  TireRack
      10-08-2014, 06:47 PM   #1
Exclusivs
Exclusivs's Avatar
18x10" wheels/tires that clear KW Clubsport coilovers
Much like the Brembo 380mm/ 18" wheel clearance thread started by (Kaiv) - This list can be comprised of 18x10" wheel/tire front fitment that clear the popular KW Clubsport coilover suspension.
Manufacturer / Model / Size (10") / Offset / Tire Brand / Spacer? / Pictures
      10-09-2014, 09:58 AM   #2
M3 Esq
Automobilist
M3 Esq's Avatar
Drives: E70 X5, 911 GT3
Apex ARC 8 18x10 ET 25 Nitto NT01 275/35/18 5mm spacer in front
      10-09-2014, 11:23 AM   #3
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
It's important for people responding to note that the spring shapes are very different between a clubsport kit (cylindrical spring) and the Variant 1-3 kits (cone shaped spring), so experience with a different KW kit would not directly apply.
Another variable you may want to collect is if people are keeping their helper springs in. The helper spring adds a lot of stack height, and forces the lower perch to be set low. Different length main springs, and no helper spring can make a huge difference in clearance.
Tire size as posted by M3 Esq will be important as well in combination with brand.
      10-28-2014, 02:02 PM   #4
M3ANMACHINE
Admiral
M3ANMACHINE's Avatar
Drives: 2011 E90 M3 + 2014 F15 X5
APEX / EC7 / 18x10 / +25 / 275/35/18 Hankook RS3 / 5mm Spacer
2020 FORD RAPTOR
2014 F15 X5 | M-SPORT
SOLD
2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3
      10-28-2014, 08:30 PM   #5
B0feity
B0feity's Avatar
11
Drives: M3
Apex / Arc-8 / 18x10 et+25 square / Hankook RS3 275/35/18 / ST60 front / ST40 rear / just ordered the KW Clubsport
Questions/concerns:
-Is there any benefit of running anything larger than a 5mm spacer in front?
-Is it generally considered safe to use a 5mm spacer in front: like the TMS 5mm spacers?
      10-28-2014, 09:49 PM   #6
steven_s
Drives: M3
going to assume te37 18x10.5 + 20 can run 275 in the front with some negative camber?
      10-29-2014, 03:55 PM   #7
B0feity
B0feity's Avatar
11
Drives: M3
If you are listing a spacer, can you list the brand as well as I think this is important.
      10-29-2014, 04:15 PM   #8
M3ANMACHINE
Admiral
Questions/concerns:
Biggest benefit would be increased inner clearance of the strut. I have been running my 18x10's up front with a 5mm spacer up front without issue, however I would recommend an 8 or 10mm spacer to leave more space.
10.5 will need a larger spacer up front than the 10" wheel, regardless of camber. Since the inner and outer clearances are both decreased by 6.3mm, you'll want a 10mm spacer and a lot more camber.
2020 FORD RAPTOR
SOLD
      10-29-2014, 05:15 PM   #9
B0feity
B0feity's Avatar
11
Drives: M3
If a 5mm is fine, why do you want more clearance? Peace of mind?
I am at the point of deciding whether to use the 5mm spacer, try a 12.5mm spacer and see if that works with my alignment and outer clearance or go a spring swap (as in Slicers' thread regarding clearance issues).
      10-29-2014, 08:40 PM   #10
steven_s
Drives: M3
hm, your fitment in the front is on point my friend.
what is your front camber
damn, that would be an effective x 10.5 + 10 at 275... (probably looking at hankook as they have a more rounded sidewall like you as well)
i'm assuming i'd have to go at least -3.5?
      10-29-2014, 09:08 PM   #11
M3ANMACHINE
Admiral
Peace of mind would be the only reason. 12.5mm will be too big, and require A LOT of camber.
Since you don't have the coils installed already, i'd recommend the spring swap when you get them!
2020 FORD RAPTOR
SOLD
      10-29-2014, 09:12 PM   #12
B0feity
B0feity's Avatar
11
Drives: M3
Ya I think I might do the swap, just seems like added headache and cost...
I already have the 5mm spacers though...
      10-29-2014, 09:15 PM   #13
M3ANMACHINE
Admiral
Do it right or do it twice as they say! The cost is marginal for the added ability of not requiring spacers and being able to run a wider wheel/tire up front without issue.
2020 FORD RAPTOR
SOLD
      10-29-2014, 09:19 PM   #14
B0feity
B0feity's Avatar
11
Drives: M3
You're probably right... I can find the springs for about ~65 bucks, so might as well as buy two. I will bring the spacers and the springs to the shop when they are to be installed and see what happens!
      10-29-2014, 10:13 PM   #15
M3ANMACHINE
Admiral
Remember, if you swap springs, you won't need spacers at all
2020 FORD RAPTOR
SOLD
      11-01-2014, 07:05 PM   #16
steven_s
Drives: M3
bump?
      11-17-2014, 04:47 PM   #17
B0feity
B0feity's Avatar
11
Drives: M3
Anyone able to run rivals with the CS in a 18x10 et25 with 275/35/18 tire?
      09-14-2017, 08:22 PM   #18
Exclusivs
Exclusivs's Avatar
Or if you swap suspension completely *hint* your sig
Still running/loving KW
Bumping thread!
      09-14-2017, 08:24 PM   #19
M3ANMACHINE
Admiral
Bumping thread!
Got a whole new car too. Lol
2020 FORD RAPTOR
SOLD
      09-14-2017, 09:05 PM   #20
Exclusivs
Exclusivs's Avatar
Well not technically ....
PM me dont wanna divert off thread topic
      02-05-2018, 01:21 PM   #21
Exclusivs
Exclusivs's Avatar
In light of recent frustration
A) With KW clubsport being an absolute well made set of coilovers for the E9X M3 platform. And truly not falling short in any category for me at this moment in time.
B) Inability to run certain tires all together, due to inability to fit 275/35's in front because of spring/strut orientation.
      07-21-2020, 02:36 AM   #22
opihi5
opihi5's Avatar
Drives: 2011 m3
2011 BMW M3  [10.00]
How big of a spacer do you need to fit 275 up front? I have apex arc 8 275/35/18 squared on michelin 4s tires.
