11-22-2019, 02:12 PM | #1 |
Rep 950
Need help/guidance regarding HVAC in E90
Hello,
Where is the "air handler" located in the E90? My unit is blowing air only out the rear center vent. I suspect I may either knocked a wire out or created an obstruction not allowing the front vents to open while recently installing/running wires for the Android unit. In the interim, I guess Ill recheck my connections Any help troubleshooting would be greatly appreciated! Thank you in advance! Last edited by InnerBlueSkies; 11-22-2019 at 02:21 PM.. |
05-21-2021, 02:15 AM | #3 |
Rep 2
No, it's ok that you posted here. People sometimes have the same issues and barely find the solutions. Such posts really help to identify the causes. For example, I usually mess around with my air conditioner at home because it sometimes doesn't work properly. "Cooling a house when it's hot outside? No, thanks! I prefer to break", that's probably the way my aircon usually thinks. I think it's time to replace my old buddy with smth way better. So, I've already checked the brands on socool website and found a couple of good models. I think getting a new one instead of an old aircon (you need to repair it several times per year) would be a profitable move.
