      11-30-2017, 06:02 PM   #1
Dismed
Drives: E93 M
Carly help quick guide?
Is there a quick guide somewhere on how to do some of the popular coding? It is really confusing.
      12-01-2017, 03:32 PM   #2
Helmsman
Helmsman's Avatar
Sweden
4465
Drives: 2011 AW E90 M3 ZCP
Tell me whats confusing mate.
      12-01-2017, 04:13 PM   #3
Dismed
Drives: E93 M
I coded some stuff and now my car will only start with the key in the slot?
      12-01-2017, 04:17 PM   #4
codinge90
Drives: e92 M3
Go back to Carly and restore to your original settings. When you go to the coding section, click the CAS module and press restore. Don't mess with the comfort access settings too much other than the mirrors fold in and hold lock to roll windows up.
      12-01-2017, 04:27 PM   #5
Dismed
Drives: E93 M
Thats all I wanted but it wouldn't always work. I will try that thanks. I wish there was a quick guide to doing the simple things
      12-01-2017, 04:30 PM   #6
Helmsman
Helmsman's Avatar
Sweden
4465
When you prepare for coding the text per module/feature explains fairly well what will happen. I'd suggest you take a proper look there before you go Dismed.
Good luck
      12-01-2017, 04:33 PM   #7
Dismed
Drives: E93 M
I was drinking 😥
      05-07-2018, 09:28 PM   #8
PACarGuy
PACarGuy's Avatar
Drives: 2012 E92 M3 DCT ZCP
Did you end up figuring out how to just alter the mirror fold settings w/o causing any more problems? I tried same with Carly and got same issue where car only started w/fob in the slot so had to restore my coding back to original.
      05-07-2018, 09:37 PM   #9
codinge90
Drives: e92 M3
Which options did you change for mirror folding that caused the other problem as well?
      05-07-2018, 09:45 PM   #10
PACarGuy
PACarGuy's Avatar
Can't recall exactly now since I'm not connected, but I thought I turned on "comfort folding for side mirrors", but that didn't seem to make it work with the key fob remote. All that happened was that I couldn't start w/o the fob in the slot, though it's possible I also may have hit "deactivate comfort access" by accident.
      05-07-2018, 09:47 PM   #11
codinge90
Drives: e92 M3
Yes go back in and only enable comfort folding for side mirrors. Go into the FRM module after and check to see if comfort folding for side mirrors is an option there as well, that option has appeared on both modules on many different e9x for me. If it is present in the FRM enable it as well.
PACarGuy679.00
      05-07-2018, 10:08 PM   #12
PACarGuy
PACarGuy's Avatar
Thank you! Will try that tomorrow.
      05-21-2018, 01:50 PM   #13
PACarGuy
PACarGuy's Avatar
As an update, I enabled comfort folding in FRM as well and it's working now! Thanks again for the help.
