09-03-2012, 10:11 AM | #1 |
Rep 44
Towing DCT Transmission
Hi
I recently needed a tow of my 2011 M3 with DCT. Wile waiting for the wrecker, I dutifully read the manual, attached the tow hook, and placed the transmission in neutral using the screwdriver in the neutral unlock under the shifter boot. I go out and pushed the car pushed the car a little to verify the car was in neutral. All cool Right? No so.....! Since I had something of a wait for the driver, I walked the hood for a while. When the driver arrived, some little voice inside suggested that I verify that the car was still in neutral before she hauled the car up on the flatbed. Damned if the lock had not slipped back up into the lock position in the hour since I''d locked it out. So, I put the screwdriver back in and pulled it back down and got it up on the truck with no problem. Naturally then, when we arrived a the dealer, ready to get the car off the truck, I checked the lock again, and sure enough, it had slipped back into park lock once again. Wondering if the should be expected? Malfunction?. Maybe we should leave the screwdriver in the lock, and tie/weight it down somehow to prevent this. I see in the manual that the car will revert to park after 30 minutes of unlock when the key fob/slot method is used for a car wash or some short duration use. However I'd not expect that when the manual procedure is used. Anybody know? |
09-03-2012, 08:48 PM | #2 |
Rep 4,488
Isn't there a warning in the manual that DCTs shouldn't be towed more than a certain number of miles? Maybe this is why? I'm not sure what to expect, though. I'd insist on a flatbed next time though.
EDIT: If you were in fact on a flatbed, you have nothing to worry about. That warning only applies to being towed in such a way that your own tires are moving. That never happens on a flatbed, so you could never have shifted into Neutral at all and probably been fine except maybe while your car was being hauled onto said flatbed -- but even then most towers put dollies under your tires to do that, in which case even would have been a non-issue. And in fact even the trucks that still tow your car on an incline typically put dollies under the tires near the ground for the whole trip these days, in which case you'd have been fine there too.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 09-04-2012 at 09:05 AM.. |
09-03-2012, 09:16 PM | #4 | |
Troll
79
Rep 1,193
What happens if you park in a tow-away zone?
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport Quote:
09-03-2012, 09:23 PM | #5 |
Rep 753
09-03-2012, 09:45 PM | #6 | |||
Rep 1,590
But doesn't anyone read these threads anymore or just respond? |
09-03-2012, 10:15 PM | #8 | |
Rep 753
But i assumed that he flatbedded it from what he wrote |
09-03-2012, 10:18 PM | #9 |
Rep 92
What is there to assume??
OP said, and I quote "No so.....! Since I had something of a wait for the driver, I walked the hood for a while. When the driver arrived, some little voice inside suggested that I verify that the car was still in neutral before she hauled the car up on the flatbed." |
09-03-2012, 10:56 PM | #10 | |
Rep 44
09-04-2012, 08:11 AM | #11 |
Rep 4,488
Apologies, was reading on my iPhone. I've edited my original post.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 09-04-2012 at 09:04 AM.. |
