08-27-2022, 11:24 AM | #1 |
Rep 341
MT Refresh what's all needed ?
Clutch release bearing getting worse pretty sure that's what it is am at 109000km lots of noise when clutch is engaged in neutral going to refresh everything while it is apart anything am missing or that is not needed definitely want to do upgraded clutch...
Clutch Slave Cylinder Rear Crank Seal Shifter rebuild and upgrade kit Trans Bushings 80a Clutch Masters stage 3+ FX 350 BMS Billet clutch valve Release Bearing Pilot Bearing Air Injection Control Valves Output Shaft Seal Driveshaft Seal Trans Fluid Thanks In advance
TTP
08-29-2022, 05:52 AM | #2 |
mTekMods
2143
Rep 2,902
Im not sure if you should mess around with the rear crank seal, if you dont have the tool to put the seal back in you will be in for a world of headaches when you gotta pull the trans back out. The snout of the crankshaft stick out past the end of the block and there really isnt anywhere to attach a homemade tool back there. the seal sits recessed into the bore.
If it isnt a track car take those 80a trans mounts off your list, the transmission will vibrate the entire car loose around 4K RPM.
08-29-2022, 01:06 PM | #3 |
Rep 24
I did RMS myself it was okay... Having the right tools really helps but is not a must, you just need to be really careful when tapping it in, a lot of patience is needed.
Also, it is a track car or not? If not, go with the stock clutch and flywheel, and OEM trans mount. Because the noise these stuffs will make will drive you crazy if you just cruising around town. Also, you don't need a BMS Billet clutch valve, M3 does not have a clutch delay valve. And if you changing the output shaft seal and driveshaft seal, you might as well change the driveshaft center bearing and flex disc (guibo) while you are at it. |
08-29-2022, 01:38 PM | #4 | |
Rep 946
"Tapping" them in as mentioned, while possible, is just asking for a repeat in fairly short order. RMS are fairly delicate and it takes very little to damage the sealing surface. On top of that, not using an install tool can very easily distort the seal causing uneven wear and premature failure. OP, I would leave it alone if it is not leaking. And unless you are putting down 6-700 HP you would not need or ever use a stage 3 clutch. Hell, this engine barely stresses a stage 1 clutch, LOL! Save your money!
08-29-2022, 03:44 PM | #5 | |
Rep 24
I do not agree to leave it out when doing the clutch, I learned this the hard way. When my car is at 100k I changed the clutch without doing the RMS, and at 120k RMS started to leak. Wasn't leaking a lot but was leaking enough to sling oil onto my clutch causing it to slip and fail. So I have to redo the clutch again with RMS. Maybe I am just unlucky that my RMS failed, maybe yours will last a very long time, IDK. But I don't want to take the chance again in the future. Just spend the $150 to get the tools and do it properly. Just a tip, when buying RMS, buy the one with a plastic install guide, it makes your installation way easier and only costs a few bucks more. |
08-31-2022, 10:58 PM | #6 |
Rep 341
thanks a lot for all the feedback and when the car comes out it gets beat on hard basically every time a lot of clutch kicks and banging first to second and will probably be doing VF620 on this car wouldn't mind a bit of extra noise from the tranny or clutch as the car is not a daily it's either track or street drift but if stock trans mounts hold up fine with more power will go with stock...
08-31-2022, 11:00 PM | #7 | |
Rep 341
08-31-2022, 11:02 PM | #8 | |
Rep 341
