03-31-2018, 09:05 PM | #1 |
Rep 124
limp mode/misfires after xpipe and battery swap
hey everyone, went to swap my oem xpipe to pass inspection car battery happened to die before entering the shops garage, was pushed in oem xpipe swapped in then jumped and started but after a few minutes a bunch of codes came up limp mode/misfiring on cyl 1-4.
i replaced/registered the battery thinking it would go away but the problem persisted and even came up with p0171 and p152d codes, so now im not to sure if its electrical related or exhaust related...i read it could possibly be the metal ring gaskets that connect headers to x pipe but its only the second time ive swapped the x pipe...any ideas TIA |
04-12-2018, 12:08 PM | #4 |
///M
237
Rep 703
Did you replace header to testpipe gasket with OEM? Anything but OEM gasket will cause misfires from what I've seen.
Follow me on IG: dre.pt
