09-11-2015, 06:41 PM | #1 |
Rep 252
Quick questions on rod bearings
Hey guys i know of 2 M3s that have had rod bearing failure in NZ now. Both of them 2008 models and high mileage approx. 70,000 miles +.
Are the new rod bearings still failing? Understand they changed and new part #s are 703 / 704. The new ones do not contain lead right? So oil analysis is not going to tell you if they are wearing? |
09-11-2015, 07:18 PM | #4 | |
General
63360
Rep 24,668
We saw all failing no matter what built year or type of bearings . Here is more => http://www.m3post.com/forums/showthread.php?t=786615 About what a Blackstone oil report would show in case of... Blackstone => http://www.blackstone-labs.com/ S65's from 2007 <=> May 2011 would show increased ppm levels of lead and copper in case of bad bearing wear . S65's after may 2011 <=> end of 2013 would show increased ppm levels of aluminium because the bearings were changed into aluminium by Euro/environment legislation . But.... For "NOT" turning another thread into Internet Hysteria I need to mention that we have also some outstanding S65's on here with + 150K miles on it !
09-11-2015, 07:58 PM | #5 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Yes the new bearings are blowing engines as well, no change. As stated above you will need to look for increased aluminium in the blackstone for the new bearings.
Just got my blackstone back from last change, running New bearings WPC treated, new bearings and supercharged for last 16k. Only had 3 for my aluminium level which is less than half of what the average is. Which is nice considering my orignal bearings were shot at 31k! Blackstone gave me a huge thumbs up
09-11-2015, 08:51 PM | #6 |
Rep 252
Thanks guys. Sucks the new ones are still blowing motors. But at least the wear can be monitored to some degree although I have read about some shitting themselves despite no warning from oil analysis. Damn.
09-11-2015, 11:13 PM | #7 | |
Rep 2,301
Currently at 120K miles, and was going to change mine at 150K, but after seeing this, I'm going for 200!!
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
09-12-2015, 06:52 AM | #8 | |
General
63360
Rep 24,668
About your pic that you posted ...It shows "190K Miles" ! And 190K Miles converted into KM's => "305,775 KM's" ! And 305,775 KM's for a S65 is just Think it's a World Record for our S65 engine... EDIT : And it shows with DCT trans .
09-13-2015, 06:07 PM | #9 |
Rep 252
Yeah ive seen that pic before you keep posting it all over the place. You rub that in ppls faces when their rod bearings fail do you? Yes this might only be affecting a small percentage of cars. You tell that to the poor bastard who has to pay to fix their engine because its out of warranty.
09-13-2015, 06:27 PM | #10 |
Rep 81
One thing you should make sure is that youdont over fill your oil, as more oil will take longer to heat up, dont rev past 3000 until the needle reaches 100c
and monitor the oil with blackstone, even with all this bs the engine is still one of the best in the world. |
09-14-2015, 12:26 AM | #11 | ||
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
For me, I am not one to gamble with a $25K+ engine. Once my stroker is built, I'll be pulling apart my original engine and dialing in the clearances on it too. To the OP, from the levidence we have, the failure rate does not seem to have changed with the new bearings. The clearances with the 702/703s is not much better than with the 088/089s. Also of note, the harder surface of the aluminium overlay on the 702/703s makes it much more likely for you to damage the journal in the event of metal on metal contact between the bearing and the journal. |
09-14-2015, 12:27 AM | #12 | |
Rep 1,017
09-14-2015, 02:48 AM | #13 | ||
Rep 252
09-14-2015, 08:12 AM | #15 | |
Grease Monkey
295
Rep 2,646
If so I'll be pulling the bottom end apart and measuring it all up as a project in my garage. Cost won't be an issue, since the labour will be free. The only thing I'll have to pay for is machine work, if required and parts. |
09-15-2015, 02:12 PM | #17 |
Rep 1,017
The new alum bearings 2011 +are thinner than the lead ones?? First time I have heard that, thought only the new aftermarket bearings were thinner.
09-16-2015, 08:35 AM | #18 |
4-6-8
234
Rep 990
How do you know this for a fact? I haven't seen any conclusive numbers on the actual number of S65 failures worldwide pre or post bearing p/n change, only those reported on this forum.
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
09-16-2015, 11:48 AM | #19 |
Rep 10,616
09-16-2015, 08:03 PM | #21 |
Rep 252
09-16-2015, 09:53 PM | #22 |
Rep 10,616
Everything I have read, and I have read everything on the subject, suggests that the bearing change was to comply with EU no lead laws and that there was no redesign of tolerances. Besides, to the extent there is a problem to fix, it was much less recognized in 2010 when the bearings were changed.
