05-30-2013, 12:35 PM | #1 |
Dub A
22
Rep 238
Switched to ZCP's from 220's(ride height increased??)
Need some advice from you folks:
Recently i switched from OEM 220's to OEM ZCP's - i kept the same tires(245/35/19 & 265/35/19 Conti's OEM) and the car seem to "raise" up and sit "higher". No suspension change - Eibachs with 15/12 MS spacers. Any reason why switching to the ZCP's with the same tires would increase the ride height?
2009 e92 m3 IB - Matte Grills/Gills, Lux v3, KW Sleeve, Akra
05-30-2013, 02:57 PM | #2 |
Rep 6,734
It takes a little time for the springs to settle after you jack up the car to change the tires. Tires have steel belts which dictate the diameter. The same tires will have the same diameter no matter what wheels they are on. The ZCP wheels are wider which stretches the tires more. That could also be creating the illusion of more fender gap.
'23 X7
05-30-2013, 03:33 PM | #3 |
Dub A
22
Rep 238
Hmm, really - the springs have been on the car for 20K+ miles. I guess ill be patient. The work was done yesterday afternoon, so its been approx 22hrs. Is that enough time for the springs to settle back?
Thanks for your response.
05-30-2013, 04:27 PM | #4 | |
Rep 4,089
Drives: 21 X6MC
05-30-2013, 04:27 PM | #5 |
Rep 7,594
Drives: '19 M2C
I did the same swap, no ride difference here. It does take some time for the suspension to re-settle.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
05-30-2013, 04:51 PM | #6 |
Dub A
22
Rep 238
Maybe i need to get my eyes checked.
I was using my fingers to check the gap, and its increased a tad bit. How long would it take for the springs to settle back?
05-30-2013, 10:14 PM | #7 |
Rep 3,341
A drive around the block was always enough for every spring change I ever did. You're comparing different rim widths with slightly different offsets. The tires are slightly stretched on ZCP's...all these things are probably throwing you off. You're not comparing apples to apples. Don't sweat it.
05-31-2013, 03:13 AM | #8 |
Dub A
22
Rep 238
Yah I'm not sweating it - just want that same wheel gap in had with the 220s.
If i change to a 30 series tire will it reduce the gap? The last thing I want to do a suspension mod.
05-31-2013, 06:08 AM | #9 |
Rep 7,594
Drives: '19 M2C
Pilot Super Sports on ZCP wheels on a non-ZCP car (like mine) looks perfect!
05-31-2013, 08:49 AM | #10 |
Rep 6,734
A 30 series tire in the same width is a lower profile and will increase the gap. You can switch to 255/35/19 and 275/35/19 tires if you want to reduce the gap. Those tires are slightly taller than OEM. Another trick is to add spacers which can give the illusion of less gap. Lastly lowering the car is the best way to reduce the gap... Based on your signature you already have eibach springs... Coilovers are the next step.
'23 X7
05-31-2013, 09:07 AM | #11 | |
Rep 6,912
It will INCREASE the gap!
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
05-31-2013, 09:21 AM | #12 |
Rep 7,594
Drives: '19 M2C
Here are 3 pictures of my ZCP wheels + Stock Michelin Super Sports on my Non-ZCP car.
I have no spacers, suspension is completely stock. I lightened the images up so you could better see the gap. -----
05-31-2013, 12:06 PM | #13 | |
Dub A
22
Rep 238
Spacers - already got them on there. My last resort will be to go do the KW sleeve's so i can adjust the ride height to my desire. Thanks for your input.
05-31-2013, 12:08 PM | #14 |
Dub A
22
Rep 238
Wow - looks eerily similar to my current wheel gap, and i have Eibachs, lol
05-31-2013, 09:30 PM | #15 |
Rep 7,594
Drives: '19 M2C
Here is what's funny. I have measured my car against another ZCP car and we had the exact same gap. I have always thought BMW screwed up my car and I got ZCP shocks.
06-01-2013, 12:32 AM | #16 |
Rep 3,341
I hear you. I've measured ZCP's on the lot that had more gap than a couple of my non-ZCP suspensions. BMW has a 10mm tolerance on ride height from corner to corner so I'm told.
06-02-2013, 04:18 PM | #17 | |
Dub A
22
Rep 238
Im still not happy with my drop - looking to get a couple of millimeters lower. Should i go with the 255 and 275 route or get the KW sleeve over kit?
06-03-2013, 03:58 AM | #18 |
78
Rep 684
Alright, this thread is getting a little silly...
1. Your 20,000 mile springs absolutely do NOT need to be settled after lifting your car up to install wheels. You may need to roll your car for a couple feet for the suspension/tires to get into normal position, but it has nothing to do with the spring settling. 2. As slicer mentioned, ZCP wheels are 0.5" wider than 220. This means that each tire is stretched 0.5" farther apart than before, which deformed the sidewall and created the larger fender gap (think hellaflush). But your ride height (as defined by BMW - measured from bottom of rim to fender) does not change.
06-03-2013, 04:58 AM | #19 | |
Rep 7,594
Drives: '19 M2C
06-03-2013, 07:31 AM | #20 |
Rep 556
Springs do need to settle after the car is jacked - but it only takes a few minutes of driving to take care of it, IMO.
I have Eibachs and 10/12 spacers on ZCPs. My rears do look a bit more tucked in than yours. Take some different pics, if you can. The shadows can play tricks on you. These pics were taken the same day of having all four corners jacked to install spacers. *EDIT: Posted the wrong comparo pic Last edited by Rk-d; 06-03-2013 at 07:52 AM.. |
06-03-2013, 07:49 AM | #21 | |
Rep 7,594
Drives: '19 M2C
06-03-2013, 07:53 AM | #22 |
Rep 556
