02-22-2018, 05:01 PM | #1 |
Rep 560
Has anything changed in the lightweight battery department?
My 2011 is turning seven in April and I think a new battery will probably be required soon.
I remember reading about the Lithium VoltPhreaks and other batteries which were $1000+. However, they appeared to not be well suited for a car which sits a lot. I'd love to get the M4 battery but I'm not sure if it can be coded into the E92. Have there been any new updates on this front since I last checked in 2015? My goal with this M3 has always been to shave 100 pounds off of the car with a battery, exhaust and personal weight loss. |
02-23-2018, 08:53 AM | #2 |
Rep 12,725
Voltphreaks vph900 has been used flawlessly in several people's cars for a few years now.
I've had mine almost a year, no issues.
02-23-2018, 08:55 AM | #3 |
///M Powered for Life
11480
Rep 10,328
This battery seems to be well tested and proven, however, it's several years old by now and I'm sure newer chemistry has come out
02-23-2018, 09:13 AM | #4 |
Rep 11,667
I'm going through the same thing, trying to find some reasonable weight reduction with the battery.
I'm still not convicted that lithium are a PnP solution, I've seen too many meltdown situations. Plus there is no way I'm spending +$1k USD for a battery. I used a Deka EXT20L that weighs 18 lbs on my Z4MC . it has worked flawlessly for 3 years now, no DD and always on a trickle charger. It was $150 CDN I'd like to do something similar with the M3, but there's more power required cranking over the S65 compared to the S54. And there's more electronics demand. ....then there's the coding issue. I haven't gotten into this topic very deep yet, but its definitely on the list.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
02-23-2018, 09:47 AM | #5 | |
Rep 11,667
this is new to me, do you have more info?
02-23-2018, 10:59 AM | #6 |
Rep 3,726
Drives: 2018 M2
actually your car is turning 8
02-23-2018, 11:56 AM | #7 |
11480
Rep 10,328
It's a Lithium-ion battery of some kind but it's still giant. I doubt it's 'lightweight'. And it'll cost $600 for sure
02-23-2018, 12:52 PM | #8 |
Rep 801
Meh. No interest in non-OE lithium batteries in a car application. They are just too explosive, and you really want one that you at least know someone is standing behind. I'd just find a smaller lead acid battery and make it work.
02-23-2018, 01:45 PM | #9 |
Rep 560
02-23-2018, 03:21 PM | #10 | |
Rep 3,726
Drives: 2018 M2
02-23-2018, 07:16 PM | #11 |
Rep 9,032
The Mini battery is suppose to bolt in and about 20 lbs lighter if I remember right.
02-24-2018, 05:44 AM | #12 | |
Rep 3,334
EDIT: Here is the link with the direct comparison. It states: "...uses a different IBS connector and vent tube than the E9X M3, doubt a swap would be suitable for previous M3 models." Footprint of the battery is the same however. It appears the actual difference is 30.9 lbs. I think what was noted in another thread is that this is the single biggest item in the weight difference between E90 and F80.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 Last edited by CSBM5; 02-24-2018 at 05:51 AM.. |
SYT_Shadow11479.50 |
02-24-2018, 08:14 AM | #14 |
Rep 11,667
On its own yes.
Weight reduction is normally a cumulative effort though and a single item at 30 lbs is huge.
02-24-2018, 08:37 AM | #15 |
mTekMods
2139
Rep 2,899
Maybe someone can try out the lithium ion battery from the F8x.
02-25-2018, 10:14 AM | #17 |
Rep 560
I'm trying to find a smashed F8x m3/m4 to grab the battery out of it. Hopefully the wrecker has no clue, and if it dies because the coding doesn't match, who cares.
02-25-2018, 10:19 AM | #18 |
Rep 3,334
You'll need to get the IBS connector setup and vent tube and figure out how to adapt those to the E9x -- it's apparently not a simple plug and play.
Current Stable:
02-25-2018, 12:15 PM | #19 | |
Rep 239
On paper, As the F80 battery is self contained, if it’s installed in the e90 and the IBS system is left intact it should work but the big question would be how it will behave as time passes with the charging programs designed for lead acid batteries from the IBS. |
CSBM52721.00 The-Traveler137.00 |
02-27-2018, 02:02 AM | #20 |
Rep 455
02-27-2018, 05:58 AM | #21 |
Rep 10,614
The older Mini battery is probably the cheapest option that will still start the car reliably in warm weather. The Deka ETX20L is lighter and weaker but might work for a while in warm weather and if trickled when parked for more than a day. There is also an older Miata battery that is in between these two.
02-27-2018, 06:30 AM | #22 |
Rep 5,483
There are several users including me who have had a voltphreaks battery for a while with no issues. There is no free lunch here yet. Unless you DIY, build your own battery and battery management circuit, in which case you can probably do it for under $300
My voltphreaks setup including custom shed-engineered home made mount is under 9lb and starts the car reliably below 30 degrees after sitting all day at work ( in the garage at home it’s never below 45). I use a tender for long stretches of down timebut it has sat for more than a week without the tender and starts the same as when I use it the next day. I would want a battery blanket to warm it if I drove/parked outside in super cold weather often. Last edited by Richbot; 02-27-2018 at 06:37 AM.. |
