01-01-2009, 09:00 PM | #1 |
Rep 655
Drives: Gone- 08 DCT SSII, 2006 SMG
Location: Current: 2014 BMW 4-Series Convert for the fiance w M Package, F150, 06 S2000, 08 911 c4s
Cheap HDMI cables are just as good... Don't waste your money.
I got into an argument with the guy at bestbuy regarding hdmi cables and happened to see this tonight. Given that CNET evaluates TV's every day, I take their real world testing over the snake oil salesman.... Also, check out
http://www.monoprice.com/products/su...08&cp_id=10828 tv wallmounts that are about 3-5 times cheaper than bestbuy...... http://reviews.cnet.com/hdmi-cable/?tag=mncol;txt What HDMI cable should I buy? Let's cut to the chase: CNET strongly recommends cheap HDMI cables widely available from online retailers instead of the expensive counterparts sold in your local electronics store. Here's why: Expensive cables aren't worth it If you walk into your typical electronics store to buy an HDMI cable, you're likely to see prices upward of $50 with promises of better performance and faster speeds. Do you really need to spend that much money on a single HDMI cable? Absolutely not--those cables are a rip-off. You should never pay more than $10 for a standard six-foot HDMI cable. And despite what salesmen and manufacturers might tell you, there's no meaningful difference between the $10 cable and the $50 cable. Unless you see something obvious, such as dropouts or a flashing screen, the digital information transmitted by both cables is exactly the same--no cable can make the picture any better or any worse. We've used cables from many different companies in the past--such as Belkin, Accell, Monoprice, Monster, and SimplayHD--and have not run into any consistent issues with any brand of cable. With working cables and solid connections, we've seen no dropouts and "sparklies"--just consistent, dependable, high-quality audio and video. It's that simple. Even a heavy-duty, high-end Monoprice cable cost us less than $20. But feel free to buy a cheaper one for a standard home theater. The editors at CNET are so confident that cheap HDMI cables offer identical performance, we've been using inexpensive Monoprice HDMI cables in the CNET Home Theater Lab for more than a year with no issues. That's saying a lot, especially when you consider that our video experts are constantly swapping in new products and changing configurations, which means our cables take much more abuse than they would in a normal home theater. We're also accustomed to making long cable runs, and many of our cables from Monoprice are 15 feet long. We also use even longer 20-foot cables from a generic maker with no appreciable loss in video quality. If cheap HDMI cables are good enough for the eagle-eyed video professionals at CNET, we're betting they're good enough for your home theater. And don't get hung about other cables that offer a lifetime guarantee, protecting you in case your cables are technologically obsolete in the future. If in a few years there are consumer video products that output higher-than-1080p video signals (an admittedly unlikely scenario), you can always buy another cheap $10 cable online that can handle more data. And you've still saved yourself $30 over that $50 cable in the store. Cheap HDMI cables sound great! Where can I get them? The best way to score a cheap HDMI cable is to order over the Internet. Here are a few of our favorite resellers, all of which offer solid return policies in case you do get a bum cable. Monoprice.com sells all other kinds of quality AV cables at very reasonable prices. As we mentioned before, we use Monoprice cables in CNET Labs, and several CNET editors use Monoprice in their personal home theaters as well. Amazon is especially convenient if you're already buying electronics from them and just want to "add to cart" an HDMI cable. We've done hands-on testing with a $2.10 HDMI cable from DVI Gear and haven't had any issues. Return policies vary by reseller, however, so do your research first. Newegg.com, another online retailer with whom CNET editors have had good experiences, has several HDMI cables for less than $10. CNET itself lists numerous inexpensive cables as search results for the term "hdmi cable"--as long as you sort the results properly (lowest price first). Again, return policies vary by reseller.
2008 SSII DCT M3/Peapack/Parsippany NJ
01-01-2009, 09:27 PM | #4 |
Rep 321
if you have an expensive tv that refreshes at 120Hz and you buy an HDMI cable that is not capable of 120Hz than you just wasted on that money on a big fancy tv. I'm not saying you need to buy particular brands but certain specs of the cables are important such as the frequency and what materials are used.
01-01-2009, 09:52 PM | #5 |
Rep 321
The bandwidth demand placed upon the cable is a function of the bitrate flowing through that cable. The bitrate, in turn, is a function of the resolution, frame rate, and color depth of the picture. The argument here is obvious enough... 120Hz signal has double the frame rate of 60Hz signal, and therefore needs double the bandwidth. So if your source is putting out signal at 120Hz and your cable can only handle 60Hz your going to loose some of your quality. Granted not all tvs refresh at 120hz and not all soucres are going to put out a signal at 120Hz but there are some instances where this is this case. I do agree that the normal everyday person can do with any old HDMI cable though.
01-01-2009, 10:26 PM | #7 | |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
This makes no sense whatsoever. The 120hz processor is internal to your TV and only effects the refresh rate of your TV picture. The HDMI cable supplies a signal to your TV at whatever rate the supply machine (cable box, satellite receiver, DVD/Blueray player) puts out. The cable has no effect on the rate (hertz) of the input signal. Your 120hz TV will still refresh the screen at 120hz regardless of the input source. The hertz is a rate of refresh and processing, there's no bandwidth changes. You've been sold a bill of goods my friend.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
01-01-2009, 10:29 PM | #10 |
Rep 1,247
Drives: E60 M5, E71 X6M, E46 M3
Garage List 2006 BMW E46 M3 'vert [0.00]
2008 BMW M5 [0.00] 2011 BMW E92 [0.00] 2012 BMW X6M [0.00] 2003 E46 M3 [0.00] |
cablesforless.com ...fast shipping, great prices, wide selection...
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
01-01-2009, 10:31 PM | #11 |
Rep 3,071
01-01-2009, 10:35 PM | #12 |
Rep 5,483
funny you brought this up, my girlfriends father told me about this and when I bought my Sony LCD a couple weeks ago, I bought 5 no name HDMIs (but I made sure that they supported 120hz as my TV required).
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
01-01-2009, 10:43 PM | #14 |
Rep 321
its not... i just wasn't getting into all the details the Hz rating of the cable os directly related to the bitrate of the cable... i know that the tv does the processing internall. So if your cable is rated for 10.2 gbps then your tv will process that to a 120Hz refresh rate. Now if you have a cable with with a slower bitrate you wont get the same quality with the refresh rate. Theres other reasons why certain cables are better than others and certain advantages but I don't feel like getting into it because i know it will turn into one of those threads where one person ends up fighting a large number of people... not fun
01-01-2009, 11:04 PM | #15 | |
Rep 18,823
Drives: BMW
Do Coat Hangers Sound As Good Monster Cables? http://consumerist.com/362926/do-coa...monster-cables After 5 tests, none could determine which was the Monster 1000 cable or the coat hanger wire. Further, when music was played through the coat hanger wire, we were asked if what we heard sounded good to us. All agreed that what was heard sounded excellent, however, when A-B tests occurred, it was impossible to determine which sounded best the majority of the time and which wire was in use. Needless to say, after the blind folds came off and we saw what my brother did, we learned he was right...most of what manufactures have to say about their products is pure hype. As for HDMI, a cable is a cable is a cable.
01-01-2009, 11:14 PM | #16 |
General
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
I just bought the HDMI 1.3a compliant cables from Amazon, sold by Amazon, for $9.99 with free 2-day shipping. They work fine.
Maybe we need scalbert to do some tests and hook them up to a scope to see the signal loss between Monster and cheap ones.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
01-01-2009, 11:19 PM | #17 | |
Rep 74
It truely is a rip off because its a digital signal which is composed of logical high (1) and logical low (0). If the siganl was an analog then the cable would play a big role in the quality, but digital signals only have two states, unlike analog. |
01-01-2009, 11:25 PM | #18 | |
General
384
Rep 21,747
Yup... rip off.
01-02-2009, 03:58 AM | #21 |
Rep 3,807
Drives: Retired 2017 F87 M2
when it comes to hdmi cables all hdmi cables are the same. Cables only matter for like RGB cables, optic cables and other audio cables, if quality is a must for you.
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
01-02-2009, 07:30 AM | #22 | |
I like cars
329
Rep 5,052
