10-11-2010, 02:14 PM | #1 |
Rep 7
BMW 1 Series Changing 1st to 2nd Gear
Hi,
I have a BMW 1 series 2006, i notices that when i change from the 1st gear to the 2nd gear - at 2000 REVS, the car makes a strange noise from beneath- as if the engine cant hold the car. The noise is like metals clinging with each other. Also the same noise happens when i am on the 3rd gear... slows down ( eg roundabout) and press the gass again to move... Any ideas ? Thank you in advance |
10-11-2010, 04:10 PM | #2 |
Member
Rep 183
Post in an appropiate forum here: http://www.1addicts.com/forums/index.php
10-11-2010, 10:14 PM | #4 |
Rep 215
Wouldnt shifting at 2000 RPM be kind of bogging the engine?
I usually shift between 3k and 4k under normal driving. Much higher if I'm going for a quick launch...
"...couldn't help but make me feel ashamed to live in a land where justice is a game." -Bob Dylan
10-11-2010, 10:31 PM | #5 |
Rep 5,627
10-11-2010, 10:33 PM | #6 |
Rep 567
It is a 2006, what? 116, 118, 125? How many miles? Have you changed the differential and transmission fluids? If you have more than 50k miles on the car, I would do this, and maybe even look at the shifter bushings to make sure they are not wearing out. 2000 rpm is pretty low for shifting unless it is a 135i, even my old Z3 coupe would stutter and bog at that rpm in higher gears. (It wanted to rev). Try changing the fluids and shifting at 3000 rpm on a regular basis to see if that helps at all.
10-12-2010, 02:10 AM | #7 |
Rep 459
I'm thinking you're describing the known problem in 1-series and 3-series caused by the clutch delay valve. Feels clunky and makes a ton of noise? If that's it, then it's normal. Or did it just recently start?
10-15-2010, 09:21 AM | #10 | |
Rep 7
35K Miles So i should start shifting gears at higher revs ? Thanks |
10-15-2010, 12:03 PM | #12 |
Rep 1,501
I've noticed something similar. Although I haven't felt as something was wrong. But this is after 9 years of driving Acura 6mt. BMW, to me, seems to be clunky. And I've noticed if I slow up quick shifts, the smoother the drivetain reacts (CDV maybe?)
miiipilot
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
10-15-2010, 12:58 PM | #13 |
Rep 459
I've noticed the same thing too mii. I don't think it can be anything else other than the CDV giving us smoother shifts if we slow down the shifts.
Tags |
bmw, gear, noise, series |
