08-05-2009, 02:48 PM | #1 |
Rep 180
TIRE SIZE HELP: 20x9 ET20, 20x10.5 ET26?
Like the title states, what's the optimal tire sizes for the following setup for an E92 M3:
F 20x9 ET20 R 20X10.5 ET26 The car will be dropped on H&R sports. I don't want rubbing, and don't want to roll the fenders either. Looking for the ideal street setup--with occasional track use. What do you guys recommend? |
08-05-2009, 06:53 PM | #2 | |
Automotive Industry Insider
462
Rep 1,948
255/30/20 for the front 295/25/20 for the rear These will be the perfect tire sizes for your new wheels. Anything more will be overkill IMO.
The best is yet to come...
08-06-2009, 12:13 AM | #3 | |
Rep 6,125
FYI: It would be the IDEAL to match stock diameter. 245/35/19 Diameter: 25.8 265/35/19 Diameter: 26.3 255/30/20 D 26.1 (+.3 inch larger than the stock) - optimal wheel width: 9 295/25/20 D 25.9 (-.4 inch smaller than the stock) - optimal wheel width: 10.5 So in stock setup, rear diameters are larger than the front. But with 255/30 and 295/25 setup, your front diameters are actually larger than the rear. Go to E90Post wheel section to use calculator or tirerack for overall diameter specs. I was looking for (actually still looking) same size wheel setup (CH-R) but had a hard time matching the tire diameters with optimal tire width. Good luck.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
08-06-2009, 12:54 AM | #4 | |
462
Rep 1,948
Those sizes aren't perfect, but they do provide him the proper clearance, rim lip protection and a rolling diameter within the 2% margin of error. (speedo) 245/30/20 offers slightly better rolling diameter, but at the expense of skinnier tires that offer less rim protection and are slightly stretched for the wider 9" wheel width... I would have suggested 305/25/20 for the rear tires, but the wide wheels + offset + lowered on H&R springs might cause rubbing issues on such a wide section width tire. It's not at all important to match the front and rear tire diameters exactly. Just as long as you don't get too far away from that OE baseline. I put a lot of thought into this, and I assure you my recommendations take everything into consideration. It's a delicate balancing act.
08-06-2009, 01:09 AM | #6 | |
462
Rep 1,948
If this is your only other option, then I would reconsider the 305/25/20 (26.0") before buying the 285/30/20 tires which are too big... 20" tire sizes are very limited.
08-06-2009, 02:17 AM | #7 |
Rep 195
if your looking for like new 2 front tires in Toyo (only 100 or less on them) I have a pair for sale
http://www.m3post.com/forums/showthread.php?t=262628 |
08-06-2009, 02:54 PM | #8 |
Rep 6,125
255/30/20 and 285/30/20 would work (and easier to find the tires).
Either that or 245/30/20, 285/30/20 will be my choice but 245 on 9" wheel will be kinda stretch look that I don't really like.
08-06-2009, 03:41 PM | #9 | |
Rep 1,164
-Andy
2008 M3 Sedan- Alpine White
08-06-2009, 04:29 PM | #10 |
Rep 726
I learned the hard way... different tire manufactures have different 'measurements' in what they consider a 255 or a 285, 295 etc...
To get closest to 'stock' Diameter, (height not width) I believe the 255/30/20 & 305/25/20 are the ticket. Especially in your case, with a 10.5" rear wheel. I went through three sets (in 2 weeks) until I was able to get it right... PM me your email... and I can send you some 'larger' pics... showing the difference of 255 & 285's vs. 255 & 305's. If you are going to go the 285's.. Yokohama S. Drive made a VERY big one... that fit on my 10.5" rear wheels great... But I didn't like the 'street noise' (when cornering spiritedly). So, I then tried Bridgestone RE050A... which was PERFECT on the front... but their version of the 285 was almost a full inch narrower, and 1/4" shorter than the Yokohama... (It looked like a '78 Dropped Cutlass!) I finally just ended up biting the bullet and purchasing the Michelin Pilot Sport PS2's, and went to the recommended 255/30/20 Front & 305/25/20 Rear. If you lower your car... I've heard the 255's up front will rub... so you may need to run the 245's. I think if you run the 295's in the back... it could look odd... as that tire is about 1/4" lower than stock... and would be awfully stretched on the 10.5" rim (if depending on the tire manufacturer, doesn't size up well.) If you attempt to search the 'actual' Tire Brand websites (Yokohama, Michelin, Toyo etc...) you can view the 'actual' tire specs... to compare which are sized bigger and smaller. Enjoy! Dave
2010 ZR1 3ZR Wht/Blk 10.7 @ 132
2011 C63 AMG P31 Car Blk/Blk 11.8 @ 117 2010 Nissan GT-R 10.8 @ 129 (Sold) 2008 Lexus IS-F (Sold) 12.5 @ 113 / 2008 Shelby GT500 (Sold) 11.3 @ 126 2008 e90 M3 6MT 12.8 @ 111 (Sold) / 2006 e60 M5 12.4 @ 114 (Sold) |
08-06-2009, 04:49 PM | #11 |
Rep 1,164
I once had this setup, lowered on H&R springs, with no rubbing:
20" x 9" ET20 20" x 10" ET25 Toyo Proxe 4's 295/25/20 255/30/20 It looked really good too. I believe Toyo's tend to look thin. -Andy
08-07-2009, 11:54 AM | #12 |
Rep 10,166
I run:
HRE P40 20x9 20x10.50 both et28 255x30 and 285x30 Nitto Invo... the Invo has a smaller sidewall and I have zero rubbing and Im dropped on RD sports (1.25 front drop and .9 rear). They drop the car more than H&R. Im sure if I ran PS2's Id rub.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
08-07-2009, 12:25 PM | #13 |
Rep 296
I am also running 9x20 on 255/30/20 and 10.5x20 on 285/30/20 wrapped in Nitto Invos. I'm not lowered but it looks perfect to me. No rubbing.
