      12-08-2014, 01:57 PM   #1
Genericuser1
Drives: M3 Convertible
Taking my car in for last service
Going to have the dealer look at a couple of rattles/loose items. Car will be out of warranty in a couple of weeks anything else I should ask to be looked at?
I'll probably ask to have the rear pads checked to see if they are close enough for a change but I doubt it.
Vehicle is running fine and no issues that I can tell.
      12-08-2014, 01:59 PM   #2
BrewRifle
BrewRifle's Avatar
Drives: 2011 MCB E92 M3
2011 BMW M3  [7.56]
2013 BMW X3 35i  [0.00]
2009 BMW 135i  [8.00]
Make sure your A/C is running flawlessly since the evaporators are quite expensive to replace. Also, if you have any hiccups in your idle it could be a sign of your idle control valve on its way out. Check for any leaks around your motor and transmission.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
      12-08-2014, 02:45 PM   #3
davesaddiction
is fast cars
davesaddiction's Avatar
Drives: '08 E90 M3 6MT SSII BPM Stg II
x2 on the evaporator
If you thought the AC was weak at all this past summer (or even if you didn't), let them know and have it tested with dye.
      12-10-2014, 03:17 PM   #4
Genericuser1
Transmission fluid was added a few weeks ago and a leak test was done. New front rotors and pads were put on as well.
I'll ask about the AC, from what I can remember it was fine but I had the top down a lot and it was a mild summer.
Search this Thread:
Advanced Search
