08-23-2013, 08:10 PM | #1 |
Rep 1,388
\ 2008 82k miles Stock Rod Bearing Replacement /
Earlier this summer, by request of a local owner, we investigated the condition of the rod bearings in his 2008 DCT 82k mile, stock E90 M3 prior to installation of a supercharger system. Not knowing what we would find, our tech was prepared with a set of VAC upgraded bearings as a precaution. Below are the pictures of the condition of the bearings(!) which the owner was not too happy about. The new bearings were installed and tolerances verified before closing up the new VAC performance baffled oil pan.
It is becoming more apparent that rod bearings are a more important service item than one would expect, and wear heavily on these engines with or without supercharger enhancements. If anyone has any Technical questions, please feel free to email us Technical@vf-engineering.com |
08-23-2013, 08:15 PM | #2 |
Rep 1,673
Thanks for the pictures and info.
Still not understanding why people do not think this is a problem. As engines get older and higher mileage I think we are going to see a heap of failures start creeping up.
Electronics Junkie, Engine Builder.
08-23-2013, 08:34 PM | #3 |
Rep 1,239
My 2011 M3 had a rod bearing failure at 31,000 miles and I wasn't SC. At the time I was doing an oil change every 4 track dates or 4000 miles. I believe this Rod Bearing problem is not an inherently a high mileage M3 problem.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
08-24-2013, 09:08 AM | #7 |
Rep 1,962
Could someone explain what the rod bearings should look like at 100k miles? I understand that it cannot look like new so there will be some signs of wear (scratching or some etching on the bearing) but how do you know that this is far out of tolerances? On EAS's thread, I can see that one of the bearings that they took out (#8) was obliterated since there were chunks missing off the bearing but this bearing just looks worn.. Is the answer if the bearing starts to sheer into a different color in the center, then its shot?
Can someone also explain how to prevent this or if this is purely a flaw in BMW's design.
Peanut Butter Chunky
08-24-2013, 11:20 AM | #8 |
Rep 3,456
Drives: Harrop E90 M3
Since no one has pulled bearings on a car at the first oil service and every one thereafter to establish a timeline, there is no way to determine what mileage this should be done at. Especially considering these threads that have no oil analysis to back up the observation of bearing wear. Obviously those bearings are toast, but how do you know they haven't looked that way for the last 50k? How do you know whether or not they would go another 100k? Was the bottom end noisy? Was the car pulling timing or running poorly? I've pulled S54 bearings at 1200 miles during the recall days and seen them look like that. Obviously a lot of those cars were failing at the time, but it was determined to be an assembly contamination issue. I also just replaced some S54 bearings less than a month ago that were never done on an 03. The car had an HPF stage 1.5 kit installed at 56k miles and had 87k on the clock. They looked basically normal for the mileage with very little wear, especially considering the client follows the service indicator for his oil services. So we can't say all M engines running 10W-60 have issues can we?
Btw is every vendor jumping on the band wagon to start a rod bearing thread? Who's next, Gintani? Must be the cool thing to do these days. : |
08-24-2013, 11:32 AM | #9 |
Rep 4,033
The S54 is often brought up and used as an analogy, I'm curious to know what the clearances are on those bearings.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
08-24-2013, 11:47 AM | #10 | |
Rep 3,456
08-24-2013, 11:55 AM | #11 | |
DHS
229
Rep 4,043
Drives: 2023 M4, 2020 Land Rover
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
08-24-2013, 01:05 PM | #12 |
Rep 4,033
I didn't do a lot of digging but found that on the S54 they increased the bearings from .03 to .04 after the rod bearing issues, so that's quite a difference if true.
Edit: that's in metric, so it's not a huge difference, but still some. 03mm to .04mm is .0012 to .0016 inch. Here's a thread discussing it back in 2002: http://forums.bimmerforums.com/forum...amp-other-info
08-24-2013, 01:17 PM | #13 |
11818
Rep 23,187
bryan is that second portion of the article true about not replacing connecting rod bolts? why would that be? i still was planning the BW kit with ARP bolts, at some point as a precautionary measure.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
08-24-2013, 01:50 PM | #14 | |
Rep 3,456
08-24-2013, 01:51 PM | #15 | |
Rep 3,456
On a separate note, what did you have your bearing clearance set to? |
08-24-2013, 01:56 PM | #16 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
I am not quite sure why everyone still thinks that it is acceptable to do bearings as a maintenance item!?
The thing is, when you install new bearings without removing the engine, especially coated bearings like everyone seems to be using not only are you taking clearance away due to the added thickness of the coating, but you are also not able to properly measure the journals and rods to calculate an accurate clearance for each individual bearing/journal once assembled. I do realize most mechanics are going to be using plastigauge but lets face it, plastigauge is to give you an idea of clearance and is not a substitute for proper measuring with bore gauges and micrometers. So while I understand that the most people are not willing to remove their engines and have the cranks ground to achieve proper clearances I caution against installing coated bearings due to the added thickness and inconsistency of the coating. Calico themselves states the coating ranges from 0.0002" to 0.0004" and cautions to use their bearings with clearances of 0.002" to 0.003" and not to worry about the reduction in clearance from the coating. At 0.001" you really need to worry about 0.0002" to 0.0004" of a reduction in clearance. If you guys want to replace your bearings because you are not interested in removing your engines, please do it with OEM bearings so that you are not rolling the clearance dice with the coated bearings. I am not too versed on the Calico coating used on the bearings, it may be great, but please remember that the main and rod bearings in an engine work on the principle of hydrodynamic lubrication and no coating can replace that. Granted the coating on the bearings may be great, but at some point the coating is going to fail and then what happens? Just some food for thought...... The bulletin posted above shows that BMW recognized that adding clearance to the S54 would be accepted as a fix. They originally wanted the engines to be built with 0.03mm (~0.0012") of clearance but later wanted 0.04mm (~0.0016") of clearance. Both of these numbers are greater than what most of the measured S65's had for clearance (BMW don't post bearing clearances for the S65). To be honest, if the S65 had 0.0016" of clearance on the rods, although that is still a little tighter than accepted for a high performance engine, I would be comfortable with it an wouldn't be disassembling my engine to add clearance! |
08-24-2013, 02:06 PM | #17 | |
11818
Rep 23,187
08-24-2013, 02:06 PM | #18 | |
Grease Monkey
295
Rep 2,646
While many people are not having issues, they are most likely the people who have an issue but don't know about it because they haven't opened up their engines. |
08-24-2013, 02:11 PM | #19 | ||
Rep 3,456
08-24-2013, 02:16 PM | #20 | |
11818
Rep 23,187
http://store.bimmerworld.com/s54-rod...kit-p1020.aspx
08-24-2013, 02:18 PM | #21 |
Rep 3,456
My bad. I contradicted what I had already posted with a fat finger and no proofreading.
I edited my last post, thanks for catching that. |
08-24-2013, 02:25 PM | #22 |
11818
Rep 23,187
so i do still have an option here for my ancient car. im not in any hurry yet to do this but dont want to be hung out to dry with a spun bearing either and repairs that come with it. also dont know how much an advantage the ARP bolts and modified design of the bearing is? maybe it will be more important for me once i add the turbo, nitrous supercharger ive had my eye on. the turbo feeds exhaust boost to the SC so i can run 87 lbs of boost at max for about 1497 hp and with a 500 shot of nitrous i should be in the ballpark of those wrx-evo hard parker guys.
