07-22-2009, 12:44 PM | #2 |
Rep 915
r532 - The biggest dislike I have about running my car(s) on the track, is the following day having to clean up everything. Getting rubber off almost tops the list.
I have to remove rubber deposits from the inside of my rims, some the size of golf balls. I clean the R compounds and rims together. The car, I use one of two things. Normally, Turtle Wax Bug & Tar Removal will work to remove the streaks and strikes. Some of the deposits may require Rubbing Alcohol. I also have some paint shop solvent, but I do not like to use that due to potential paint damage. FYI, I try and keep a good coat of wax on the car, particularly those areas prone to rubber collection. Hope this will help. vz
Previous Track Toy |
07-22-2009, 01:19 PM | #3 | |
8300
19
Rep 573
08-09-2009, 04:27 PM | #10 |
Rep 1,664
Seal/wax your car prior to the track day....
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
08-10-2009, 04:51 PM | #12 | |
Rep 2,279
ClearShield also has a clear coat layer. Install it in all the usual places. Cuts down on tape time. As tired as I am, I generally try to wash the car that night if I can. It's MUCH easier than even the next day.
'09 Interlagos Blue E92 M3 (sold to a good home)
09-16-2009, 09:23 PM | #13 |
Rep 1,696
I would NOT use any isopropyl (rubbing alcohol) on any clear bra film. I put a small bit on my Xpel film and it ate it away, not all the way through. But it took off the smoothness of the film and left it very rough. Luckily, I'm getting a Solar Guard ClearShield installed next week.
09-16-2009, 10:11 PM | #14 |
Rep 229
As a general rule, you can use anything on the clear bra that you feel comfortable using on your paint.
09-17-2009, 05:20 AM | #15 | |
Rep 58
Good luck with the ClearShield. Thats Baekert... do not think you are going to be happy with that film. There is a reason its one of the least used films on the market. |
10-13-2009, 01:27 PM | #16 |
Rep 81
I haven't tried it (may next event), but I've heard Pam spray works really well. Spray it on before the trackday, nothing sticks. Clean it off with gentle soap aftwards.
Can't imagine it would hurt anything. Anyone know? |
10-13-2009, 11:55 PM | #17 |
Rep 367
Drives: Alpinweiss 2009 E92 M3
clay will get it all off.
2009 E92 M3 - 7/3/09 ED, 8/17/09 redelivery 1997 E36 M3 - Track Rat 2014 Jeep Grand Cherokee Overland |
