12-22-2022, 01:18 PM | #1 |
Rep 116
Upgraded Injectors on a Stage 2 M3
Will upgrading my injectors yield me more power on a M3 with test pipes, E85, and tune? I understand that it matters more if you’re FI (Forced Induction). I was told by a reputable “Tuner” that upgrading injectors could yield me 40-50 Whp even if it’s not supercharged. I haven’t heard many M3 e9x owners talking about injectors on a vehicle that’s not FI for power gains.
12-22-2022, 01:29 PM | #2 |
Rep 6,771
Drives: 2016 BMW i8
A combination of going catless on a healthy S65 with new plugs and a good e85 tune could yield +50 hp gain. The injectors would be needed due to the e85, since the stock fuel system could be insufficient for this setup.
This setup would also be good for about 10mpg but would be really fun. Common knowledge that on an equivalent basis, it takes 30% more e85 than conventional gasoline to power an internal combustion engine.
ExoticM351.50 |
12-22-2022, 01:35 PM | #3 |
Rep 3,993
Full e85 tunes don't require upgrading injectors.
It wouldn't hurt to increase the injectors sizing, that way they wouldn't be overworked (higher duty cycle) with E85 like the factory ones are. I'd say if the tuner thinks he can get more power with bigger injectors, go with his recommendation and let us know the outcome. Keep in mind that any change in injectors need to be accounted for in the tune, you can't just throw in bigger injectors and expect them to work.
ExoticM351.50 |
12-22-2022, 04:17 PM | #4 |
Rep 116
tdott Will let you guys know the result of adding them on. I just never heard much people say “Add bigger injectors” when they talk about performance mode, usually testpipes etc.
12-23-2022, 02:20 AM | #5 |
Rep 1,109
How are the fuel lines with long term use of e85? I’ve seen it basically melt lines on older cars and I’m not 100% convinced it doesn’t contribute to stuck injectors on our cars.
12-23-2022, 08:06 AM | #6 |
Rep 1,195
You can run full E85 on the stock injectors so how would going with a larger injector make more power? If someone told you upgrading to larger injectors will net you a 40 to 50 hp gain you should walk away. That's called a scam.
Bmwdoubles_194.00 |
12-23-2022, 07:39 PM | #8 |
Rep 116
spammysammich people run full e85 with tune with no problems. I think bigger injectors with the mods on my car won’t make a huge difference.
spammysammich1588.00 |
12-23-2022, 07:50 PM | #10 |
Rep 1,109
Are you able to keep it on a tender? Might help a little. I haven’t even bothered trying to start up since we hit the 30s. Winter driving is what my old Subaru is for 😂
