08-10-2022, 02:14 AM | #1 |
3r1k
30
Rep 360
IPE Exhaust Manual Valve Adjustment
Hopefully someone can help me here
I acquired E90 M3 with IPE Exhaust however the remote is missing so the valve is open all the time and it is very droney. Is there a way for me to manually adjust the valve in the pipe itself with a stick or something else? Thank you in advance.
12.836 @ 109.75mph (Cobb - Accessport & VRSF DP)
08-10-2022, 10:25 AM | #2 | |
Rep 507
07 e90 335xi- Sold, 09 X5- Sold, 12 e92 335 xdrive - Sold 11 e92 M3- Sold, 15 M235-Sold,07 e90 335xi (current daily), 10 Atlantis e92 M3 (current) Way to many mods to list
08-10-2022, 06:32 PM | #3 |
Rep 4,165
The valves are vacuum, meaning they only close when there is vacuum pulling it shut. There is no way to push them close, the spring in the valve would just open it up again.
If you have lost the remote, just wire up a toggle switch to the vacuum solenoid that activates the valves. Then you can open/close the valve using the switch. |
NiBe453.00 B8bydesign680.00 |
08-11-2022, 01:28 PM | #4 |
Rep 1,527
Drives: '11 BMW M3
This is exactly what the PO of my E90 did, works great.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak |
08-12-2022, 09:00 AM | #5 |
3r1k
30
Rep 360
Thanks for the help! I'm not that technically minded I'll try the method above otherwise I'll get a new module.
