05-30-2014, 07:20 PM | #1 |
Rep 1,338
Drives: Round n' Round
FS: Brass Caliper Bushing Up Grade for OEM Calipers
SOLD!!! These are new, they fit rear OEM Brake Caliper on e9X M3 they do not fit the fronts on e9x as a longer size is needed (I realized this after I purchased them)...They also fit most all previous years BMWs brakes front & rear such as e46. They cost me $72 shipped, I am willing to sell for $50 shipped This sale includes 4 brass bushings, 4 Stainless Steel guide pins, 4 snap rings Description: "Simple upgrade gives BMW brakes a better feel and more even pad wear. The stock caliper on most BMWs uses a rubber guide pin bushing that allows the caliper to "twist" when you brake. This upgrade is a combination of precision guide pin and machined brass bushing which eliminate "twist" and allow the caliper to squeeze more evenly. You get a better feel and longer pad wear. Set of four; one set required per axle. Apply Stalube - Synthetic Brake Caliper Grease Last edited by kitesurfer; 11-05-2014 at 02:19 PM.. |
10-03-2014, 09:34 AM | #2 |
Rep 1,338
bump
10-03-2014, 10:29 AM | #4 |
Rep 1,338
Yep they will work on 335's rears brakes for sure, I am not sure about the front calipers, if the front calipers are like the M3's it will work in one bushing the other needs to be longer. If so you can buy them from Bimmerworld.
10-03-2014, 12:08 PM | #6 |
Rep 1,338
Yes they should fit e36, from what I understand they are universal for past years BMWs with the exception being e9x m3 front calipers, These are from Bavarian Auto sport. They are in new condition
11-01-2014, 06:53 PM | #7 |
Rep 1,338
someone needs these...
