08-23-2013, 10:00 AM | #1 |
Rep 478
275/30 and 295/30
About to pull the trigger for some Michelin PSS tyres tomorrow. I have 2013 E92 ZCP M3, OEM suspension.
Did tons of searches. Quite confident that E92 ZCP will do fine with front 265/30 and rear 295/30 I'm not so confident about front 275/30. Those of you running 265/30s and 275/30s front, do you get any rubbing when cornering under load ? The only reason for trying 275 is to get the OD similar to the rear. Any help is appreciated ! |
08-23-2013, 10:35 AM | #2 |
Rep 6,734
What wheels are you installing those tires onto? If you are installing them on ZCP wheels I would not recommend it. ZCP wheels are only 9" and 10" wide. Those widths are too narrow for 275/295's. It can be done and it is within spec for most tires but it's still not ideal. Tire performance is best when the tire and wheel widths are well-matched - allowing the wheel to support the tire's side-wall. I think that 255/35/19 and 275/35/19 are a much better match for ZCP wheel widths. That being said, I have run 275/30/19 Yokohama AD08's (which run very wide and square) on 9" front wheels with an offset of et20. No rubbing for me. The OEM ZCP fronts are et31; so I had the equivalent of a 12mm spacer with a ZCP wheel. Based on my experience, the tire sizes will work but again, I wouldn't recommend it.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-23-2013 at 10:41 AM.. |
08-23-2013, 10:38 AM | #3 |
Rep 478
ZCP Wheels.
I understand them to be 9" front which may be too much of rubber with 275. Just trying to figure out if I can achieve same OD with 295s in the back. |
08-23-2013, 10:45 AM | #4 |
Rep 6,734
What do you mean by "same OD with the 295"? A 275/30/19 is very close in OD as the OEM 245/35/19 tires but not the same as the 295/30/19. That being said, I try to run tires with OD's that are as close as possible to OEM. At the very least, I make sure the rear OD is equal to or larger than the front OD. The 275/295 combo is great in that it does offer the closest OD's to stock with larger tires.
'23 X7
08-23-2013, 10:51 AM | #5 | |
Rep 478
Which is why I'm leaning towards 275/30 instead of 265/30. I just need to know if 275/30 front will rub when under high corner load. |
08-23-2013, 11:06 AM | #6 |
Rep 1,679
08-23-2013, 11:09 AM | #7 |
Rep 478
08-23-2013, 11:13 AM | #8 |
Rep 1,679
08-23-2013, 11:27 AM | #9 |
Rep 6,734
'23 X7
08-23-2013, 11:44 AM | #11 |
M3NTAL
132
Rep 608
Running 275/295 PSS on E92 ZCP with no issues. Ever so slight rubbing on rears with hard cornering when they were brand new, but it wasn't even audible and seems to have rubbed off enough to have stopped.
08-23-2013, 12:23 PM | #12 |
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
275/30 19 in front with no issues whatsoever
08-23-2013, 12:36 PM | #13 |
Rep 4,318
I ran 275/30 AD08s up front on 9" wide front, only minor rubbing, but it was too wide for the wheel. Lost steering feel, felt very heavy and when pushed hard (esp at the track) did not perform well. I downsized to 255/35 & 285/30 and am very happy. Have basically the same grip with much better feel, no rubbing at all and perfect appearance.
GT3 RS | Desperately seeking the next great M car...
08-23-2013, 08:34 PM | #14 | |
Rep 478
The reason why I asked if these tyres would rub is because there is a difference between driving around daily and driving around the track. At tire's traction limit, the suspension will be under higher compression as compared to daily driving which then increases risk of rubbing. Thanks for your feedback ! |
08-23-2013, 08:59 PM | #16 | |
Rep 478
Due to lack of tire stocks(3-4 mths wait), its either OEM sizes or Front: 255/35, 265/30, 275/30 Rear: 275/35, 295/30 My preferred choice is still 255/35 and 285/30 GTS set up. I know 255/275 can be done but I want a minimum of 285 in the rears for ZCP. I will go with 265/295 set up. Thanks for your feedback ! |
08-23-2013, 09:05 PM | #17 |
Rep 368
I'm going to be running PSS 255/35/19 f 295/30/19 r however I'm using aftermarket wheels 19x8.5 front 19x11 rear.
2009 E92 M3 DCT: BPM tune + DCT tune & Servotronic | Velos Solo VII 19x 8.5, 19x11 | Michelin Pilot Super Sport 255/35/19 front 295/30/19 rear | M Performance Exhaust | BCM Air Intake Filter
08-23-2013, 09:24 PM | #18 |
Rep 478
08-23-2013, 09:35 PM | #19 |
Rep 368
Most definitely will! Tires came in yesterday still waiting on the wheels, I was told 4 to 5 weeks on the wheels, so I still have at least 2 weeks left for the wheels to arrive.
08-23-2013, 09:40 PM | #20 |
Grown Azz Man
429
Rep 3,021
Good choice......been running this set up for a while now. Initially ran it on my ZCP wheels and now on CH-R's.......19x9.5 front and 19x10.5 rear..........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
08-23-2013, 10:54 PM | #21 |
Rep 996
08-24-2013, 12:33 AM | #22 |
Rep 6,734
Why not 275/35/18 in the front?
'23 X7
