xi
Me and Scott both have M5 mufflers.
      03-04-2014, 11:18 PM   #9
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
I will be joinin the '550 with M5 muffs' club soon. To be exact, I'll have the complete M5 Competition Sport exhaust to be exact. The one with the black tips. Should be here by next Friday.
Now I just have to wait until I actually get my car in June/Sept!!
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      03-05-2014, 12:13 AM   #10
CloudVIII
CloudVIII's Avatar
Drives: AW LCI F80///M3
I trust you guys I ordered last night!
      03-05-2014, 08:41 AM   #11
badblack550xi
      03-05-2014, 06:48 PM   #12
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
@scott135i -
I believe you have the M5 mufflers… but still have the rest of the 550 exhaust… except you cut out the center resonator and replaced with x-pipe? Is that how a stock M5 exhaust is set up?
You have stock DP's?
Could you post some driving clips from in-cabin? Flaps open and closed…please?
Thanks.
      03-05-2014, 06:59 PM   #13
HDEddie1
HDEddie1's Avatar
120
Drives: X5 40i, X3M40i, Audi SQ5
Scott does it again!
Great find! Thanks for the detailed report. You've opened up a whole set of options for those that want to mod their exhaust (stock mid pipe, M5 x pipe, or straight thru pipes) while controlling to final sound with just a press of a button (as long as they're using OEM M5/M6 mufflers).
Brilliant!
      03-05-2014, 09:04 PM   #14
scott135i
scott135i's Avatar
Originally Posted by PhilT3
@scott135i -
Thanks.
Yes. M5 mufflers and custom x-pipe replacing the center muffler. All else stock including downpipes.
It's the same setup that the full m5 exhaust has except the m5 downpipes are slightly different, it's 3" throughout with no crush points and it's x-pipe is not as well flowing based on some pictures I've seen of the cross section.
In 2-3 weeks when warmer I'll get cold start clips, warm start clips, and clips while driving both inside and outside the car with flaps each open and closed. Thanks Go Pro HD.
      03-05-2014, 09:06 PM   #15
scott135i
scott135i's Avatar
Brilliant!
Happy to help. The exhaust meister works on all after market mufflers that use the same vacuum flap design and connections as the oem.
      03-05-2014, 10:06 PM   #16
combatbmw
Drives: 20' X3M CP
I love this, diff going to order one when I have my completed system.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
      03-05-2014, 11:30 PM   #17
omer
Drives: M8 GC
Will this work on 535 f10 with full tatinium litespeed exhaust?
      03-06-2014, 09:50 AM   #18
badblack550xi
Does it have vacune flaps?
      03-06-2014, 01:37 PM   #19
combatbmw
Drives: 20' X3M CP
      03-09-2014, 06:11 PM   #20
5fix
Drives: 2020 X5 40i; 2018 m550i
Just installed on my 550ix with stock mufflers. 10 minute install was very easy. Not sure why previous posters say it won't make a difference on stock exhaust. I can tell the difference in the car and outside. I will post a video in a few days. Even if not a huge difference in sound, a fun and relatively inexpensive mod!
      03-09-2014, 07:48 PM   #21
badblack550xi
wtf mine is not shipped yet.........!!!!!!!
      03-09-2014, 07:51 PM   #22
pillpusher84
pillpusher84's Avatar
Drives: 2014 550xi M-Sport Silver
This guy took 2 weeks to ship mine! Once I received it ... it didn't even work!
I'd love to see how you make out once you receive yours. (Maybe even put it in my car to test again if you would be so gracious to oblige ) I wonder if mine were defective ... but I installed correctly, and could hear the unit clicking on and off ... however there was no change in sound. (I have 550xi w/ M5 mufflers - vacuum lines functional & flaps NOT tied open permanently) ... had mine installed at MaximumPSI in Linden based on Scott's recommendation.
Tags
exhaustmeister, flaps, muffler, sound
5post
