03-30-2014, 01:32 AM | #1 |
Rep 954
Apex EC-7 and R888 fitment. Need advice
I am trying to choose my new setup for maximum grip. I picked Apex EC-7 wheels and R888 tires combo.
Can I run this w/o much rubbing? 18x10 ET25 w/ 275/35/18 18x11 ET25 w/ 295/30/18 I want it to be uber aggressive. What I run now is a safe setup and no rub, but I feel like I can squeeze more in there. What do you guys think ? |
03-30-2014, 09:21 AM | #2 |
Rep 6,734
275/35/18 is a great size for the front but you will need a 5mm or 10mm spacer in the front to clear your clubsports. I would choose 295/35/18 in the rear, which will fit without a spacer. 295/30/18 is 1" too small of a diameter. It's also a smaller diameter than the 275/35/18 you plan to run in the front which I would avoid (OEM spec is a larger diameter in the rear than front). 295/35/18 is very close to the OEM diameter, a good diameter match to 275/35/18, and it fits nicely. I have fit g-force rivals in that size with the same wheel width and offset. I have not test fit R888's.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 03-30-2014 at 09:31 AM.. |
03-30-2014, 10:55 AM | #3 | |
Rep 954
Thanks a lot! Well, the problem is that Toyo doesn't make 295/35/18. At least I couldn't find it. 275/35/18 is 25.7" 295/30/18 is 25.1" Man, maybe I should try 305/35/18 at 26.3"?! It is 0.5-0.6" wider.. Last edited by thorny; 03-30-2014 at 11:04 AM.. |
03-30-2014, 11:29 AM | #4 | |
Rep 6,734
http://www.m3post.com/forums/showthr...&highlight=E05
'23 X7
03-30-2014, 11:41 AM | #5 |
Rep 6,734
I should also say that I have seen a lot of accomplished track drivers on this forum run 265/35/18 and 295/30/18 tires. Those sizes are available in Michelin Pilot Sport Cup, Hankook TD, and Yokohama AD08R tires. I just don't see the point of installing 18's with 30-series tires in the rear which is a size / sidewall suitable for 19" wheels (in addition to the reasons I listed above). That being said, the grip of the TD's and PSC are know to be amazing which results in some impressive track performance.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 03-30-2014 at 11:54 AM.. |
03-30-2014, 03:44 PM | #6 | |
Rep 954
03-30-2014, 03:50 PM | #7 | |
Rep 954
03-30-2014, 05:05 PM | #8 | ||
Rep 6,734
'23 X7
03-30-2014, 05:45 PM | #9 | |
Rep 954
03-31-2014, 05:08 AM | #10 |
Rep 2,224
Your sizes sound right and are what apex advised me to run too. R888 probably aren't the best grip tyre though. I run a 275 square setup but will soon upgrade to 11" rears with 295's.
Apex did tell me though that 295/35 are too tall and 295/30 are the best/correct size. |
03-31-2014, 11:08 AM | #11 | |
Rep 6,734
'23 X7
03-31-2014, 01:01 PM | #12 |
Rep 5,483
Apex needs to read their own website then.
295/35-18 will fit just fine. A 295/35-19 would be too tall yes. It's too bad The 11 isn't more like an et30-33. At et25 it's not taking full advantage of the available space. I would rather run their 10.5 than their 11 for that reason There is room for the 315/30 Hoosier in back, but it is a shorter tire than the 305/35 Toyo. Still I was running out of width room before height room when running that tire so I would expect it to fit with the right offset. Also there is room in front for a 295/30 but you have to buy the right struts and choose offsets carefully. Some of the struts out there take up more room than stock. I like this tire size for the front as it's usually pretty close to a 285/30 in width if you look at the specs (sometimes even narrower wven though in theory it should be wider) but it's got almost a half inch of extra height which can give you better wear as a bigger tire height or width can take more load longer than a smaller tire in general
03-31-2014, 05:52 PM | #13 | |
Rep 954
03-31-2014, 07:30 PM | #14 |
Rep 2,224
Ohhh, I assumed you meant for track only, as R888 are more a track tire. I think the M3 is a bit heavy for the R888 and get too hot & greasy when tracking. I dunno if I would use R888 on the street either, because they wouldn't last too long and would be poor in the wet.
Problem you've probably noticed is.. when you're looking for shallow 295's, there are not many options, especially for track setups. If you're after more of a street setup, maybe something from usual suspects like conti or michelin? The new ContiForceContact look interesting though, and Yokohama AD08 might be worth checking out too but I know very little about them? You might be able to find something that ticks most boxes. I'm now confused by the differing opinions in 295/30 vs 295/35 Luckily I don't need them yet. My next track tyre I am considering trying pilot cup sports |
