06-17-2018, 06:21 AM | #1 |
Rep 2
e30 swap with own ecu
Hello Everyone!!
I am build project on e30 body with S65 Engine Pls help me with some issues with DME It's possible to run engine without software modifications? initially I had engine with ecu and cas module what other units are needed to normal run this engine? |
06-30-2018, 12:26 PM | #2 |
Rep 2
If someone met this problem pls let me know what is that??
connect battery, before first start: I am using BMWlogger to fast check errors: https://pasteboard.co/Hsjxzb0.png DSC error on the instrument panel icon half-engine (reduce power) mode after starting engine! another picture hmm https://pasteboard.co/Hsjwunn.png rpm limit 4500 (red zone) try to push pedal to 100% but rpm limited about 3500-4000 rpm turn off engine clear errors clear adapts by BMW logger ok check again : got DSC only........ start engine https://pasteboard.co/Hsjzyr2.png idle rpm ok try to rise rpm with the pedal (rpm limit on board 5500) but in fact a can't reach 4000 rpm , something does not allow me to do it ok check errors: https://pasteboard.co/HsjC6Ck.png wtf !!? 272C 272D lambda heater ? 2786 it's about pressure sensor http://wiki.rcollins.org/core/index....r:_2786,_P0193 but pressure sensor installed and did not make mistakes before ok , stops engine.... start again: https://pasteboard.co/HsjHw1e.png then stops https://pasteboard.co/HsjI3K1.png of all these actions, I understand that some errors occur during engine run and also disappear when it stops Ie some errors I could not diagnose in INPA because did not detect while tap throttle pedal and if you carefully look at the screenshots you will see that of the throttle do not open with the gas pedal pressed DKPB1 and DKBP2 always zero while pedal angle changin according to the pedal pressed |
