09-29-2013, 03:27 PM | #1 |
Rep 91
My M3 is bellowing like a beached whale (VIDEO)
Note - Tried searching and couldn't find anything. Tough to search for sounds (screeching? whining? how would you describe this sound?)
Link to video: http://flic.kr/p/gfeRoL I pulled the car into the driveway after a 70 mile drive, and let it cool down for about 90 minutes. Then I came out and started washing the wheels. I rinsed all four wheels, sprayed on some wheel cleaner and went to work, starting with the rears. As I got to my last wheel (front), I started hearing a screeching noise. The frequency of the noise would occur at shorter intervals every time I sprayed water anywhere near the front section (!). I got my phone to record it, and then continued washing my car with the noise continuing. (No, I did not have the hood open while I was washing my car!). The phone's mic was close to the engine... it did not sound nearly this bad to the ear but was still loud. The noise persisted for about an hour through the wash. After the wash, the noise continued but at much longer intervals, and the car started up just fine. I let it idle for a few minutes, pulled it into the garage, and turned off the car. The noise did not recur at this point. Very odd. This probably unrelated but last night after a spirited drive and then maybe 5 miles of relative moderate driving, I parked the car and the radiator fan kept running. It was 50 degrees and midnight. I have driven the car in 100 degree weather and this had never happened before, so I thought it a bit odd... but most cars can technically do this (even if rare), so I did not worry. Any thoughts? Too far up the car to be fuel pump. AC was off for entire 70 mile drive. Car was off for ~90 mins before I started washing it. Is it some kind of radiator overflow / pressure valve / leak? Thanks!
E92 M3 6MT ZCP
09-29-2013, 03:36 PM | #2 |
General
62743
Rep 24,511
I think you need to call a Exorcist....
Serious now...i just don't know it man But keep us posted,i'm curious what caused this strange noise.........
09-29-2013, 04:01 PM | #3 |
Rep 161
2010 Melbourne Red E92 M3 / DCT / 220M / CF Roof / Premium / Assist / BT / PDC.
Evolve Stage 1 Tune / GTS DCT Flash / Servo Tune / OEM Exhaust Mod / BMC Drop In / H&R Sports Springs / BMS 15/12mm Spacers / CF Grilles / CF Gills / CF Hood Vents / Painted Reflectors / Extended Paddles / BMS ARC AE's / Cyba Scoops / 20% Tint |
09-29-2013, 07:56 PM | #6 |
Rep 91
E92 M3 6MT ZCP
09-29-2013, 09:26 PM | #11 |
Rep 7,594
Drives: '19 M2C
That sounds like a piezo element.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
09-29-2013, 09:27 PM | #12 |
Rep 91
you have it too? Yes same for me, the mic was close to the open engine plus the hood was acting like an amplifier
E92 M3 6MT ZCP
09-29-2013, 09:52 PM | #13 |
Rep 515
That's bmw being bmw..
09-29-2013, 11:41 PM | #14 |
Rep 1,159
Wow, I had this same noise coming from my Engine bay when I was cleaning my car about two months ago.
I want to make clear that I did not clean the engine bay. The funny part was, every time I sprayed a burst of water into the grill, the noise would go on. Very weird, I've only witnessed it once though so I'm not to worried.
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
09-29-2013, 11:57 PM | #15 |
You got my money?
3011
Rep 4,593
Drives: Ice Cream Truck
My guess.
Horn shorting out...
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
09-30-2013, 07:23 AM | #18 |
Rep 90
It's the radiator cap.
Pressure release from the system after you shut it down. I used to have an SW20 MR2 Turbo, they were quite bad for it because of the design of their cooling system. Fix for this was generally a new radiator cap or a higher pressure one. I would start with replacing the cap. |
09-30-2013, 11:00 AM | #20 |
Rep 349
Yup, I have the same noise. Sort of sounds like a bell ringing. I only notice it while washing the car. No idea what it might be. It doesn't seem to have any effect so, I just ignore it.
09-30-2013, 11:49 AM | #21 | |
Rep 91
E92 M3 6MT ZCP
09-30-2013, 01:45 PM | #22 |
floccinaucinihilipilifica tion
15
Rep 249
I've had a number of BMW's, and they've ALL done this including the 2012 135i I just sold (well, transferred the lease). I have sort of just decided to ignore it.
I suspect rsv4dan is probably right, but I don't think there's anything actually wrong; I think BMW's just do this. |
