07-27-2021, 10:49 PM | #1 |
Rep 795
Looks like the rear end of my car...sank 10mm so?
About 63K miles on the car and all original suspension.
Was working on installing the front BBK, and replacing the 4 brake lines in the rear along with rear pads this past weekend. Jacked up the rear using the rear diff. After we put everything back, it felt like the rear end of the car sank maybe 10-20mm..? I am actually not sure if it looked that way for a while since I haven't been driving it a lot lately Car felt normal driving around, but it looks like the rear end sank 10-20mm on both side. I'm on 275/35-19 and 10.5 wide wheels and not rubbing, but the tire does look a little more tucked into the fender. Don't have a pic right now but it looks closer to the pic attached than stock height Going to try to figure out more later this week, but what could cause this? This has been bothering me since Sunday but the Texas heat and work is preventing me from working on the car right now
2011 BMW E92 M3
2018 Tesla Model 3 Long Range RWD |
07-28-2021, 06:51 AM | #2 | |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
///M Power-Belgium63516.50 |
07-28-2021, 07:00 AM | #3 |
Rep 946
^This. Never a good idea to use the diff as a jacking point. The diff floats in 3 rubber bushings that are not designed to handle 1800 pounds of car suspended above. Don't think this would make it sit lower and it definitely does seem to be sitting rather low if stock suspension.
07-28-2021, 10:29 AM | #6 |
Rep 801
1) Using the diff as a jack point isn't a big deal.
2) Even if you completely broke the diff mounts, that has ZERO impact on ride height. I'm not sure where you guys even get that idea from. Take the diff out entirely, and the only impact on ride height is from the weight reduction.
Scharbag2629.50 |
07-28-2021, 10:35 AM | #7 |
Rep 303
I just went out to check my 2012 M3 with stock competition suspension and I can easily see over the top of my rear tire in the wheel well. I agree that yours seems to be sitting a bit lower. There should be a factory specification that you can compare to.
With regards to suspension spring aging, I recently replaced the rear springs on my Audi A4 because one broke. After I finished the replacement and lowered the car, I noticed that the rear sat higher. Upon comparing with some older pictures of the car and factory specs, the new height was indeed back to normal. I think suspension changes happen so slowly that we don't even notice them. Only when we make repairs do the changes become noticeable. baba louey |
jpmonty866.00 |
07-28-2021, 10:40 AM | #8 |
09 M3 e93 VF650, e30 e85, Remus, Federal’s 595rs
205
Rep 329
Its in your head, mine sits about the same.
09 M3 E93 - VF650, AFD e30 e85, Remus Race, Federal’s 595 rs-pro’s.
07-28-2021, 10:44 AM | #9 | ||
Rep 795
2011 BMW E92 M3
07-28-2021, 10:47 AM | #10 | |||
Rep 795
but looking at the car again, it's not as bad as I first thought and probably just settling since the car is 10YO and on all original suspension
2011 BMW E92 M3
07-28-2021, 10:50 AM | #11 | |
Rep 795
I changed the wheels and tires on mine so it might be a little different compared to stock ZCP setup, but with the settling I can barely see the top of my rear tire, lower compared to new, but not as bad as I thought, probably had a heatstroke that day and my head wasn't clear lol You running any suspension mods with all that supercharger and stuff?
2011 BMW E92 M3
07-28-2021, 11:46 AM | #12 | |
Rep 2,141
Drives: 2011 E92 M3
Think about this: the S65 produces 295ftlb of torque at the flywheel. In first gear, with a 4.055:1 gear ratio (6MT here), the driveshaft is trying to twist the diff with ~1200ftlb of force. Then you run that through a 3.85:1 final drive and you are dealing with ~4600ftlb of force (well, assuming zero losses but still…). And this is for a stock S65. Think of the diffs in boosted S65s putting out over 450ftlb at the crank. Bottom line, diffs have to be VERY stout.
07-28-2021, 12:59 PM | #13 | |
Rep 946
Scharbag2629.50 |
07-28-2021, 02:32 PM | #14 | |
Rep 3,331
Flat spot in front of the diff fins is the approved jack point. Just need a good block to get past the fins.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
07-28-2021, 03:38 PM | #15 | |
Rep 2,141
Drives: 2011 E92 M3
08-06-2021, 03:52 PM | #16 |
Rep 2
Rear Suspension sagging ?
i think i have the same issue with my rear suspension too. lots of chat about rear diff .. (but is the rear suspension a problem and do i need to replace ? )
my driver side (RHD) seems really low when compared to the passenger side. |
