05-04-2010, 04:19 PM | #1 |
Rep 1,033
How do I get the dirt off without getting swirlmarks?
So I have a car thats been sitting for atleast 6 months and theres like a layer off dust on it, and after hosing it down with water its still on there.
I was afraid of starting to spunge it with soap and water before anything. So how do I start to wash it, preventing it from getting major swirlmarks due to the hard-to-remove layer of dust? I know I should wash more frequently but not in town so i need to was it ASAP when im home, which is soon, so I'm prepaired. Thanks for any inputs on this. |
05-04-2010, 04:35 PM | #2 |
Rep 280
If you have a foam gun, use it to "loosen up" the layer. If not still use the following. The key is a good shampoo mixed properly in the 5 gallon bucket (two to three bucket method : one with shampoo, two with water) and a good wash mitt. To avoid swirls keep your mitt clean with each few passes. As long as your mitt stays clean (and you may have to dump out your shampoo for another bucket midway), you're good. Its kind of a pain to keep cleaning your mitt in the grit guard but you'll be able to get that layer off. There are detailers that keep the hose nearby and keep washing off the dirt from their mitt before putting it back in the bucket.
You can consider pre-spraying with bug and tar remover before the wash, but don't leave it on too long or let it dry. Good luck.
09 E90 M3 DCT SSII Carbon Blk, Eisenmann Sport, RAC 19"RG63 on 255/275 UltracS, Dark Sidemkrs/Reflectrs/Grills, BMC Filter, LUX H8 V3 LEDs, V1 H/W, Ultimate Pedals & 30% Tint
05-04-2010, 06:01 PM | #3 | |
Rep 1,033
05-04-2010, 06:22 PM | #4 |
Rep 280
There's a lot of good shampoos out there. You don't have to get too expensive. I still use Megs Gold Class (got from Walmart). I also like Chemical Guys Citrus Wash and Gloss, Plain Citrus Wash. If you have a CarQuest in town, Duragloss 901 is great:
check out this thread: http://www.autopia.org/forum/car-det...-shampoos.html
05-04-2010, 09:42 PM | #5 |
Rep 1,168
presoak with ONR at QD strength. rinse it off
come back with a bucket with dawn and degreaser and a mitt (washing in the shade, and rinsing after every panel, dont let the soap mix dry) wash again with dawn and you should be good to go! You might even be able to get away with a normal wash, and just polish it anyway! chances are you are going to have to clay it to remove the embedded debris, and after claying, polishing is a must IMO. seal it up and it will be as it was before you left it alone! |
05-05-2010, 01:04 AM | #6 | ||
Rep 1,033
Yes I was thinking giving it; - A good wash with a pressure washer using some foam. (maybe let it soak for a short time) - Soap/water, mit - Clay - Wax/polish. Hope that should do ET!!!! THANKS guys!!!! |
05-05-2010, 01:48 AM | #8 |
Rep 1,033
05-05-2010, 03:43 AM | #9 |
Rep 1,035
It's about as non-abrasive as you can get. The dirt gets trapped into the little holes and doesn't get dragged across the paint. You'll know how non-abrasive these sponges are if you try to wash a dirty car with them. Takes forever but doesn't leave scratches behind.
05-05-2010, 11:21 AM | #10 |
Rep 803
Mentally, imagine that your mitt is faced with sandpaper on the first pass over the car. Essentially, it is. In other words, a very, very light touch on the first pass, then flip/rinse/rewash with a little more pressure.
Objects in mirror are slower than they appear.
05-05-2010, 11:52 AM | #11 | |
Rep 280
http://www.detailersdomain.com/optim...ne1gallon.aspx BTW, detailersdomain is great place to get stuff. Phil is very helpful.
05-05-2010, 01:07 PM | #12 |
Rep 10,407
+1. I was getting some light marks even with a good mit and the two bucket method. The grout sponge has helped a lot.
05-05-2010, 01:32 PM | #13 |
Rep 259
ONR is optimum no rinse. It comes concentrated and can be mixed to wash or as a quick detailer. The stuff is awesome. I mix some in a small amount with soap in my soap gun and also in my wash bucket. On top of increasing lubricity to prevent swirls it softens the water to prevent spots from hard water. I use a natural sea sponge, two bucket method and a waffle weave mf to dry and get very little marring over the course of a year. I doubt any of the marring is from washing. Check out http://www.autopia.org/ for more detailing information.
05-06-2010, 08:55 PM | #14 |
8 tracks of madness
62
Rep 2,735
Even using 2-bucket method with grit guards I got swirls with mitts and a grout sponge. The ONLY thing I've ever used that gave me no swirls was something everyone told me would, my trusty Meguiar's brushes. Go figure. No, being a brush it won't get off anything that's really stuck but a duick QD when I'm done gets any of that stuff.
I think they're discontinued but if you can find them I HIGHLY recommed that brush. |
05-07-2010, 12:35 PM | #15 | |
Still waiting...
25
Rep 887
