03-10-2010, 12:57 AM | #2 |
Rep 1,064
Unless your car is 'custom' there is no benefit of a custom tune.
Even if your car is custom then there may already be a tune out there for that setup. The mechanical tolerances are extremely small accross these engines. Unless of course you want a custom type of map such as specific changes to the throttle maps or purely driveability modifications and no full power changes etc etc. |
03-10-2010, 11:27 AM | #3 | |
391
Rep 3,149
The MSS60 will adapt and make corrections on the fly for each cylinder in the S65 motor when needed. Most tuners have software for small changes like catless exhaust systems that work perfectly fine. The only reason anyone would ever need a custom tune on this car is if they wanted something specific like a custom RPM limit, idle or they made a significant change such as cams or higher displacement. |
03-12-2010, 09:05 AM | #4 |
Rep 148
I have heard that the engine management is a "target" based closed loop type system that will adapt to different modifications. Is this correct? and can you elaborate more on how the factory engine management works?
The reason for this post is when researching PencilGeeks Dyno Thread there seemed to be common that the "custom" ECU tune was always on top of the charts even on the standard 4.0l with bolt on mods. |
03-12-2010, 12:00 PM | #6 |
Scared money don't make money.
67
Rep 1,448
Drives: 2009 E92 M3 DCT
I can tell you that my custom PC map made A LOT more power than my off the shelf map. According to some, I wasted my money by paying for a "custom" map , but my cars consistently strong performance tells me otherwise.
There's a lot of political BS on this forum that clouds the information that is actually posted. My advice is to take sponsor's opinions with a grain of salt. Just my .02 .
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
03-12-2010, 12:09 PM | #7 |
Rep 148
My problem is that I tune vehicles for a living and I know what is typically left on the table. I don't believe that this car is any different. I am just looking for little more insight.
03-12-2010, 07:06 PM | #8 | |
391
Rep 3,149
AJ and I will be in socal several times over the next 6 weeks so it should be very easy to arrange this test. We will of course pay for the dyno time. |
03-12-2010, 07:36 PM | #9 |
Rep 3,574
Tuning for more HP is one thing, but tuning to make the car feel better as a daily and for more power all around is another story. Depends on which you want.
I can tell you that my ECU flash from "wherever I got it from" works really well and it was worth every $.
2015 Porsche 991.1 GT3 2015 F80 M3 -- Individual; Space Grey |
03-12-2010, 08:28 PM | #10 | |
Rep 148
Can you elaborate on the engine management on these cars? |
03-12-2010, 09:02 PM | #11 | |
67
Rep 1,448
You've got yourself a deal Roman, as long as I get to keep your tune if it makes more power . I'm in close proximity to several dynos here in Orange County. PM when you have figured out a date and I'll give you all of my contact info.
03-12-2010, 09:14 PM | #12 |
Rep 385
This is good you guys, good for all of us!
03-12-2010, 10:41 PM | #13 |
391
Rep 3,149
Excellent you got a deal I will PM you with some dates and let me know if any of them work.
03-12-2010, 11:13 PM | #14 | |
Rep 1,064
Information will soon be made very clear so there is no clouding and no amount of political BS should cloud the whole understanding of tuning again. |
03-13-2010, 02:50 AM | #16 |
I like cars
329
Rep 5,052
Why can't it be made clear now?
My photostream: http://www.flickr.com/photos/racelap/
03-13-2010, 09:58 AM | #17 | |
Rep 148
Is it in continuous closed loop even under WOT? Are the adaptation values that PG speaks of fuel/IGN/Vanos/ETC or are the limited to just one. It has to be governed by the same principles as any other engine management. That is why I don't believe a flash is a blanket solution for different combos. Last edited by masitr; 03-13-2010 at 10:08 AM.. |
03-13-2010, 11:16 AM | #18 |
Automotive Industry Insider
462
Rep 1,948
I agree 100%, one-off 'custom tunes' are a fallacy on this car.
Customers have been sold on this concept, because many guys lack a basic understanding of how engines/ECU's work. (fact) Or... they believe that cars are still tuned exactly the same way they were 5, 10, or even 15 years ago. That leaves many BMW enthusiasts vulnerable to all sorts of bogus marketing propaganda. (regardless of the product being discussed) New innovative engine management technologies are always advancing, always improving the tuning methods used in modern engines. The really good tuners are going to figure out the best way to utilize that new technology. In order to build a safer, more reliable tune (that can also extract more horsepower and torque) vs. the conservative stock tuning loaded into OEM ECU's), will require a knowledge base that very few tuners actually have in regards to BMW cars. The very complex encryption on our factory ECU's, means that any tuner will have his work cut out for him if he intends to write a file for our cars. BMW's are notoriously difficult to tune properly, because that's how BMW AG wants it. They make it very difficult to access the raw software code, and many of the tables/maps are not easily manipulated. Tuning a M3 vs. tuning a Dodge diesel truck is like night and day. Even tuning a Porsche or Lambo is child's play compared to an M3. BMW's are the most difficult cars in the world to tune. Again...that's exactly how BMW want's it. They set traps for tuners all the time...you guys just don't know about it since you never talk to the few individuals in the world who actually tune BMW ECU's for a living. (and have done so for the past 10-20 years) Despite the best efforts of some members here to educate others, I have to admit this... A very well executed marketing campaign is incredibly difficult to beat sometimes. Man, I can't wait to see the posted results of this shootout. (and the comments that follow it) Just my .02 fellas...
The best is yet to come...
03-13-2010, 11:52 AM | #19 | |
Rep 722
03-13-2010, 11:56 AM | #20 | |
Bulldog
482
Rep 3,355
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS |
