01-21-2016, 10:04 AM | #1 |
Rep 1,485
Drives: 2011 Frozen Grey E90 M3
FS: Active Autowerke E9X M3 Supercharger Gen 1 LVL 2 Kit
Hey Guys Bought this kit last year from forum member Gt4 with VAG Motorsports in Montreal. Kit currently has approximately 18,000 km (11,000 miles) on it. I had the kit professionally installed in Calgary by Shenni's Autotrend. The car is currently on the car that is parked for the winter. It will be removed and packaged once a buyer comes forth. Please note that the kit will include a newer air filter, spark plugs and belt. All items were new at the time of install for me. The original owner indicated approximately 11,000 kms (6800 miles) while I have used it approximately for 7,000 km (4300 miles) (one season). Tune and HKS fluid is NOT included. Willing to ship at buyer's expense. It's a generation 1 so it has the HKS Gt-8550 supercharger with water/meth. Those kit were more expensive (15000$) vs the actual kit with the Rotrex (12000$) This kit is similar to the actual Gen 2 except for the HKS supercharger: http://store.activeautowerke.com/col...-gen-2-level-2 The advanced design and sleek features of the Active Autowerke Supercharger System include a front mount air-to-air intercooler system with a separate oil cooler for the supercharger unit's independent oil system. The Active Autowerke Supercharger Plenum replaces the factory air box and is designed to have an OEM-type look with custom finishes available at the customer's request. The Active Autowerke Supercharger Plenum has been designed with eight high-flow velocity stacks, and large three inch intercooler piping to supply cooled air. The custom Active Autowerke Filter mounts to the supercharger unit and is enclosed in a custom intake box engineered to incorporate factory design while forcing cool air to the air box. The optional methanol injection system assists in lowering intake air temperatures and prevents detonation. The Active Autowerke Supercharger System is powered by an HKS GTS8550 Supercharger Unit mounted with a custom CNC'ed bracket that uses a dedicated drive belt system, while eight high flow fuel injectors are used to supply the additional required fuel. Active Autowerkes Performance Software, available for 91-93 octane, race gas, and octane levels unique to other countries, is carefully calibrated, and is at the heart of the system to provide an unparalleled driving experience. Keeping within the factory's OBDII parameters, the Active Autowerke Supercharger System ensures consistency for everyday driving. AA E9X M3 Supercharger Plenum with Eight High-flow Velocity stacks HKS GTS8550 Supercharger AA Blow Off Valves & Bypass Valve Dedicated Belt Drive System (does not share belt with accessories) Eight-rib Pulley System Eight High-capacity Bosch Motorsport Fuel Injectors AA Performance Software for the MSS60 ECU with available upgrades CNC Hard Anodized Brackets and Hardware. AA Front-mount Air to Air Intercooler Independent Supercharger Oil Cooler Lifetime Traction Fluid for GTS8550 Supercharger Cold Air Intake Box AA Oil Breather System New Oil Line with A/N Fitting System High Performance AA Spec Filter Colder Heat Range Spark Plugs Methanol Injection System (Stage 2) with Progressive Controller All mounting hardware (plumbing, hoses and clamps) included Performance 650 HP and 440 ft lbs of torque (Specs for Stage 2 System, based on Mustang Dyno Readings) Boost 7.5 psi - 8.5 psi Reason for selling this kit: the car is going back to stock Price: $5500 (Paypal accepted. Buyer to pay fees) Last edited by FMLYSDN; 01-25-2016 at 12:43 PM.. |
01-25-2016, 12:43 PM | #2 |
Rep 1,485
Monday Bump
02-07-2016, 07:32 PM | #3 |
Rep 1,485
Bump
Kit is being removed as we speak. Soon to be boxed and ready to go. Operators standing by |
02-21-2016, 01:02 PM | #4 |
Rep 1,485
Bump
02-22-2016, 08:09 PM | #5 |
Rep 1,485
Sale pending.
03-23-2016, 07:25 AM | #6 |
Rep 1,485
SOLD
03-24-2016, 03:03 PM | #7 |
Rep 2,534
Drives: 16 G12 + 15 F06 + 17 F15
Someone, somewhere is happy as hell right now.
03-24-2016, 05:00 PM | #8 |
Rep 1,485
Yes. Yes indeed!
Thanks to all those that expressed interest. |
