05-23-2013, 07:50 PM | #1 |
Rep 175
Do I Need a New Battery?
Coming up 4 years in ownership. Today, all iDrive settings spontaneously reset to default. All stored radio stations disappeared. Equalizer settings reset to default. Both side mirrors reset to default.
No problems starting the car however, and clock is still accurate. Always use the same key so that's not the issue. If it's the battery, how long do I have before I can't even start the car? If not the battery, what's the problem?
2009 E92 M3 / DCT / AW / Black Extended / Akrapovic Evolution / BPM Engine+DCT Tune / Dinan Stage I + Camber Plates / HRE C20 / Valentine One by Alekshop
05-23-2013, 07:54 PM | #2 |
Rep 586
You're due for a battery whether or not this is causing your other problems... BMW batteries tend to go like clockwork every 4-5 yrs.
2013 E92 M3 (the weekend good weather car), 2018 Tesla Model 3 Performance (the 20k mi/yr beater)
05-23-2013, 08:45 PM | #4 |
You got my money?
3150
Rep 4,642
Drives: Ice Cream Truck
Yes you do.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
05-23-2013, 09:01 PM | #5 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
Sounds like you do. I just changed mine but my fault for not driving much and not using my battery tender.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
05-24-2013, 12:22 PM | #6 | |
The Hammock Man
493
Rep 593
Drives: X3MC, X3 M40i, E93 M3
- '20 X3MC | Alpine White | Black Alcantara/Midrand Beige | loaded | 295/265 PS4S - '09 E93 M3 | Alpine White | Bamboo Beige Novillo | DCT | loaded | Chrome M220 Wheels - 275/255 PSS |
05-24-2013, 01:06 PM | #7 |
Rep 4,381
Sounds like a key fault...battery problems are normally indicated by fault messages on the idrive and the clock going slow...looks like the key has lost all its settings and reset the car to default.
05-24-2013, 01:42 PM | #8 | |
///M3
42
Rep 348
http://www.walmart.com/ip/17688539?w...l5=pla&veh=sem |
05-24-2013, 01:43 PM | #9 |
Rep 115
I've got new battery under warranty a few weeks ago.
I had no welcome light, rear defroster and top control via key fob. Also had several low charge level and battery discharge warnings. |
05-24-2013, 03:07 PM | #10 |
Rep 1,404
Sometimes, electrical problems stem from poor battery connections. I suggest cleaning your terminals, charge the battery and see what happens.
Could your car be part of this recall?: http://www.m3post.com/forums/showthread.php?t=804611 I have the battery tender plus, too and it works great. My battery was located quite a distance from the plug. So, to avoid using an extension cord, I bought 12 foot cable (made by the same company) which extends the battery clips cable. |
05-24-2013, 03:46 PM | #11 |
Rep 1,599
I have 2 Battery Tender Plus's. One is BMW branded and the other is Deltran branded. They work great. You can also get the Deltran on Amazon for about $45.00. A search on "battery tender" on this site will yield many threads where people talk about their issues with keeping the battery on their M3 charged. Whether it's due to power drain while the car is sitting or charging schemes that prioritize fuel economy over keeping the battery charged (or a combination of both), it's apparent that you have to drive an M3 a lot and over good distances to keep the battery fully charged.
You want to get a tender with the alligator clips as the power socket in the interior is not hot when the car isn't operating (key fob not inserted). The jumper terminals in the engine compartment are generally the best connection points. With the fuel economy pressure on the auto manufacturers, I think keeping batteries charged will become more of an issue over time. We just bought a new CR-V. There's some weasel words in the manual about not using accessory power very much with the engine off. We have a friend that does in home physical therapy (the legitimate kind - degreed & licensed) that puts on lots of miles. She's had her CR-V for about a year and has started having battery trouble. As a result of her problems, I put our new CR-V on the battery tender. It took several hours to achieve a full charge, and now, even with driving it all the time, it takes about 4 hours for it to be fully charged when I hook the Battery Tender up to it after a few days. In the case of the CR-V, it appears to be a small battery (likely for both cost and weight) and a fuel mileage biased charging scheme.
05-24-2013, 03:50 PM | #12 |
Rep 395
Drives: 2008 E90 M3
Garage List 2013 Subaru WRX [10.00]
2000 Aprilia RSV Mi ... [10.00] 2008 BMW E90 M3 [10.00] 2005 Honda S2000 [10.00] |
Didn't even need to read the first post, the answer is yes.
05-24-2013, 04:57 PM | #14 | |
Rep 1,789
Still on the current battery and this happened maybe a year or two ago. |
05-24-2013, 05:04 PM | #15 |
Rep 110
Had you let it sit for awhile when it occurred back then? I know that if I don't drive mine for an extended amount of time the battery will discharge resulting in odd behavior. After driving symptoms go away.
2006 E46 ZCP Mystic Blue M3. 2008 E90 SSII M3. ///M
05-24-2013, 05:14 PM | #16 |
Rep 5,484
I keep my car on a battery tender to keep the electronics happy if I am letting it sit for more than a week at a time. Low voltage when the car is "asleep" can really freak things out the next time you start
But it's a long way from a slow clock to a dead battery, the power management system starts shutting off power to various nonessentisl things in a low voltage situation to preserve starting capability, at least in theory. My car started fine for a month before I finally convinced the dealer the battery was going
05-24-2013, 05:25 PM | #17 | |
General
63209
Rep 24,650
05-24-2013, 06:09 PM | #18 |
Rep 111
i have a 2008 392 m3 and i am still on the original battery. i have a ctek battery tender attached to the car once a week when i'm not using it. try using a battery tender first before replacing the battery
