09-16-2010, 09:53 AM | #1 |
Rep 1,883
Bluetooth passcode
Hey guys I was trying to pair my phone to my car , but since I bough my car used the fucker didn't give me manual or anything ! Now my question is does all BMW use same passcode ? If so can u guy help me out here and post a passcode for me thanks
09-16-2010, 10:03 AM | #3 |
Troll Harder
393
Rep 596
Drives: 997 GT3, 997 4 GTS, X6M
you set the password at every pair
otherwise try 0000 that's default for most anything bluetooth
09-16-2010, 10:37 AM | #5 |
Rep 1,838
Try
0000 000000 1234 123456 Or the last digits if your phone number The car doesn't have one it's your phone, so worst case just call your phone service provider
09-16-2010, 10:48 AM | #6 |
Troll Harder
393
Rep 596
I don't think you are pairing right
the car and the phone both ask for a passcode u need to put the same code on both for them to pair
09-16-2010, 10:51 AM | #7 |
Rep 564
09-16-2010, 11:00 AM | #8 |
Rep 3,637
09-16-2010, 11:15 AM | #9 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
-1. The car BT unit should have a set passcode. It will either come in the manual on a little laminated piece of paper or you can get it off of the TCU (usually in the trunk somewhere).
With the vehicles (at least mine and my BT headset) you only enter the passkey that is set for that device.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
09-16-2010, 11:36 AM | #10 | |
Rep 3,637
09-16-2010, 12:26 PM | #12 | |
Rep 4,365
here: http://www.zpost.com/forums/showthread.php?t=90592 and here for pictures: http://bimmerfest.com/forums/showthread.php?t=255333
09-16-2010, 12:33 PM | #13 |
Rep 1,268
When pairing the a phone, you have to put the phone in discover mode, and once the car connects to the phone the phone which come up with a prompt for pass code which you can enter any number you like. Once done the BMW will prompt you to enter the same pass code and once entered correctly the two should pair.
You might want to delete the previous pair phone form the BMW system so the previous owner phone does not show up in the list. |
09-16-2010, 12:34 PM | #14 | |
Rep 3,637
Hmm. Maybe this is for the Z4 only. I use 12345 in my GF's Acura TL and it worked. Also use 12345 when I pair with someone else's BT phone. Never had any issue. |
09-16-2010, 12:37 PM | #15 | |
Rep 10,309
Drives: A///MERICAN!!!
Typed 1234 when the BT asked for my code, went into BT connection on my phone, found BMW, prompted me for code, typed 1234, and the rest is history |
09-16-2010, 12:38 PM | #16 |
Rep 4,365
Perhaps then. I don't have Nav/DVD so there is really no good way for us to enter the #'s. Same with my Plantronics BT headset. Guess you can probably disregard my post, as the 335 is set up differently.
09-16-2010, 12:50 PM | #18 |
Rep 10,309
It isn't. Go in your car activate bluetooth on your phone and on your car. On your car, type 1234 for the code. Now go to bluetooth connections on your phone, and try accessing the connection for your car (will be called BMW something) and type 1234 when your phone prompts you for the code - the devices will pair.
09-16-2010, 02:04 PM | #19 |
Rep 2,032
Drives: Red Flyer
It's not really that complicated. I figured out how to pair my phone, and all the voice commands to store names, dial numbers, etc. on my own without the manual. The voice commands were trial and error to find the right phases, but it's pretty intuitive.
09-16-2010, 03:04 PM | #20 |
Rep 17,316
Drives: E92 M3, E30 325i
the bluetooth passcode for mine was 0000
09-16-2010, 03:17 PM | #21 |
Rep 1,289
I had to do it the exact same way when I had my M Coupe. With iDrive, it's as simple as creating an arbitrary code each time you want to pair a new device.
'16 ///M4 GTS
'11.75 ///E90 M3 ZCP | DCT '06 ///M5 | SMG - Gone '98 ///M3 | 5MT - Gone '07 ///M Coupe | 6MT - Gone |
09-16-2010, 03:18 PM | #22 |
Rep 10,309
