04-24-2019, 06:32 PM | #1 |
Rep 392
Drives: F13 M6
Self installed a ESS Tuning VT2 595
Special thanks to Kevin at EAS. The install went well. It was difficult for me, since it was my first S/C install and I did the entire job alone. The toughest part was mounting the S/C with the bracket attached, I have the Gen II kit, so bracket is a bit different. The directions are good and with some good mechanical background, I was able to finish it in a couple days.
The only problem I had was with the upper radiator hose on the driver side (USA car). I had not re-seated it properly after mounting the bracket, which led me to problems during the first run, etc... I found the leak and reseated it and am all good now. I have put about 300 miles on the kit and its awesome. I had a spirited drive from Ohio back to Chicago. Here are some pics and a short video of the first start. |
04-24-2019, 06:44 PM | #2 |
Rep 392
Drives: F13 M6
Install images
Here are the install images.
04-24-2019, 07:00 PM | #4 |
Rep 392
Drives: F13 M6
I agree! Btw, not to change the subject too much, but I have checked out your DIY on Rod bearings. Do you also have a youtube video on that? I think I may have seen I think.
04-24-2019, 07:03 PM | #5 | |
Rep 21,727
Mdriv3r148.50 |
04-24-2019, 07:18 PM | #6 | ||
Rep 392
Drives: F13 M6
I will post more install pics (gotta resize them) a bit later. I don't have too many more, as my hands were literally covered in grease lol. There were parts I had gloves for and parts where I didn't so I could feel the bolts better, etc... I also have a video of doing the initial ecu read and the first start up. I am sure people looking S/C will wanna see that. The install went smooth and its a great lit all around. |
bhup0925.00 |
04-25-2019, 12:14 AM | #10 |
Rep 392
Drives: F13 M6
More images
Here are the rest of my pics. The directions mentioned to use red thread locker to mount the S/c to the bracket and to torque them to 25-30 lbs. The kit also had the black injectors.
04-25-2019, 12:19 AM | #11 |
Rep 392
Drives: F13 M6
04-25-2019, 09:18 AM | #12 |
Rep 1,673
I have had the gen 2 since November. Will post up a few shots also, can throw a few pros and cons along with it.
Electronics Junkie, Engine Builder.
04-25-2019, 10:21 AM | #14 |
Rep 2,747
The bracket on my gen 1 has a small fracture where it gets very thin, wondering if that was common and that's why they redesigned it? Actually the gen 2looks easier to install now too? Is the air intake still the same?
9ers
Mdriv3r148.50 |
04-25-2019, 10:45 AM | #15 | ||
Rep 1,673
Nice job on the install with the 595 kit.
Mdriv3r148.50 |
01-22-2020, 11:06 PM | #16 | |||
Rep 392
Drives: F13 M6
The only thing I did was change O2 sensors but I bought those from FCP Euro, so using the lifetime warranty for part exchanges with them. |
01-22-2020, 11:10 PM | #17 |
Rep 392
Drives: F13 M6
Forgot to mention... I have also done the rod bearings with BE bearings and ARP rod bolts since then. I also picked up and installed a set of Ohlins R&T to balance the car out. Those are great as well
