07-06-2015, 08:26 PM | #1 |
Rep 82
I have a problem and i need advice
Hello everyone,
Today i took my 2009 e92 M3 to the dyno to see what numbers it would put down, but i was extremely shocked how it under performed ! it made only 348whp ! Preformance mods: BPM stage 2 tune IPE F1 exhaust system Macht schnell stage 2 intake Rd lowering springs To be honest i was expecting something was wrong , my macht schnell stage 2 intake is kind of not fitted right it keeps on coming a bit off every time i floor it, its like there is an error from the factory, i bought it from EAS however my friend got his macht schnell stage 2 intake from IND and installed it at the same garage but his fitment is 100%. I am not saying this could be the main problem i am just saying it might of helped loose a few horses , i was expecting to make about 380WHP. If anyone can guide me to where the problem might be i would really appreciate it. Thank you This Video of the Dyno run |
07-06-2015, 10:51 PM | #4 |
Rep 318
Make sure the little rubber spacer under the intake is on the center hole of the frame rail.
Also check your oxygen sensors as it shouldn't be leaning out on top, it should be going richer. Perhaps the dyno afr meter is incorrect or the sensor pushed out. |
07-07-2015, 12:44 AM | #5 |
Rep 82
ill try fixing the intake issue, probably will contact eas , Yes i realized it going too lean and i was wondering if this has to do with the tune or a fuel pump issue but if it is the Oxygen sensor then how should i fix it? Maybe Mike Benvo can help
07-07-2015, 12:54 PM | #6 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
what did your friend dyno?
07-07-2015, 08:14 PM | #7 |
Rep 614
07-07-2015, 08:57 PM | #8 |
Rep 1,246
Your shit is running so rich up top that it's making it rain in the club on a Tuesday!
07-08-2015, 12:15 AM | #10 | |
Rep 82
07-08-2015, 12:18 AM | #11 |
Rep 82
07-08-2015, 07:56 AM | #12 | |
Rep 1,201
Your power curve shows that power is trailing off early. If you had a torque graph you could see it pretty easily. Around 100mph your power begins falling off.
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
07-08-2015, 12:39 PM | #13 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
i'm sorry i thought perhaps your friend with the same intake dynoed his car as well.
07-08-2015, 10:27 PM | #14 |
Rep 30
I made 356 on a dyno jet which is very low considering I have a intake , pulley , tune , gts dct software , the newer dct software 241e . Matt schnelle catless x pipe ... My afs are at 13 across the board ...... Interested to see what you find .
07-08-2015, 10:47 PM | #15 |
Rep 317
A dyno is just a tool, always base line at a good shop that keeps dyno in good condition.
Temperature, humidity, how u have been driving lately are just some of the variables. Just make sure everything is good spark plugs Coils O2 sensors Fix that intake leak Drive it hard! |
08-10-2015, 07:52 PM | #17 |
Rep 82
08-10-2015, 07:56 PM | #18 |
Rep 82
hey guys I have recently plugged my m3 to the diagnosis machine honestly don't know whats it called and this is the msgs that I got ,272c oxygen sensor output stage diagnosis heater after cat blank 1,and ,272d oxygen sensor output stage diagnosis heater after cat blank 2.
Do think this is what's causing my AFR to be really lean or that's not the issue ? Can anyone show me how good AFR graph looks like? |
08-11-2015, 09:25 AM | #19 |
Rep 1,201
Those are emissions codes I think. Won't affect how your car runs. Honestly though, they shouldn't be popping up once you get a tune I would think.
How were you reading AFR? Were you using the factory O2 readings or using an O2 sensor mounted in the tailpipe. If mounted in the tailpipe, do you have cats?
08-11-2015, 10:52 AM | #20 |
Rep 1,749
The lean run is pto baby causing ignition timing retard and lost power. Second your not far off. 340 to 380 is norm even for tuned cars. New plugs, o2 sensors and coils if you have more than 50k miles may help.
Tune won't eliminate those emission codes from an obd2 reader. It suppresses the CEL from apperi g with a tune though. Some folks in past ipe full valves exhaust loses power too |
08-11-2015, 09:46 PM | #21 | |
Rep 82
08-11-2015, 09:54 PM | #22 | |
Rep 82
