      12-29-2014, 01:46 PM   #1
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11462
How to mount shoulder belts on DD car?
I have a E92 M3 which I will start using for the track next year. I am retiring the E46 M from track duty.
One option is to use the stock cloth seats and Quikfits.
A better option is to use the Sparco Ergo halo seats and install a 6 point harness.
I do not want to install a half cage as it's a DD car.
Originally I thought of getting the Challenge harness bar but the people who sell it do not recommend I use it for actual tracking as it's a bit flimsy.
So, how can I mount the shoulder harnesses?
I track with BMWCCA and PCA, so any solution has to be compatible with these clubs.
Thanks for the help
      12-29-2014, 09:09 PM   #2
bigjae1976
bigjae1976's Avatar
1570
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Why can you use the quick fits and a fixed seat? The QFs will work so long as you retain the OE belt tensioner.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      12-30-2014, 12:05 PM   #3
SYT_Shadow
SYT_Shadow's Avatar
11462
I'm concerned this won't be accepted by PCA. It is an option and I know it's what you run and I may not have any other choice.
      12-30-2014, 08:21 PM   #4
Estoril Blue
Drives: 2006 M3
You have reason to be concerned about PCA and BMWCCA - at least most of the chapters that I go out with.
Pull their Tech Inspection sheets and see what they say. If they aren't detailed enough - email a specific question to their Chief of DE Tech.
Be sure to ask about harnesses in cars without at least a roll bar. And ask about whether you need to leave the original 3 point belts in if you have no roll protection. And remember the oft-used "same protection" rule.
      03-23-2015, 05:54 PM   #5
SYT_Shadow
SYT_Shadow's Avatar
11462
Thread resurrection
Check this out
http://www.bkauto.com/R_1203_BMW_E92...r_p/r-1203.htm
It seems like someone has finally made a TRUE bolt in harness bar for track use! And this one is DOT certified!
I have checked with the 4 PCA groups I run with and this is fully permitted. Obviously they mention it's best to have a roll cage etc etc, which I'm fine with.
I wish I had found this out earlier. Well, next year this is clearly my future!
      03-24-2015, 05:35 PM   #6
nicksm3
nicksm3's Avatar
Drives: e92 m3 Competition
Originally Posted by SYT_Shadow
Thread resurrection
Check this out
Wow, curious to see what it looks like set up.
      03-25-2015, 08:15 AM   #7
SYT_Shadow
SYT_Shadow's Avatar
11462
I'll post some pics next year when I get this.
Finally there is a way to use track/race seats, 6pt harnesses and not do any permanent modifications to the car!
      04-07-2015, 11:32 AM   #8
dmw16
Drives: 2005 ///M3
I am not a big fan of that approach, especially with stock seats. With stock seats the harnesses could fall off the shoulders (compared to a fixed back seat with belt eyelets).
At the very least I think a half cage is appropriate when using harnesses and a fixed seat. The risk of spinal compression in a roll over is minimal, but roll overs do happen at track days...look at the Audi @ Buttonwillow (?) a few weeks back...
Generally Brey Krause offers well thought about products, but I don't like harness bars.
<steps down from soap box>
      04-07-2015, 11:46 AM   #9
SYT_Shadow
SYT_Shadow's Avatar
11462
Just to clarify: this will be used with fixed seats. 6pts with oem seats don't make much sense
      04-07-2015, 11:58 AM   #10
dmw16
Drives: 2005 ///M3
I don't think that makes it any safer from a roll over standpoint, but at least the harnesses are guided.
      04-07-2015, 11:59 AM   #11
SYT_Shadow
SYT_Shadow's Avatar
11462
Correct rollover safety is a step under bolted in half cages which are considered heresy by many
      05-13-2015, 11:37 AM   #12
KillrM3
KillrM3's Avatar
South Africa
90
Drives: 16 F80 M3
I have a BK Harness Bar and belts for sale.
FS: Brey Krause Harness Bar, Schroth Hans Belts, and Fire Extingusher http://www.m3post.com/forums/showthread.php?t=1126495
      05-20-2015, 06:09 AM   #13
LiM3y
LiM3y's Avatar
United Kingdom
70
Drives: 2008 E90 M3
An option for a 4-point harness with anti-submarine straps is the Team Tech Jet-Pilot (http://www.teamtechmotorsports.com) harness. It is a 4-point install with anti-sub belts attached top the lap belt, providing 6-point capability in a 4-point format. The question of a 4-point harness is the submarining issue, and if tech inspectors don't buy the Schroth ASM, this fixes that.
You can talk directly to the owner, Curt, by e-mailing or phone. Team Tech works directly with Ford SVT for their demo cars, this is how I became aware of them after seeing their 6-point harness fitted to standard Ford recaro seats in SVT demo cars at a Mustang track event. In that case, they had a 6-point harness clipped and wrapped onto a bar fitted across the rear of the seat rail, and the driver/passenger sat on the anti-sub loops. In the discussion of fitting their six-point Rampac harness to my car this way, they said "Actually, have you seen the Jet Pilot harness?". This clips in like a 4-point, but has anti-sub loops stitched into the lap-belt. All six straps release at the buckle. Pretty cool. You also have custom color and HANS shaping options.
Search this Thread:
Advanced Search
