06-30-2015, 09:09 PM | #1 |
Rep 2,966
Is it time for Battery replacement? *UPDATE* New battery installed
Hey guys
The "increased" battery warning has reared its head a few times on my 09, but went away when car was driven for longer durations w/ time to charge. Low mileage car (21,xxx) -nor my daily. The error message appears every time on startup now. Will be my first BMW battery replacement - my preference is to keep it OEM. Where is the best place to find an OEM battery? How much will dealer charge for change? Is ECU tune wiped clean? Thanks in advance guys! Last edited by Exclusivs; 08-21-2015 at 05:19 PM.. |
07-01-2015, 09:23 AM | #2 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Yep sound like you need a new battery, mine was doing this and its a 2010.
I wanted to stick with OEM myself but kept having problems with any of the sellers willing to ship the battery to me. Ended up getting a very close match from Napa, the battery reset is on the coding side of things and required a different cable than tuning does. I only paid $180 for the battery and installed it myself. Had BPM reset it remotly since I have coding from them, most any shop that works on EURO cars should be able to reset if for you. Wont mess with your tune
07-01-2015, 09:46 AM | #3 | |
Rep 2,966
Dealer quoted $155 for labor - and around $355 for OE battery. |
07-01-2015, 10:27 AM | #4 |
Rep 1,017
Yea dealers always rape ya pretty good.
07-06-2015, 09:15 AM | #5 |
Rep 2,966
07-06-2015, 05:18 PM | #6 |
Rep 6,696
Drives: F30 340i
07-06-2015, 06:45 PM | #7 | |
Rep 2,966
Does anyone have source for good price on OEM battery? |
08-21-2015, 05:19 PM | #8 |
Rep 2,966
UPDATE: Had new battery installed & registered at the dealer today. It was confirmed my old battery was on the way out so new one was replaced with Oem EP 92AH. Not sure if this is an AGM battery or not - Read that BMW is no longer making AGM Oem batteries. Is this true? In any case - glad to have replaced this and though a bit more expensive going through the dealer route - gives me peace of mind of using OEM parts / and OEM registry. So far car starts up faster, navigation is no longer laggy, and overall electronics just seem to be functioning to where they are suppose to.
For cross reference battery part # that was installed is : 61-21-2-353-812 As I said - unsure if it's an AGM or not. Or if BMW is making AGMs anymore. Maybe someone can clarify and confirm. All in all today was a good day! |
08-21-2015, 08:32 PM | #9 | |
Rep 217
AGM i had battery installed about 2 months ago. AGM for M3. |
08-22-2015, 11:41 AM | #12 |
Rep 2,966
Excellent - thats exactly what I paid as well. Thanks for confirming it is an AGM! Though an unwanted expense - in my mind its peace of mind going the right way in OEM part/ registry.
Need to pick up a trickle charger now ... |
08-22-2015, 02:07 PM | #13 | |
Retired Curmudgeon
2985
Rep 4,047
A Battery Tender is what you need.
Battery Tender Plus Works with AGM batteries. Quote:
FWIW, I used this on my wife's 2002 M3 when I was detailed to DC for four months. Worked like a champ. Hope this helps!
01-24-2016, 06:44 AM | #14 | |
Rep 2,966
Hadn't driven car for roughly a month due to travel - came back and "welcome lights" didn't activate as usual for about the first 2/3 drives till battery was back charged again. These cars are so sensitive |
02-22-2016, 11:55 PM | #15 |
Putcha ang ganda...
279
Rep 5,441
Bought a battery from sears AGM and been 3 years now still good if your in the OC area or LA i can register it for u for free
02-23-2016, 06:37 AM | #16 | |
Rep 2,966
All running well and strong - the key is to keep driving/ charging these cars! They like it! |
02-24-2016, 06:26 PM | #17 |
Rep 130
I am replacing mine this spring in my E93. Going with interstate had problems with the oem batteries with my 540 so switch to interstate. Good price and never had a problem in my 540.
02-24-2016, 07:27 PM | #18 | |
Stop the hate, get a V8
3850
Rep 8,625
BMW does not make batteries, they buy them from one of the big manufacturers like Johnson Controls and just get them relabeled. If you do some Googling you can find guides on indicators of who makes the battery (cap design, housing markings, etc). In the end, the manufacturer is largely irrelevant. Car companies routinely change suppliers. As it is, there are only a few battery manufacturers and tons of the stuff you see in stores is just relabeled. Even within the same "brand", you might have different suppliers -- the Sears DieHard, as an above poster referenced, could literally be any brand underneath. The easiest way to tell if it's AGM is to look for venting. If there is a ventilation tube or some sort of opening to the outside of the car, it's probably not AGM. My understanding is that the OEM E90 batteries are AGM and hence that's what you need to replace them with.
Past: 2011.5 M3 sedan ZCP |
03-14-2016, 02:46 PM | #19 | |
Rep 546
Drives: '08 e92 M3, no mods,no probs
05-18-2016, 03:15 PM | #20 |
Rep 1,932
Drives: 2013 E92 M3
My M3 had a new genuine BMW battery installed 3-15...the positive post is dated 1-15...it is black and there is a vent tube coming off of the front of it.
09-12-2016, 02:12 AM | #21 | |
Save the Manuals
1714
Rep 2,937
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
09-13-2016, 11:34 PM | #22 |
Retired Curmudgeon
2985
Rep 4,047
Don't tell my wife. I keep telling her it's the battery venting that is causing that *odor*.
