03-27-2018, 01:11 PM | #1 |
Rep 554
Sprung corner weights, motion ratios, and hertz
Hey all,
Attempting to engineer the correct springs/damping for my E90 for AutoX, street, and track fun. I've been searching all morning, but cant find if anyone has added up, calculated, or just has heard what our front and rear sprung corner weights are (with room for a tire/wheel weight, naturally). Also, mu understanding is that we have motion ratios in the .96r/.56f zone. Also, do people have frequencies that are working well for them? 2hz? 2.5? Thanks in advance. There isn't a lot coming up in searches. |
03-27-2018, 01:23 PM | #2 |
///M Powered for Life
11480
Rep 10,328
I'd love to know.
I'd like my suspension tinkering to be a bit more advanced than what it currently is: |
03-27-2018, 01:37 PM | #3 |
Rep 554
Background:
http://eibach.com/eibach/img/ers-14s...nworksheet.pdf has the math. I'm looking for a frequency of approximately 2hz and then to calculate the critical damping for that. |
03-27-2018, 02:05 PM | #4 |
Rep 105
Many a people have done this for lots of different platforms and I have never seen it be right. Find your local fast guy/shop and duplicate his setup and test/change from there.
03-27-2018, 03:38 PM | #5 | |
Rep 554
Great. Check. I'm working through the math with my son to teach him the science, and we need the variables. If you aren't going to approach it scientifically and you purchase 3-way adjustable shocks, you will either- 1. get lucky; your go fast shop hit the nail on the head, front AND rear. 2. chase your tail around in circles trying to adjust and "feel the difference" 3. chase your tail around in circles buying more parts. The first step in approaching 3-way shocks scientifically is to get the numbers, study the system, and then come up with a hypothesis, that way when the system is off, you have an idea how to adjust it. The go fast shop has no idea what tires, what sway-bars, what wheel weights, what vehicle weights, what ride heights, etc etc etc exist in my system. They wont hit the nail on the head for my car. |
03-27-2018, 04:02 PM | #6 |
Rep 1,848
Considering DJ holds multiple east coast track records and is the only guy I know with the nads big enough to stay flat (>137 mph) through VIR climbing eases, I'd be more than happy to take his settings and plug them in with no questions asked.
However, if you're trying to teach your son the math, keep searching this forum, because I have seen a few threads posted here with the math and the variables you're requesting. |
03-27-2018, 04:26 PM | #8 | |
Rep 554
I'll keeeeeep searching. |
03-27-2018, 05:02 PM | #9 |
11480
Rep 10,328
Wow, flat out through the VIR climbing esses is insane! I guess big aero, real slicks and massive balls?
03-27-2018, 05:04 PM | #10 | |
11480
Rep 10,328
I'll have Mr Kline give us a baseline and hopefully have Randy drive the car afterwards |
03-27-2018, 06:47 PM | #11 | |
Rep 554
Also the motion ratio of the rear shock and spring are different... so NBD, but one more translation. |
03-27-2018, 06:53 PM | #12 | |
Rep 554
I appreciate his conclusions tho. It point more to 550/900 than 700/1000, but I dont know what his tires were or his swaybars. People have apparently pushed spring rates higher in the last 4 years as remote dampers can control it well (like the MCS). He was a fan of JRZ tho, and I'm suspicious of that |
03-27-2018, 07:25 PM | #13 | |
11480
Rep 10,328
Although the 3W is not properly set up, it's still 3s faster than the oem zcp suspension |
03-27-2018, 07:28 PM | #14 | |
11480
Rep 10,328
03-27-2018, 08:56 PM | #15 |
Rep 12,725
all this hair-splitting and math to use 3-way coilovers and you're going with a cheap brembo retrofit caliper?
03-27-2018, 11:42 PM | #16 | |
Rep 554
If looking to understand how the math lines up to a set of spring rates some guy who answered the phones suggests is hair splitting... guilty. |
03-27-2018, 11:51 PM | #17 |
Rep 12,725
not triggered, its just unusual.
lots of time, energy, and thought going into your suspension to be right and seemingly zero thought and research put into the brakes.
03-28-2018, 12:04 AM | #18 |
Rep 554
Just because I came up with Brembo Z06 calipers, F80 rotors, and some cooling you think I didnt put thought into it. There are way too many people who wear their heart on their sleeve in the M3 brake debate; and yet half the fast BMW guys at the tracks around here are using stock calipers and rotors. This forum is not the best help in a scientific brake discussion. It's OK, I just know when to look elsewhere.
03-28-2018, 01:09 AM | #19 | |
Rep 12,725
which hard motorsport parts did you get? are you getting custom heat shields done to implement the ducting? its going to be a mystery if any oem shields are going to fit, even if the f80 rotor hat offset is the same as the e90's.
03-28-2018, 01:24 AM | #20 |
Rep 554
I got the cooling kit with the backing plates.
"HARD Motorsport Brake Cooling ClubSport Kit with M3 Backing Plates" We'll see, but the F80 offset it the same. |
03-28-2018, 07:53 AM | #21 | |
Rep 105
Unfortunately the mathematically "correct" settings seem to rarely work out in the real world. Hence why Pro Teams go to the track ballparked by their motorsports engineers and then play with spring rates from there. I don't blame you and I give you great respect for trying to teach your son good valuable teachings; I just have seen many go down the path and be completely off based on their findings. Go at it, just make sure you do a gut check on your numbers to see how they compare to shop recommendations like Bimmerworld and Turner Motorsports who have tested with these actual platforms and gone up and down on the springs to find the right balance. And just because Tommy Milner likes it at 800/900; doesn't mean you will be fastest at those rates. At our Non-Pro level; confidence in having the car work the way you like it to is worth far more in seconds than a perfect setup. |
03-28-2018, 08:01 AM | #22 | |
Rep 105
