08-07-2017, 05:38 PM | #1 |
Rep 2,361
WingZeroX5's Maintenance Log
*Updated 11/22/18*
I've finally reached 150k and been planning for this milestone for a few months. Not much was done until at the 100K interval, where I replaced most of the suspension and major engine components. These past few years, I drove A LOT. I went to the south twice for training and vacationing in Florida twice as well. Weekly back and forth from NY, commuting in NY-NJ…this car gets driven. Since purchasing the car with 60k miles, OCI's were done every 7,500 miles, at least. Pictures below may not necessarily correlate with the OCIs. FAQ's 1. Original rod bearings? Yes 2. Original actuators? Yes 60,000 Purchased vehicle. Topped off oil 65,000 -Akebono front pads -New tires, Michelin PSS 245/275 66,000 -Replaced both D1S bulbs 67,500 -Oil change, Pennzoil Ultra Platinum 0w-40 70,000 -Upgraded to Dinan CF intake -Installed Dinan exhaust -Installed RPI intake scoops 75,000 -Oil change, Shell Rotella T6 -Brake fluid and coolant flushed -F/R control arms 80,000 -Oil change, Shell Rotella T6 -Driver side wheel bearing -L/R sway bar links -Inspection -Autocraft H8 AGM 900cca battery 87,500 -Oil change, Shell Rotella T6 -New tires, Toyo Proxes 4 Plus 245/275 90,000 -Rear ended, causing front end damage too. New complete rear subframe, both headlights. -Power steering flushed 95,000 -Other driver failed to yield right of way, making a right turn 25 ft from the intersection, WHILE PARALLEL PARKED on the left most lane. New driver side headlight, steering rack, fender, and rim. -Oil Change, Shell Rotella T6 100,000 More info on the 100k maintenance I did last year: http://www.m3post.com/forums/showthread.php?t=1262455 -Oil change, Shell Rotella T6 -F/R EDC Struts w/ new supporting components -F/R and upper/lower control arms -F/R and upper/lower control arms -L/R Tie rod assemblies -L/R tension struts -DCT Fluid drain/fill -DCT Filter changed -Spark plugs -Dinan air filter -Cabin filter -Engine mounts -Drive belts -Brake fluid flush -Differential fluid More info on DCT maintenance: http://www.m3post.com/forums/showthread.php?t=1280752 http://www.m3post.com/forums/showthread.php?t=1264788 107,500 -Oil change, Shell Rotella T6 111,000 -Repaired some rock chips on passenger side 123,456 I just thought it was cool 130,000 -Replaced starter 135,000 -TPMS module had to be replaced due to people not cleaning off the roofs of their cars and a whole block of ice took out my underpanels Last edited by WingZeroX5; 11-22-2018 at 12:16 AM.. |
08-07-2017, 05:39 PM | #2 |
Rep 2,361
150,000
A buddy of mine was free, so that cut down the time drastically as he worked on the engine and I did the suspension components -Replicated 100,000 maintenance schedule -New tires, Michelin AS3+ 245/265. Went down to stock in the rears -Upgraded I-Level software, done two weeks prior. -I do have a minor valve cover gasket leak, I'll have to address it at some point Here's a video of the engine cold start after all was done 165k - 1 July 18 I did the brakes at 160k for safety reasons but I'll stick this under the 165k category. I used Bendix rotors and ceramics from Rock Auto. See here: $42 Rotors on RockAuto? https://www.m3post.com/forums/showthread.php?t=1468984 I don't have the oil report yet from Blackstone but here's a vid of the engine sound Have to clean the engine bay next week too. Engine cleaned: https://www.m3post.com/forums/showthread.php?t=1517308 170,000 Things got a little interesting here, as documented in this thread I addressed the DCT leak and almost 2k miles later, it's still dry. As you can see in the pics, based on what I said in the thread referenced, the DCT filter is genuine OEM, made by getrag. It's a whole kit that can be purchased. So the reason for it not seating properly, is unknown. Could be error on my end, or could be a bad dct filter cap. Nonetheless, just check next time. To save a hefty amount of cash, Rock Auto sells the gasket by itself, and a filter. Though I normally go with FCPEuro, the price for a new DCT pan and the suction pump thing was not worth it in the long run, especially if it's just the gasket that needs to be replaced. 172,500 Replaced: -Spark Plugs -Dinan engine air filter -AC belt -Drive belt -Coolant vent hose (it broke) -Upper radiator hose (broke too) -Water pump (might as well if I'm dumping coolant) -Coolant -Diff fluid -Cabin filters -Oil changed Broke one of my coils in the rear, so I moved it up front and will be swapping them all out at 200k, just in time for the next spark plug change. If my valve cover gasket can last that long, I'll be changing those too as well. All done! 173,500 Replaced original alternator. New one is from Valeo, purchased from Rock Auto. Didn't see the price justification in going with FCP this time, especially if the original lasted this long. But I've been getting weird electrical issues once in a while, and had been occurring about 2x a week. ISTA showed over voltage at two ECU's. Voltage diagnostic at the terminals in the engine bay shows voltage dropping to low 12's, then spiking to 15V. This smoked my USB drive and had to re-download all of my songs lol 178,000 Returned from vacation, added about 4k miles from road trip. Didn't need to top off oil, strange. Last edited by WingZeroX5; 12-28-2018 at 08:26 PM.. |
08-07-2017, 06:07 PM | #6 |
Rep 307
makes me feel a lot better about mine
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019) 2019 Lexus IS300 (lasted 3 months) 2020 Toyota 4Runner TRD (fun truck) 2014 Tesla Model S P85 (wicked car) 2011.5 E92 M3 | Space Grey | ADV.1?s |
08-07-2017, 06:18 PM | #8 |
Rep 2,361
08-08-2017, 09:59 PM | #13 |
Rep 615
Drives: E92 M3 6MT Space/Black
Nice, motivating thread! She's good to go for many more miles i'd say !
GM |
08-08-2017, 10:04 PM | #14 | |||
Rep 2,361
Also, I've never had issues with the motor being noisier, especially those who use lubri moly. BMW ICOM NEXT A Quote:
R3dliner934.50 |
08-08-2017, 11:18 PM | #16 |
Rep 263
Drives: 2013 E93 M3 Jerez Black, 13 x5
Garage List 2017 GMC 2500HD denali [0.00]
2018 Tesla Model 3P [0.00] 2020 BWM x7 m50i [0.00] 2013 BMW X5 [0.00] 2013 BMW M3 E93 [0.00] |
Nice write up
08-09-2017, 06:53 AM | #17 | |
Rep 2,361
If everyone wants to see the bearings, I could setup a fund and y'all can chip in for the cost to change them out |
08-09-2017, 10:43 AM | #20 |
Rep 2,361
08-10-2017, 05:52 AM | #22 |
Rep 10,616
If you did all that other work yourself, you can handle bearings. It's $500 to $1000 in parts depending on what bearings and what bolts you buy plus a long day of your time.
